Question about Canon PIXMA MX310 All-In-One Printer
Mp 610 canon fails to reset my catridges after filleng
I have refilled the magenta colour catridge in my printer. Now after installing the catridge to the printer it dosent automatically know its full and to reset itself. And a red cross appears on top of the magenta colour if you look at the printer screen. Now i have pressed all the cleaning settings there are but no go . Apart from reseting the chip by machine is there any other cheat mode we can beat the printer with?
Any suggestions
  • janaiott Jan 27, 2009
    Mine is the Pixma MX310, black cartridge refill, same problem.
SOURCE: Printer MP160 service error 5010 after refill catridge
I had refilled the catrige, then when I start to print a 'service error' window will appear. At the LCD screed shows E.. 4 ..2. I believe the printer simply assume the catridge is depleted, but how can it happened as I already just refilled it.
How to make printer detected the catridge as a full? I really hope you can solve and make my refilling mission succesful and my printer work again.
Posted on Oct 01, 2008
SOURCE: doesnt recognise refilled catridge of canon pixma mp145
what is the cartridge number of canon pixma mp145
Posted on Apr 29, 2009
yboyandrei
  • 828 Answers
SOURCE: Error E14 while refill the catridge and installed
E14 The Ink cartridges whose destination are wrong.
Ae the cartridges the correct ones and are they in the correct carriage?
Try this:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thank you.
Yboyandrei
Posted on Aug 22, 2009
swoop611
  • 488 Answers
SOURCE: where is the catridge of pixma mp 240
easy one.. open the front of the printer, where the paper comes out. Place your thumb under the lip of the printer just under the name Canon and lift. The top of the printer will lift up and lock into place when you lift it high enough. Do this with the printer turned on and the cartridges will slide out from the right into the middle for easier replacement. If you do this and the printer is turned off, the cartridges are hidden from view as they are parked on the rest stand underneath the front panel buttons. Press the grey cartridge release towards the front of the printer and the cartridge enclosure will open, remove the cartridge, refit the new one (or the old one), close the enclosure cover and then drop the top cover by pushing the support leg towards the back of the printer as you lower the top. Then go into control panel, printers and scanners and right click on the printer icon. Select properties, then select the maintainence tab. click on the printer alignment and follow the procedure.. Done..
Posted on Oct 31, 2009
  • 43 Answers
SOURCE: canon mp 145 scan not working ink catridge
Hi, The scanning unit is independent from printing unit. You can scan even with empty ink cartridges. At sametime, if you wanna copy documents, you need both scanning and copying units to work. Try reinstalling the Driver from the provided drive CD.
Posted on Feb 22, 2010
Hi,i am using canon ip1300. i refilled my colour ink catridge,after 2 days they showing ink catridge cannot recognisable
Please press Stop/Reset button for 5 seconds. After you press 5 seconds your printer will start functioning... thanks
Sep 05, 2011 | Canon PIXMA iP1300 Printer
Printing turns green
Your color i.e. Yellow & Cyan were functioned well but Your Color i.e. Magenta is not functioned will.. so remove the catridge and refill the Magenda and after refilling rub the catridge head with a soft paper untill the magenta is over flow.. after that your printer will print better. .. thanks
Aug 26, 2011 | Canon Pixma MP500 All-In-One InkJet...
Printer failing to print colours properly
may the catridge is not working fine i thik you did all the cleaning test but you fail i advise you to use new catridge then try it will works
have a nice day and dont forget to rate please.
Feb 12, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Canon pixma mp 145 E4 problem
Dear Sir,
Error Code E4 = No ink.
Generally printer doesnt recognise refilled ink.
Try the to reset the ink catridges
by mp tool software,mptool reset the printers canon pixma series like MP150, MP160, MP170, MP180, MP450 and MP460.And there also facility to write and read EEPROM in the printer. Other excess this software is detect automatically installing printers in the computer.
Download Mp tool
i think it solves your problem,But the actual procedure and best solution is replace the ink catridges,according to canon new genuine canon ink catridges save your printer life also.
if you find any difficulty leave a feedback,we will glad to assist you
good luck
Sep 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E5 problem
E5, says the ink cartridges are the wrong type, not properly installed, or not installed at all. You can't refill those without replacing the chip or resetting the chip. Many refilled cartridges just don't work...
Aug 27, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
My HP 6500 on install will recognize Cyan ink
Solution:
1. Try to determine whether the catridge is at fault. How so? Switch the Magenta with the Cyan catridge. Press OK.
2. If system indicates that the Magenta is not installed, you will know that the Cyan that you put there is at fault.
3. Touch the 9 mm. hole where you can see the sponge. Does the Cyan color transfer to your finger? If not, the catridge is empty or dried up. Replace or refill.
4. If the ink is normal, then use some toilet tissue to wipe the gold contact points clean. If this fails to solve your problem, take it to your dealer and ask for a replacement (if it fails to work in their machine).
5. If this fails, then the problem is within your HP 6500. You need a technician.
www.catherinecollege.net
Aug 08, 2009 | HP Officejet 6500 Wireless All-in-One...
Not printing
hi sand;
you may try cleaning the copper in your cartridge with tissue paper and also the pins in the printer but do it slowly, and see if it works
thanks
Jun 05, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP 4600DN RED CARTRIDGE LEAKING TONER
are you using non refilled genuine HP carts?
Nov 26, 2007 | HP LaserJet 4600dn Color Printer
Canon PIXMA MX310 All-In-One Printer Logo
191 people viewed this question
old marine
old marine
