Question about Gigabyte GA-7VTXE Motherboard
Gigabyte - Bad Capacitors!!
Continuing over from my last post about that crazy sound issue - Good news, and bad news. The good news is I finally found out what was causing my system instability! After weeks of tweaking the OS, checking the RAM, and virtually trying to narrow down the culprit while losing my hair, I finally checked where I would have least suspected to check: the MB itself. The bad news is that it's blown capacitors on the MB. Several of them, in fact. Apparently this is not a new issue with this Gigabyte model. My hubbie claims he's a pro with saudering and volunteered to replace the caps for me. However, I've read this isn't as simple as it might seem to be due to layering, and then it's better off to buy a new MB. My question to you wonderful people is this: What kind of warranty is offered on this model? I didn't buy the MB, it was given to me. Is there any way I can get the manufacturer to replace what apparently was a bad technical issue on these models? If not, should we go ahead and see if we can't replace the capacitors? And finally, if my best option is to buy a new board, what would you recommend swapping this out with? I'm looking to stay at 100$ or under, and newegg is a great site. But I want to replace this the easiest and make sure the new board fits my old hardware, not to mention i'm wary to purchase another GB model. Any suggestions? Thank you!!
  • 624 Answers
There was a widespread, industry-wide problem with bad capacitors in 2003/2004 timeframe. I know Dell has a good warranty replacement program (expires in 2008) for motherboards and power supplies that were built in that time frame. I have also ?heard? that several other manufactures have programs as well but the time on them is running out as well. I couldn?t find anything about a program specifically from Gigabyte but that?s not surprising. I had to literally pull it out of Dell and that only after two calls. I would definitely not try any home repairs till after calling the tech support site to see if they have an active program and if you qualify. As far as self-repairs to your motherboard go, it can be done if you have good skills and experience working on commercial electronics plus the equipment to match. If you go that route I strongly recommend you have a reliable backup of all your data just in case your repair does more harm than good. Also be aware that a bad repair job could result in damaging other components such as CPU, memory, disks and other peripherals. You should balance that against the fact that new motherboards range in price from $40 on up. Good luck.
Posted on Jul 13, 2007
SOURCE:
Lg x13 screen issue? no display.
Well, the good news is you pretty much trouble shot the issue. If you plug it into the monitor and see your desktop without any issues, the video card in the notebook is still good. That's the good news. The bad news is your laptop display is bad. It sounds like your back light is failing. You can purchase another one; but it is much easier to replace the screen as several things can go wrong trying to replace just the back light. There are plenty of YouTube videos on how to replace the screen yourself if you're daring enough, or take it to a computer repair store and they can replace it for you.
Oct 27, 2014 | HQRP Car Charger 12V DC Adapter...
Message password unlock
Have you tried the default password? The default password is the last four digits of the phone number assigned to that phone.
Hope this helps
Jun 27, 2008 | Cell Phones
My 1985 Plymouth caravelle 2.2 turbo is having issues when you take off you hear the turbo whined up and it was a nice sound. Now it whindes up it is so high pitched it kind of sounds like a fire truck...
Sorry to tell you but it sounds like bad turbo. Best option to find used one on ebay and replace. Bad news is that for that age of car a used one may not be good or last long either.
Jan 09, 2018 | Cars & Trucks
My Samsung LNS4051 has sound but no picture. I replaced 2 bulging capacitors (CM807 and 808), and it worked for less than 1 day. The other 4 caps frequently mentioned on this site appear to be good, but...
When you replace obviously bad capacitors (bulging, leaking), make sure you also replace any adjacent similar capacitors even if they look ok because they are almost certainly bad too.
If you find 2 bulging ones in a group of 6, don't skimp, just replace all 6 while you have it open.
Good luck and please post back with how you make out.
Jan 25, 2011 | Televison & Video
Backfiring
good news/bad news
the good news it may just be a timing issue
the bad news is it may be a valve train issue
lets start with some information like...
how long have you had the vehicle
how has it been maintained
when was the last tune-up
are there any aftermarket items installed?
Apr 17, 2010 | Dodge Pickup Cars & Trucks
I was driving my car the other day and it turned off completely.
The most likely cause is a broken earth wire and or bad connection
Jul 10, 2009 | Chevrolet Lumina Cars & Trucks
0175 crc1 stop post task. can u please help how 2 fix this problem.. THANK U VERY MUCH...
Well, bad news. A bad crc usually means the cheapest way out is a new board.
You've got hardware issues.
Sorry.
Good luck
Dec 22, 2007 | IBM ThinkPad A21m 2628 Notebook
Password
Hi there
Try using the last four (4) digits of you phone number. Hope this helps and please remember to put a good rating on this post.
If this doesn't work try this:There's good news and bad news. The good news is that you might well have forgotten that the default password on the phone is either 0000 (that's four zeros) or 00000000 (that's eight zeros). The bad news is that if you've changed it to something else and that's what you've forgotten, you might well need to take the phone in to a service center to have them help you break it back open.Please remember to put a good rating on this solution.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as FixYa! if it helps you.
Kind regards
Dustin Ellse (BearWeb)
Dec 22, 2007 | Samsung SGH-D600 Cellular Phone
Gigabyte GA-7VTXE Motherboard Logo
521 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
