How to download VGA Driver For Windows & version
Sir, i installed the windows 7 OS .Now I have one problem . My Mercury Driver Cd will not install the VGA Driver.because It has only Xp,And Vista Drivers.How to get it from the website.Please Reply Me Where is Intel graphics media accelerator driver located for windows 7.
I need download it immediately
  • sivamzcet Jan 25, 2009
Guys, I faced this problem, and I discovered a website that contains steps to fix it. it is in www.win7-vga-solution.com
I tried it and it worked fine with me.
Posted on Feb 02, 2010
Cannot install MGI PhotoSuite4 on a computer running Windows 7 OS
The PhotoSuite 4 program is very old and won't work under Windows 7. http://sonic.net/mnitepub/pccafe/reviews/photosuite4/photosuite4.html says that the version 4 Platinum edition ran under Win95-Win2000 versions of the Windows OS. Thus even the compatibility mode probably won't help under Windows 7 32-bit. You can try it though by right clicking on the installer and then selecting Properties. In the Compatibility Mode tab, select Always Run this program in the compatibility mode and an older version of Windows. Then right click again and choose Run as Administrator. (You may have to do this again on the program itself.) Since Win7 64-bit requires signed drivers or programs, it is not as likely to work. (Check your version of Windows 7 by clicking Start > Control Panel > System and Security > System. If the title of your OS ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit OS.)
If you have Windows 7 Pro or Ultimate (or upgrade to one of those versions), you can run a virtual version of XP for free. Download and install Microsoft's Virtual PC and then XP mode (in order). This works best if your CPU supports virtualization and you enable the feature in your computer's BIOS. (There are work-arounds for computers without virtualization. See the MS support pages.) Install your PhotoSuite inside the virtual XP program in that case.This old software may run in that case. (However, I've had some Win2K software that ran under XP with the compatibility mode but didn't run under the virtual XP. Note: virtual computers do have some additional limitations. They do not talk to the host hard drive and other hardware directly. (You can install a printer on the host machine or the virtual machine but not both.) You'll need to save files on external media (flash drive, optical disc or other hard drive) to transfer them between the machines).
Another option is to run an older version of Windows on another computer, as a dual boot computer or with Virtual PC (or another virtual computer package - VMWare or Parallels). In that case, you need a licensed version of the older Windows OS. Again install the program while running the older OS.
The final option is to upgrade to a Windows 7 compatible Photo editor and organizer. (Even the Microsoft Windows Live Photo Gallery has some of the features of Photosuite SE.)
I hope this helps.
Mar 24, 2012 | MGI Software PhotoSuite SE V4.0
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
Does the Design Studio for Plastic Canvas work with Windows 7? I bought the item on Amazon, and the description stated Windows 95/98 and later, but the box only states Windows 95/98. The seller could not...
First what version of Windows 7 are you running? Click on Start > Control Panel > System and Security > System and read the title of your OS. If it ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit version. Next which version of Design Studio do you have? If you have version 2.0, that is compatible with XP and Vista (not x64).
If you use a 32-bit version of Windows 7, you may be able to get it to work with the compatibility mode. Right click on the installer on the CD and choose Properties. In the Compatibility tab, set the "Run this program in the Compatibility Mode" and choose an older version of Windows (try XP first). Then right click again on the installer and choose Run as Administrator.
However, it will not work with the 64-bit version due to unsigned drivers and other issues.
There are workarounds if the program doesn't work in the compatibility mode. You need an older version of Windows running. This could be on a physical second computer, a dual boot system or a virtual computer. If you have Windows 7 Pro or Ultimate or upgrade to one of them, you can use a virtual version of XP for free. Download and install Virtual PC and the XP mode from Microsoft in order. Then install your Design Studio in the XP "machine" as if it was your only computer. The only restriction is that you can not share your printer or files under XP mode and Win 7 at the same time. You will need to uninstall the printer and reinstall it under the other OS or transfer the files to external media to share them. Other virtual computer programs are Parallels and VMWare. For these virtual computer, the dual boot, or the physical second computer option, you will need a licensed version of the older Windows OS.
The documentation and an update are available here: http://www.plasticcanvassoftware.com/ . The update is in the Customer Service section.
I hope this helps.
Aug 16, 2011 | M & R Technologies Plastic Canvas Design...
Sir, i have installed the windows 7 os in my pc. But i have problem that i am unable to install the vga in my computer from tha motherboard CD. ineed to install the vga now. So please help me to install...
Hi, I am Steve, lets get you some help.
The reason it wont install is because it is not Windows 7 compatible which is not a surprise. You need to go to the support site for your graphics card and download the correct driver for windows 7.
Did you check for Win 7 compatibility before installing?
I can give you more detailed instructions if you tell me the make and model of your computer.
Feb 06, 2011 | Computers & Internet
Is this compatible with Windows 7 OS
yes can be, just follow these steps:
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Sep 18, 2010 | Broderbund PrintMaster Gold 16 for PC
MPEG VIO Driver Error photo explosion special edition 3.0
How to correct a Load MPEG VIO Driver Error in Windows Vista.
If you are experiencing this issue with Windows Vista, please follow these directions:
Note: These steps are only for Windows Vista. If you are experiencing the problem on Windows XP, please see the directions found here: KB Article 1469
1. Uninstall Photo Explosion 3.0.
2. Reinstall Photo Explosion 3.0.
3. Restart the computer.
4. Download the Vista update for Photo Explosion 3.0 from the following link:
http://www.novadevelopment.com/Support/Updates.aspx
Note: Please make sure you download the correct one for your version of Photo Explosion 3.0. If you have the Deluxe version, download the Deluxe update. If you have the regular version, download the non-Deluxe update.
5. Save the update to an easily accessible location, such as your Desktop.
6. Once downloaded, go to where the update was saved and double-click the update.
7. After installing the update, you should no longer experience this problem.
Note: It is extremely important that you do not run Photo Explosion until you have restarted the computer and installed the update. If you run the program before installing the update, you will need to start the steps over from the beginning.
This comes directly from the Nova FAQs. Hope this helps!
Jun 30, 2010 | Nova Development Photo Explosion Deluxe...
How to Download Windows Media Player
Here's the link to Windows Media Player 11, If you know your windows is Genuine, the go ahead, but if your windows copy isn't genuine, download this one and follow the instructions shown here, otherwise you'll not be able to reinstall it. Good luck. Thanks for using Fixya.
Jun 05, 2010 | Microsoft Windows Media Player
Can I install my software in windows 7
before you can install the windows 7 operating system, download first the windows advisor software that allows you the check your computer if the components of your system is capable for having a windows 7 operating system, it also checks your computer if you have incompatible programs and applications if your thinking of an upgrade from windows vista to windows 7.
if your planning to do an upgrade check the version of your vista OS to see the compatible version of windows 7.
i hope this helps
Feb 25, 2010 | Broderbund PrintMaster Platinum 16
My OS is Windows Vista Home Premium. I have Am. Greetigs CreataCard Platinum 7. Does this not work with my OS? It seems to be "preparing for installation" a long time with no luck to run the program....
Start the "Windows Compatibility Wizard".
Select that you want to install a "Windows XP Application".
Point to the CD-ROM containing the software.
Install it by selecting the 'setup.exe' file.
Nov 14, 2009 | Broderbund American Greetings CreataCard...
Biostar GF 7025-M2 v.6.0 Motherboard Drivers For Windows XP Home
yes there are seperate versions for 32bit and 64 bit . check on majorgeeks.com for the drivers, also check cnet downloads for drivers. If the mother board is more than 5yrs old you might not find the 32 bit drivers on the manufacturer's website. also check microsoft , if they have any drivers for that motherboard. good luck
Jul 11, 2009 | Computers & Internet
Computers & Internet Logo
3,494 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
