Question about Dell OptiPlex GX260 PC Desktop
Exchanged case from Optiplex GX270, no boot
Hello, I have just exchanged case, since i wanted to go water cooling. I have preparated out those two miniboards, that start the computer and plugged everything in. Now when i press the start button, everything starts to spin, but i get no visual. Can't get even to BIOS. The computer worked before and I am certain i did not damage any components. What might i have missed?
  • 1 more comment
  • jurnecka Jan 25, 2009
    Thanks, but i already tried that like ten times. However its strange, that i dont get any self test sounds from the speaker.
    I really appreciate it. As I have already mentioned, i switched to water cooling, therefore the fan is not connected (i also tried to connect it together with water). So I have reseated the processor, but I still get no POST. I am really running out of ideas.
    Could I have screwed the cooler too much, so the processor got sqeezed? Is something like that possible?
Try the old power supply. Dells are legendary for screwing with the wiring. I have heard they did this for pre P4, but who knows they could've done this with a few P4's as well.
If that's the case and I'm sure you're gonna need the power check out: http://www.pcpower.com/products/power_supplies/dell/ They have one made to solve this problem.
Posted on Feb 11, 2009
    Scholar:
  • 49 Answers
Check to make sure all of your cards and memory are seated properly.  Remove all of the cards and reseat them.  Best way to do it is remove everything, then put your RAM back in.  See if it will POST (Power On Self Test, e.g. the single beep).  If so, start putting each expansion card (e.g. video, audio, raid, etc) in one at a time and see if it will POST.  Also, make sure your CPU and heatsink are seated properly.  While changing cases shouldn't change anything, a stray bump in the process could have dislodged things.
Posted on Jan 25, 2009
  • Nick DelRegno Jan 25, 2009
    Usually the only thing that would keep it from passing POST is the processor or memory issues.  Also, make sure the ATX power connector is connected.  I'd reseat the processor, being careful not to mess up the thermal paste.  Lastly, make sure the CPU fan is A) connected and B) to the right fan pins.
HOW I FIXMY VIVORT
Hi, This is a problem in the BIOS my advice to you is get in touch straight away as you will always have problems! unless they are prepared to walk you through the settings in the BIOS. Be a happy PC owner & get this exchanged free of everything they should exchange the PC without any problems & they will pick up the present PC when they deliver the new one to you. I must add the blue screen is another problem with the Video card, Hence stick out for an exchanged PC it's their liability. Please leave me feed back: Malcolm Campbell, Thanks.
Oct 31, 2017 | ASUS VivoTab RT
Hello I have a Dell optiplex GX270, with the mobo it comes with. It will boot, has sound coming from the HD, CD drive, cpu cooling fan, etc, but will not show anything on the monitor and the keyboard...
Hi,try swapping the Memory chip ie putting it on the other slot,also test with another processor if after all these system does display,i'll suggest you go get a new board.
Jan 04, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
Have a 1993 toyota paseo it keeps running hot change out radiator and house it does not have a tremostate could that be making it run hot
An explanation of the cooling system.
You start your car, it is cold at first. The thermostat is shut. Car warms up and raises the temperature of the coolant in the engine block. Thermostat opens up. Water from the radiator (cool) is exchanged for water from the engine block (hot) The cool water causes the thermostat to shut. This traps the hot water in the radiator so that it can be cooled down. The cool water that was exchanged for the hot water, now becomes the hot water because it is in the engine block. It heats up until it's temperature causes the thermostat to open again, exchanging cool water for hot water. If you have no thermostat, then you will never hold water inside your radiator. You have to hold it there to allow it to cool off, then it becomes useful to cool your engine. So, yes put a thermostat back in it, and please vote as to whether this was helpful or not.
Nov 23, 2010 | 1993 Toyota Paseo
Dell OptiPlex GX270 PC Desktop Remove cover
Press the black buttons on the sides of the computer located toward the back of the computer. The case will open on a hinge. The case can stick, so you may have to try it a few times.
Oct 09, 2010 | Dell OptiPlex GX270 PC Desktop
Dell optiplex gx270 shuts down when cpu setting is on normal but runs when on compatible mode
The GX270 has a manufacturers defect with the motherboard. Open up the case and look at the capacitors, they look like a bunch of upsidedown double AA batteries sticking out of the board. The capacitors on the GX270 are bad if you see a crust on them or some kind of brown liquid, DO NOT TOUCH this it is battery acid.
Jan 08, 2010 | Dell Heatsink and Fan Optiplex GX270 K4598...
Booting Problems With Dell Optiplex gx270 and gx260
Does anything show up on the screen when you access your BIOS?
Have you tried a fresh install?
Are there two video adapters installed (one integrated and the other in the AGP slot?
Oct 14, 2009 | Dell OptiPlex GX270 PC Desktop
Optiplex gx270 freezes in upright position. purchased stand and now dell freezes during boot.
you might have something loose inside. have you opened it and checked for cables that might be rubbing against a fan or even a loose card in a slot.
Jul 20, 2009 | Dell OptiPlex GX270 Small Mini-Tower...
Multimedia audio controller missing
i have the problem with multimedia audio controller driver for dell optiplex GX270
Apr 22, 2008 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
141 people viewed this question
Alun Cox
