Question about JVC Audio Players & Recorders
Clicking noise on my sub? is the power board blown and the speaker??
Can i use another sub and connect to my jvc home theatre system
  • 43 Answers
SOURCE: home theatre sub
Sounds like a ground loop issue. Try plugging your sub, and the rest of your entertainment equipment into the same outlet with an extension strip (4 plug adaptor). If there is too much stuff to plug into one strip, experiment with combinations and hopefully you will find which piece of gear is the culprit.
Posted on Nov 27, 2007
  • 53 Answers
SOURCE: Noise comming from centre speaker of panasonic scpt560 home theatre system
check the cable 1st. If this speaker is powered, you could have a bad shield, or the power is causing a ground loop.
If the speaker is coming from an amp using speaker wire ie: 2 lead + - check the connection and make sure no fraid strands are touching each other on the rear connection.
In addition check your TV, Ap, And speaker system (if sub is powered independently) are all on the same curcuit.
a certain cause for ground looping resulting in hum.
Posted on Jun 24, 2008
  • 3 Answers
SOURCE: have an existing ts-1100 home theatre infinity speakers
You cannot use this system with one that does not have a Subwoofer or LFE (Low Frequency Effect) output. Unfortunately, this sub doesn't have a line-level (speaker wire) input. Sorry.
Posted on Feb 14, 2009
  • 153 Answers
SOURCE: sub goes full blown loud when plugged in to wall
It sounds like a power supply failure. It needs to go to a repair shop.
Posted on May 05, 2009
  • 6 Answers
SOURCE: can i connect JVC SXXSW6000 home theatre to my pc...if so how?
You need a receiver. A surround sound receiver is a 5-channel amplifier with a line-level subwoofer out. These are available at electronics stores. Receivers usually have digital inputs like optical and coaxial that you can use with the S/PDIF output of your PC.
Posted on Jun 16, 2009
Hello Guys,Can you please help? can I replace the sub woofer on my sony home theatre system DAV-DZ231 with a Celestion sub woofer s10
Presumably, the Celestion subwoofer is self-powered in which case it would connect to an RCA subwoofer output on your Sony system if there is one.
Oct 30, 2014 | Audio Players & Recorders
My bass powered subwoofer on JVC system doesn't turn on
You need to check the signal. If there is not signal present or the volume is low the sub will not turn on and goes in to sleep mode.
-david
Nov 09, 2010 | JVC THC3 800 Watt 5-Disc DVD Home Theatre...
Sound does not come out of home theatre system
Check for power to the Home Theatre system. If you have lights on the front of the system, check your connections to the external speakers. Next check the output settings in your TV's setting menu. More info from you regarding this problem would have been helpful. I'm guessing your thoroughness is probably going to turn out to be a contributing factor.
Apr 21, 2009 | JVC Audio Players & Recorders
Have an existing ts-1100 home theatre infinity speakers
Nov 20, 2008 | Infinity TSS-1100 System
I am missing some parts
Jvc home theatre system cable that connects the the bub and the dvd
Jul 04, 2008 | JVC TH-M606 System
Jun 24, 2008 | Audio Players & Recorders
I have no sound coming from home theatre system
I would check see if you can hear any hissing coming from the speakers if there's no sound then check to see if this product has output protection fuses and if so see if they are in tact if this doesn't solve the problem you may have dead outputs. If there is hissing coming from the speakers check your audio source to make sure it is feeding sound to your amplifier without looking its hard to say in these case's there's a lot to go wrong
Nov 26, 2007 | Wave Audio CS801 Speaker
Home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Oct 04, 2007 | Sony DAV-C700 System
Installation Help
This means that you have purchased a three piece home theatre system. Two tweeters and a sub-woofer. Assuming you are using a Stereo player (Tape/CD/DVC)you have to connect the Left Output of the Stereo placer to the Left Input at the back of the Sub-Woofer and the Right output to the Right input of the subwoofer by cables. Then take tweeters and connect them to Right speaker and Left speaker output at the back of the sub-woofer ( note if the speakers are marked L/R, then connect them to the subwoofer output accordingly. In case you are using a 5.1 player, then only connect the front right and front left to the Right and Left input at the back of the subwoofer. You are and you can now start playing your music or movies and and you will get theatre quality sound.
Aug 22, 2007 | KLH (AT2100) System
24 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
