Question about Philips Televison & Video
Philips vardan zappa kit no sound eht on then automatic eht off
Switch on set on, no sound eht on few second then automatic eht off thats problem solve this. plese help me
3 Suggested Answers
  • 188 Answers
SOURCE: philips 21rf vardan tv
Check option code's.
Posted on Jul 29, 2009
  • 3 Answers
SOURCE: sound is not coming but picture is ok in philips
sound is not coming but picture is ok in philips 21 RF vardan tv
Posted on Jan 13, 2010
No sound fault inPhilips 21rf vardan tv
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 27, 2015 | Philips Televison & Video
Sony Trinitron XBR 36 in (TV control on Top Middle of set) (set-up / tv/video / vol / channel / power) when set is powered on the standby/stereo light Continuous blinks red once a second, no pausing -...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is exactly as you have described .....after few seconds picture comes slowly & immediately (after few seconds). it gets off only red light blinks............ .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore ..since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally .....GUARANTEE....... vishnuswamy_4.jpg
Jul 24, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sound is not coming but picture is ok in philips 21 RF vardan tv
Dec 16, 2009 | Philips 32PW6506 32" TV
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Philips 27PT6441/37
There is a install kit 483531057673 for this model when the set is dead. The kit will contain 7404 and the Horizontal Driver Transformer 5402 along with resistors that will limit stress on 7404 and includes complete instructions
May 03, 2008 | Philips 27PT6441 27" TV
TV PROBLEM
IN MY 230 CHANNEL TOSHIBA KIT WHEN IT IS ON THE 110 VOLTS IS OK. BUT AFTER FEW SECONDS ITS 110 VOLTS BECOME ABOUT 91 VOLTS.WHEN THE VERTICAL SUPPLY RESISTANCE FROM THE EHT,THE VOLTAGE BECOME 110 VOLTS.EHT AND TDA 7698 ARE OK.
Sep 23, 2007 | Televison & Video
WILL NOT POWER ON
isolate power from hor.output section. if voltage becomes normal 130v &it does not drop then power supply is ok. now check hor output for leaky compnents near eht specially capacitor & diode. check hor output tr. at last eht. you can clean print near eht.
Sep 10, 2007 | Sanyo DS24424 24" TV
Televison & Video Logo
56 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
