Sharp silver magic washing machine
Esag1151f
What does Chrono 30 and mAgic 40 stand for
These are names used by Whirlpool for wash programs. Magic 40 is a 1 hour program which washes at 40 degrees, 3-4 Kg of fabrics, for heavy duty cleaning.
Chrono 30 is a short 30 minute program for lightly soiled or dusty clothes.
These seem to occur in Whirlpool machines sold in France.
Jun 02, 2016 | Washing Machines
Magic Chef Washing machine does not spin.
Sorry this is the best i can come up with.
National Service Center
Toll Free Number:
1-888-775-0202
No doubt they could tell you about service center locations and phone number.
Jan 11, 2013 | Washing Machines
The door gasket on my LG Tromm WM2377CS washer always has water trapped in it. The three tiny drain holes have been getting more and more clogged with "gunk". How to get the drain holes cleaned...
I use nylon cable (zip) ties to clean them. (Not sharp, so no danger of poking holes in the gasket) You may want to run a washer cleaner through the machine occasionally, such as Affresh or Washer Magic, or one made by Tide or Clorox.
Jul 23, 2011 | LG WM-2277HW Front Load Washer
Waher works fine but when it gets to the spin cycle it starts making a horrendous noise like a bearing or something
the most common probelm is the drain pump. tilt the machine back so you can see underneath then grab the belt and push or pull it by hand and you should here the grinding noise you may aslo be able to see a silver ribbed disc stick up from the drain pump touching the bottom of the washer replace the drain pump
Aug 25, 2010 | Magic Chef CAV2000AWW Top Load Washer
Magic Jack
They are lying to you. It won't work reliably. All fax machines are Analog. magic Jack is Digital.
Apr 20, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
MAGIC CHEF WASHER WONT SPIN OUT
underneath the washer is a pully assembly kit . remove the belt ,the c clip and replace the pully kit about $ 20.00 cost for parts.
Feb 02, 2010 | Magic Chef CAV4000AWW Top Load Washer
My washing machine drains but does not spin
Look for a motor belt that is worn out and make sure that the drum turns freely (machine off).
Aug 01, 2009 | Magic Chef CAV2000AWW Top Load Washer
Magic Singalong Song Chips - question please
Not exactly, magic sing comes in different models with different song chip. Old magic sings uses Black with metal song chip, Black song chips, Silver song chips and Gray song chips.
For your Magic sing II (I believed it has four song chips slot) the compatible song chip is the Silver song chip.
Oct 26, 2008 | Magic Sing Along Consumer Microphone
Maytag MAF1200AAW
WASHER MAGIC is the revolutionary product specifically formulated to safely and effectively clean the family washing machine. Top loading machine use whole bottle. Front loading use 1/2 bottle. You may rub Washer Magic on with a rag to eliminate odors.
Why Use WASHER MAGIC? Every time you wash your clothes, hard water and detergents causes lime scale and rust to build up inside the tub, pump and hoses. This build-up reduces the ability of your washing machine to perform. Mineral build-up acts as an abrasive increasing the wear on your clothes. The result: your clothes are not as clean as they could be and wear out sooner.
If you are unhappy with the way your clothes comes out of the wash, then WASHER MAGIC may be the solution you have been looking for. Only WASHER MAGIC can restore the family washing machine to the way it performed when it was new. Use once a month for optimal washer performance and to keep control of trouble causing build-up.
Aug 04, 2008 | Washing Machines
Magic Deluxe
Yes, The only thing the filter in the water tank if that is the filter you are talking about is just improve water taste quallity. If you are talking about the filter in the brew unit then no do not use it without the silver filter(s) in place.
Aug 11, 2007 | Saeco Magic De Luxe Espresso Machine
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
