Question about Konica Minolta Bizhub 223 Copier
Paper not picking up in document feeder bizhub 223
4 Suggested Answers
  • 1297 Answers
SOURCE: konica Minolta bizhub 250 jammed but no paper
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Posted on Jul 31, 2009
SOURCE: Top ADF will not recognize paper in the feed tray.
Try to replace the 'paper is present' sensor with the 'cover open' one to see if now it is detecting the paper. Also, check the actuator that enter in that sensor.
Posted on Aug 23, 2009
SOURCE: Bizhub C650 (Minolta printer, copier)
I usually go into service mode change the setting from table 2 to table 1 that solves the problem
Posted on Oct 22, 2012
Hi, Bizhub c450: i have a problem on scanning over the rear tray if i put paper inside message will appears close section properly but there is no other error code appearing on the screen.
When you say the rear tray what do you mean, ON the document feeder tray or raising the document feeder up placing the document on the big glass. Never heard of a rear tray?????
Feb 04, 2015 | Konica Minolta bizhub C450P Laser Printer
Document feeder pulls multiple pages
Sir/Mam,
Mite want to have the rollers cleaned. use a damp rag and soap and water. The separation pad mite need replacement. that's the device below the paper.in the document feeder. where the paper goes in.
Feb 24, 2014 | Konica Minolta Bizhub C253 With Document...
KONICA BIZHUB C250 DOCUMENT FEEDER PRINTING ON ANGLE
Clean the feeder paper feed,separator roller with cloth and alcohol.
Feb 01, 2013 | Konica Minolta bizhub Office Equipment &...
Display remove paper from document feeder but there is no paper on it
Then a sensor is dirty with paper dust, yes paper has dust! Check the cover that opens on ADF. and also check the under the ADF. along the white strip that covers the small glass area. Also check the acturator that hangs down and goes up when the paper is placed in the document feeder (ADF) normally it should be handing down
Oct 22, 2012 | Minolta Di3510f Bizhub Copier
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Konica Minolta bizhub 250 jammed but no paper
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Jam in the document feeder
get rid of that hp piece o crust. demand your money back.
Mar 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Document feeder
Does the adf show a paper jam? If so remove it or look for some thing blocking the paper path and remove it. Also try to turn off the copier and disreconnect the doc feeder and turn it back on and see what happens.
Feb 19, 2008 | Minolta Di3510f Bizhub Copier
Konica Minolta Bizhub 223 Copier Logo
50 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
