Question about GE WDSR2080D Top Load Washer
GE Washing Machine
I have a GE Profile Top loader that continues to have deposits of a hard gritty substance ( I dont think it is soap cause I dont use powder and it definitely doesnt smell like soap) that seems to build up underneath the spinner. Does anyone know how to take the spinner off so I can clean it out? Or a resolution on how to stop this?
  • Lisa Mills Jul 16, 2007
    Yes the agitator...(blonde girl). I have a stainless tub, so it probably wont work right?
  • speedywink Mar 15, 2009
    GE WCSR2080B2 Top Load Washer will not drain
    How do I get to the pump?
    Novelist:
  • 159 Answers
I dont kow what you mean about a spinner? If your talking about the part in the middle thats caled a agitator. If your washer is the model with the plastic tub the agitator pulls up from the bottom. And I have to tell you it is not a easy thing to pull out. The hard gritty substance could be from your water. You might want to have your water checked. Hope this helps you.
Posted on Jul 13, 2007
SOURCE:
How to remove ge profile top loader washing machine motor
how old is this washer i have worked on the older ones if you can send me a pic i can advise you mate
Feb 11, 2015 | GE Washing Machines
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
WM2277HS front loader , the drawer to put the detergent in is stuck, how do I get it open?
I have slightly different model. Tried the remove the top option. It turned out the the drawer assembly had removable top, removed to two screws that held the assembly in place, uncliped e front assymply drawer handle and cleaned out the soap deposits. Soap build up under dispenser parts had caused the problem. It seems like running the machine a few times might have cleared the soap.
Mar 14, 2011 | LG WM2277HSW XL Front Load Stackable...
I bought the Samsung 8 kg Top Loader (Model: WA80V3WIP) a few weeks ago. I only use cold water and bought the yellow packet of Sunlight washing powder, which specifically says on the packet that it works...
As with any top-loader, the soap drawer will deposit the entire soap load on one spot within the first few seconds of water fill. When the water starts running through the soap drawer, the brakes on the drum are released, so you can manually rotate the drum to disperse the soap over the load surface, thus eliminating the concentrated spots. Also, you may save the duvet, as the white marks are most probably dried soap powder which can be removed with a damp cloth wiped over the area.
Oct 19, 2010 | Samsung SW62ASP Top Load Washer
GE Profile Washing Machine wont fill with water top loader
disconnect water lines from washer and check to see if sedement from water plugged up little screen filters
Jun 11, 2009 | GE Profile WPRE6100G Top Load Washer
Brown dirt-like looking "gunk" coming out of the washer
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Jan 10, 2009 | Kenmore 44832 Front Load Washer
White lines
we have a zanussi and it does the same we have also cleaned the drum and the draq and swapped to liquid but it still does it.
Our machine is also 2yrs old.
Sorry I dont have an answer but wanted you to know it is not isolated to AEG
Jun 10, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Front loading washing machines
not really front loaders have top loaders beat all the way but stay away from admiral and maytag .a front loader will wash your clothes using the soap that your top load failed to get out if i may suggest buy a frigidaire with a mechanical timer not electronic control more junk on them more to fail the best combo in my mind is a frigidaire front loader and whirlpool dryer front loaders use 2/3 less water 2/3 less soap and will get your clothes twice as clean they have no transmissions and are direct drive the most common promblems with them is having to clean out the pumps where people leave stuff in their pockets also you need to buy soap thats for front loaders its called high effincey or he soap and they will get your clothes make sure you read the installation guide and remove ALL the shipping braces
Mar 18, 2008 | Admiral AW22 Top Load Washer
GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Jan 29, 2008 | GE Profile Prodigy WPSE4200A
GE WDSR2080D Top Load Washer Logo
210 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
