I have checked all 6 AA batteries and they are all good. I insert into D80 camera and I get off 3-4 shots before the camera window shows that there is zero battery capacity.
SOURCE: My Nikon D200 refused to turn on!
Afraid bad news is correct, it sounds like main control board.... You will need to get a quote from your local Nikon Service Agent..... Good Luck
SOURCE: The batteries provide little to no power to my L20
Change the batteries go with rechargeable, high-capacity NiMH batteries for regular shooting, but in case of an emergency you always carry a spare set of hybrid NiMH or disposable lithium batteries with you, in case the rechargeable poop out in the middle of a shooting session. For other batteries the life is short in camera.
Follow the tips to increase the battery life:
1.Do not use continuous focus when not necessary.
2.Minimize photo previewing.
3.Turn off LCD, when not in use.
Hope this helps.
Shane
SOURCE: The camera goes through the motions of taking a
Several can be the causes of this failure:
SD Connector faulty or defective solder pin in the connector.
Faulty memory compressor circuit in togo board.
Bring your camera to Nikon service best solution.
same problem here.. any solution?
