Question about Cameras
Remove lenscap error fuji s4400 - Cameras
Changed memory card in S4400 from 8GB (4) to 64GB SDXC (10) camera accepts but amount of time for video has not increased. Why?
Your camera can work with the SDXC cards perfectly. But keep in mind that the one movie can't be bigger than 2 GByte or 29 minutes. The maximum size of a file can be 2 GB in your camera and 29 minutes is probably to avoid overheating the sensor. Some modern DSLR's only can shoot for 8 minutes for that reason. But after some rest you again can start a new movie and later put them together with software on your computer.
This is what the manual form your camera says about size of a video.
Jun 19, 2014 | Fujifilm FinePix S4400 Digital Camera,...
Protected memory card comes on screen unable to take pics
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 21, 2014 | Fujifilm FinePix S4400 Digital Camera,...
Memory card
Card protection on display all time
Dec 29, 2013 | Fujifilm FinePix S4400 Digital Camera,...
Shaking camera symbol with exclaimation point icon won't go away?
Manual says slow shutter speed. You can adjust this by going to "S" on the dial. However it could also be that your ISO setting is too high therefore restricting shutter speed. Set ISO to 400 auto - a good all round setting.
Feb 10, 2013 | Fujifilm FinePix S4400 Digital Camera,...
How do you change the date on a fuji s4400
Press the MENU/OK button. Press cursor-left then select the wrench icon. Press cursor-right, then use cursor-up/down to select the clock icon. See page 14 of this manual.
Dec 29, 2012 | FUJIFILM FinePix XP10 XP11 Digital Camera
Resetting date on Fujifilm S4400
If you cant find date on Menu would reset camera setting to Default and start all over.
Sep 20, 2012 | Fujifilm FinePix S4400 Digital Camera,...
Cameras Logo
20 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
