Question about Samsung LN46A530 46 in. LCD HDTV
After replacing all capacitors on the power supply board,Tv still doesn't come on
    Genius:
  • Samsung Master
  • 2,432 Answers
If only a blinking indicator at the tv panel that was mean has an error detected by the main board. if no any power indicator then you have been already replaced bulging capacitors but still won't turn on. at this time you will need to have voltage checking using a digital tester, if their is an output voltages at the power supply board.
Posted on Jan 18, 2013
  • 927 Answers
SOURCE: Samsung model LNT5271f excessive relay cycling before full power
Howdy,
Yes, it is very easy to repair. Solder iron wattage should be at least 300 w.
The PSB is the center Board (towards left) after you remove the back off the TV. Remove the shield that covers the Boards and remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Good Luck, big IRISH.
Posted on Dec 28, 2009
Testimonial: "Great fix"
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
rustym62
  • 201 Answers
SOURCE: What are the locations for the capacitors on the
Hi, This link takes you to a online store selling this ps and has a photo there you can enlarge.Samsung PS If you need to identify a capacitor they are the metal cylinders in the pic. If you are wanting to repair you can look on the side of each cap there are 2 #s you need 1 is its value in microfarads example 1000 mf and 2 is its working voltage example 10v. The value must remain the same but you can go higher (and should) on the working voltage. Bad caps will be swollen or rounded on top, good ones are flat. Good luck.
Posted on Feb 13, 2010
  • 8457 Answers
SOURCE: My samsung hl56a650 tv power cycled and then
Likely the whole power supply board it is shot,dying capacitors alone will not emmtting smoke out of the tv.
Posted on Jan 10, 2011
Testimonial: "Thanks a lot for your answers."
budmrtn
  • 11361 Answers
SOURCE: Samsung power supply & IP board BN44-00264B &
Please see here:
http://www.shopjimmy.com/samsung-bn44-00264b-power-supply.htm
You have verify the LCD panel.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 01, 2011
Screen Philips 17 inches LCD doesn't react. Power LED stays off.
Check the tv power supply board,that board where the power a/c cord plug into it.Most common problems on these power supply board are dying and leakages capacitors components parts.Check the power supply board carefully,if u have dying or leakages capacitors parts,these capacitors parts will bulges ups,will not have a flat cylinder heads like the rest of the other capacitors coponents parts.Replaces all these dying and leakages capacitors parts with the same Miro fared and the voltages little higher like 5 to 10 volts higher,the power supply board should not have this problem again.U have all equipments to do basic soldering works and u understand basic electronic wright?Then u should have no problems by replacing all of these dying and leakages capacitors parts that are bulges ups onto it cylinder heads on the power supply board.If u can't do this,tries websites like Shopjimmy.com,eBay.com to by a whole new refurbish power supply board for the replacement.
Aug 22, 2012 | Computers & Internet
It doesn't turn on
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will solve the problem.......
Jun 13, 2011 | Televison & Video
HI I have a 32"
first, make sure the TV is correctly plugged into the wall. You can try another outlet. If that doesn't work, then your TV is certainly having a power problem.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on......
All these can be checked on the power supply board.......
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes).
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.......
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
Yours sincerely.
Elect_Comp.
May 16, 2011 | JVC AV-32850 TV
The plasma flat screen 55 inc tv just makes a clicking sound. no picture.
first, make sure the Tv is correctly plugged into the wall. You can try another outlet. If that doesn't work, then your Tv is certainly having a power problem.
Yours sincerely.
Elect_Comp.
May 15, 2011 | Televison & Video
Tv turn off now it won't turn back on
Yours sincerely.
Elect_Comp.
Tv wont turn on
Yours sincerely.
Elect_Comp.
May 14, 2011 | Sampo PME-42S7 42 in. Plasma EDTV
Plugged in my tv. It popped and now won't turn on. Is it the power supply or an issue I can fix easily
Yours sincerely.
Elect_Comp.
May 14, 2011 | Philips Televison & Video
My Toshiba Regza flat screen has no power. Power board?
Yours sincerely.
Elect_Comp.
May 13, 2011 | Toshiba Televison & Video
Tv was playing and went off like the plug was pulled
Yours sincerely.
Elect_Comp.
May 13, 2011 | Televison & Video
The red led on the front of the unit flashes. unit will not turn on and led doesn't turn green. is this a power supply issue?
The power supply board of the Television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.....
May 06, 2011 | Akai LCT3201AD 32 in. LCD Television
Samsung LN46A530 46 in. LCD HDTV Logo
228 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
