Question about Maytag Gemini MGT8655X 30" Freestanding Double-Oven Gas Range with 4 Sealed Burners, 3.9 cu. ft. Lower Oven, Self-Cleaning, Precision Cooking System, Power Cook Burner and 2.1 cu. ft. Upper Oven
Broiler shuts off
The broiler will run for about 10 seconds, then the flames go out. When restarting the broiler, it continuously shuts off after about 10 seconds.
    President:
  • 2,976 Answers
Make sure you keep the oven door OPEN when using the broiler, otherwise the thermostat will shut it off.
Posted on Jan 18, 2013
I HAVE AN OLD BLACK AND DECKER 300 QUICK AND EASY IRON. DOES IT CONTAIN MERCURY?
I just looked up the manual. Unfortunately the best way to find out is to contact B&D.
This is from a recycling website.
Purpose of the Mercury: The reason that mercury tilt switches were widely used in irons and other appliances was because of the conductive and liquid-like properties of mercury. In a mercury tilt switch, as the switch is "tilted" the mercury flows with the switch to complete the circuit by conducting electricity and turning the appliance on or off. In irons the mercury switch controls an electronic shut-off timer, constantly resetting the timer when the iron is in motion. If a person leaves the iron turned on and motionless, the automatic shut-off timer turns the iron off after a certain amount of time, reducing the risk of a fire. If an iron falls, this feature will also prevent it from continuing to release heat potentially causing a burn or fire.
Potential Hazards: As long as the iron remains intact, there is a low probability that there would be a mercury release.
Recycling/Disposal: There is no easy way to identify whether or not an iron contains a mercury tilt switch. However, if the iron is more than 10 years old and it contains an automatic shut-off, consumers should assume that it contains a mercury switch and dispose of it properly.
Unfortunately, they keep referring to 10 years old, but it doesn't say when this information was written up. If it was written in say 2006, then it would be referring to 20 year old irons.
Jul 28, 2016 | Irons
Shark g1468 auto shut off (iron won't come/stay on)
First let me say I HATE AUTO SHUT OFF!!! It sounds like it has wore out. the computer part that tells it when to shut off it not working. It would be cheaper to buy a new one vs fixing yours. If I were you, find an older iron that has LOTS of steam vents and NO AUTO SHUTOFF at your local goodwill, thrift store or garage sale.
Jan 06, 2014 | Shark Euro Pro GI468-FS Rapido...
My Oreck cordless steam iron keeps shutting off. I press the reset button but stays on only seconds
It sounds like the battery system on it is dead. there is no way to replace it and there are no replacement parts for it. the best way, if you liked the iron is to purchase an new one. they run anywhere from 39.95 to 49.95 brand new
Sep 11, 2011 | Oreck Cordless Speed JP8100CA Iron
Iron with auto shut off will not restart, why?
The thermostat is the problem, I used aew3656's solution posted elsewhere, and took care of the same problem on my steamer, just take out the damaged thermostat and use it as a sample to get a new one from any electronics supply store, BTW dont forget to buy thermal grease, it helps dissipate the heat so your steamer won't overheat, and the thermostat wont't go off every 2mins.
May 25, 2010 | Homedics PS-200 Iron with Auto Shut-off
My iron shuts off when I am continuously ironing.
The flashing is a indication that somthing is failing.. More than likely it is a internal component..
It might be most efficent to get a new one..
Or bring it back if it is under warranty..
Good luck..
Sep 23, 2009 | Hamilton Beach 14977 Iron with Auto...
Shark GI495N cord sparked and burst into flame
shark website for instructions and number
May 07, 2009 | Euro-Pro Shark GI490 Iron
The black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Mar 16, 2009 | Black & Decker ICR200 Iron with Auto...
I'm having a problem with the auto shut off of my sunbeam 421A series iron. The iron works great until the auto shut off comes on and the red light starts blinking. I understand that the iron should...
Unless you have a 5 or 6 hundred dollar iron, or unless it is brand new, and still under warranty, there is an excellent rule of thumb when an iron quits working: Buy a new one! These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Sep 21, 2008 | Sunbeam 4214 Iron
Turns off after 10-15 seconds. Shake and it comes on briefly
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Jun 21, 2008 | Rowenta Professional DX8800 Iron
Steam Question
Found the answer. The steam button is built into the handle. Push the button and you have steam.
Feb 27, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
Maytag Gemini MGT8655X 30" Freestanding Double-Oven Gas Range with 4 Sealed Burners, 3.9 cu. ft. Lower Oven, Self-Cleaning, Precision Cooking System, Power Cook Burner and 2.1 cu. ft. Upper Oven Logo
105 people viewed this question
Top Maytag Irons Experts
Are you a Maytag Iron Expert? Answer questions, earn points and help others
