Epson workforce 545 is printing & coping blank
  • 32,281 Answers
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Posted on Jan 18, 2013
3 Suggested Answers
  • 213 Answers
SOURCE: I just replaced my ink
Try "Nozzle cleaning" and if the problem persist, try "Deep nozzle cleaning". Try them only once or else the ink will run out very quickly.
If the ink cartridges are not genuine Epson, remove them and buy genuine cartridges. If needed, repeat the procedure with them.
Non-original consumables very often clog the printhead.
Posted on Aug 07, 2010
  • 1575 Answers
SOURCE: Epson R265 - prints blank (new inks & paper loaded)
Check the cartridges installations and make sure they're well installed.
Make sure the plastic tab around the new cartridges is completely removed.
Disconnect the printer completely and re-connect after a while.
Turn it off and on.
Problem solved?
Uninstall and install the printer again.
Hope this helps.Thanks!
Posted on Nov 14, 2011
Epson workforce 325 printing blank with black ink
The print head is plugged up. Try the nozzle check function or the clean function on the control panel.
Oct 07, 2016 | Epson WorkForce 325 Inkjet Multifunction...
Problem with printing, no ink on paper
The print heads are clogged or you are out of ink. Try the steps in the link (Epson support page).
Epson WorkForce WF 2530 All in One Printer
Apr 06, 2016 | Epson WorkForce WF-2530 All-in-One...
Leaving a space when printing
there is always 3mm margin in all sides of paper. Its Normal & you can not remove them.
If there is more than 3 mm than you should use nuzzle check.
Mar 28, 2015 | Epson Workforce 545 Wireless All In One...
Epson workforce 635 scan/copy/print has blank spaces
I am going to take a different approach - it sounds like U might have to do a printhead cleaning - go into the menu on the printer and look for Ink or Maintenance and the use the arrow keys to get U to printhead cleaning and try that and see if it solves your problem
Oct 27, 2014 | Epson WorkForce 635 AllInOne InkJet...
Why does epson workforce 635 print emails in red
Hi Sal Lentz, try this:
1. Copy the message to word pad and print, if ok.
2. Check the printer properties from your web page.
Aug 21, 2014 | Office Equipment & Supplies
Workforce 545 's ink pad is at the end of service life
As this remains unanswered but still picking up hits the Workforce 545 is basically the same design as the Epson BX525WD which is supported by a Printer Potty SoloLX kit for which installation is covered in this link
Instructions for installing waste kit on BX535WS
The error itself won't be resolved unless you find suitable reset utility such as the WICReset utility although this is a pay-per-reset solution. You can get both waste kit and reset bundled up if you want or you can go DIY to figure your own fix...
Nov 05, 2013 | Epson WorkForce 545 Wireless All-In-One...
Loaded new ink cartridges. Levels read full. Made 6 Nozzles checks. Levels showed practically empty. Paid $75 for 6 checks?
if it isnt putting out any ink and seems like it should work. then 90% of the time it means its just fine. no matter how many times you check it. youd know if you made all the ink leak out. if your unsure then id say compare weight against an old ink cartrage of the same type. there will be a diffrence. also if its not printing correctly it means that you just need to run a good 30 to 50 papers through with just that ink color and clean the hell out of the ink cartriges like 5 to ten times and wait till that color ink starts showing up. i just had to do this with a black ink cartriage.
Sep 20, 2012 | Epson WorkForce 545 All-in-One Printer
My epson workforce 600 is printing blank pages
Do a nozzle check and see what comes out.It should be under a maintenance tab on the front control panel LCD.If nothing comes out it more than likely has not been used in awhile and the head needs cleaning.If this is the case and you get it to print again do a sample page at least once a week to stop this from occurring again.
Jun 19, 2009 | Epson WorkForce 600 All-In-One InkJet...
Open Questions:
236 people viewed this question
k24674
