Question about Superior Jawbone Era Headset
Jawbone era sees pc and starts to pair but reports bad PIN
Why won't my Jawbone ERA pair with my Asus P8z67 Deluze mother board with built-in bluetooth?
Jawbone won't pair with iphone
Hi, you need to plug the jawbone to a computer in order to connect it for the first time to your phone, it can also be an issue with your phone bluetooth, restart might solve it.
Feb 17, 2014 | Apple iPhone Cell Phones
How to pair an aliph jawbone to my phone
turn the bluetooth option on from your evo and make sure that the bluetooth is discoverable and that press & hold down the power button on the jawbone bluetooth till you see lights blinking red & blue or its blinking red only on some jawbones , that check your phone , it should show u a jawbone bluetooth discovered on device than hit connect or pair , enter 4 zeros (0000) to connect & you should be able to use it like a champ , good luck , thank me if i help out on you Question
Feb 02, 2012 | HTC EVO 4G Sprint - /
How do i pair my jawbone bluetooth headset to my envy touch?
I found this on another website and it worked for me.
"I was also having a lot of difficulty getting my Jawbone II or "new Jawbone" into pairing mode. I finally ended up carefully removing the outer plastic shield. It popped off without breaking anything and then I was able to easily press BOTH the noise shield button AND the talk button. With the plastic cover OFF, I was able to put my Jawbone into pairing mode on the FIRST TRY!"
Jan 19, 2011 | LG enV Touch VX11000 Cell Phone
Have a jawbone bluetooth ear piece trying to pair it with a blackberry cant remember how to pair it
I have two jawbone headsets and they won't pair with our blackberry phones. Can you help me
May 20, 2010 | Cell Phones
My Jawbone headset will not pair with the iphone 3g, even after going to settings-general-bluetooth. The iphone keeps serching for a device but cannot find it.
1. Settings
2. Bluetooth
3. Turn Bluetooth ON
4. Make sure your Jawbone is OFF
5. Press TOP Of Jawbone & MIDDLE of Jawbone TOGETHER Until It Flashes Red & White
6. JAWBONE Will Come Up On The iPhone
7. Pir The Device With iPhone
8. Enter Four Digit Code
9. 0000
10 HEY PRESTO....YOUR PAIRED!!!!
Thanks to Sally Jo for this tip!
Dec 31, 2009 | Apple iPhone 3G
I have a jawbone bluetoothe and i want to program it to my cell phone
The instruction that come with the Jawbone don't give exact instructions for making it go into pairing mode AFTER it's done it the first time... here is the way to do it on a new phone:
Summary
New Jawbone pairing troubleshooting
You can view this answer at
http://aliph.custhelp.com/cgi-bin/aliph.cfg/php/enduser/std_adp.php?p_faqid=96
Jul 31, 2009 | Cell Phones
Cannot pair lg voyager with jawbone bluetooth.
Mine wouldn't pair either so I went to the jawbone site and I did this and it worked the first time.
For Jawbone ICON, while the power is off, press and hold down the Talk button and slide the power switch on. When the LED starts to flash red and white alternately, release the Talk button.
1. Press the OK Key.
2. Highlight SETTINGS & TOOLS and press the OK Key.
3. Select Bluetooth Menu.
4. Select Add New Device. (If Bluetooth power is set to off, you will be prompted to turn power on. Select Yes and press the OK key.)
5. Highlight Jawbone and press the OK Key.
Enter the PIN "0000" (be sure to enter four zeroes and not the letter "O") and press the OK Key.
Mar 22, 2009 | LG VOYAGER VX10000 Cellular Phone
I purchased a aliph jawbone 2 from all4cellular.com for $69.95 and it won't pair up with my treo 755p. It's not my phone because I can pair up with my wifes Motorola headset. I even tried my coworkers...
Palm Treo 755p
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Feb 21, 2009 | Palm Treo 755p Smartphone
My Treo 755p will recognizes my new jawbone but will not connect. It seems to skip the step where I am supposed to enter a password into to connect to the jawbone. Any ideas? Josh
Delete any other bluetooth devices paired to your phone. Then, for the Palm Treo 755p . . .
Jan 26, 2009 | Palm Treo 755p Smartphone
Jawbone bluetooth does not charge
My jawbone was not charging at all, but then I looked at the prongs on the charger and I saw that one of them was shorter than the others, so I got a pair of small needle nose pliers and gently pulled on it. It returned to its normal length and I plugged it up. It is now charging normally.
Jawbone should design a better charging system.
Dec 14, 2008 | Cell Phones
Superior Jawbone Era Headset Logo
22 people viewed this question
Top Superior Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Superior Radio Communication Expert? Answer questions, earn points and help others
