Question about Brother Mfc-j835dw All-in-one Wireless Color Inkjet Printer
Brother printer j835dwwill not connect to my Comcast modem
It will not connect to the router and my other room. I had a gateway router and modem, I had alarm system put in and when they change my router. My printer when not hook up?
4 Suggested Answers
mikaljalil
  • 15 Answers
SOURCE: share printer
First you have to set up a home network between both your computers, once that is established run an networking cable to your printer it should all be ran through a networking hub so all machines can communicate with one another
Posted on Jul 05, 2008
  • 5 Answers
SOURCE: Can not connect to personal Wi-Fi network
This instruction is to setup Brother Laser printer 2170W in windows 7
Turn off Windows Firewall
To reset the printer:
Turn off the printer.
Press and hold the Go Button in front, at the same time turn on the printer from the right side. You will see three lights(Error, Drum, Toner) turn on. Release the Go button. The light is not blue and is off.
Now, Press the Go button 7 times. Wait for some seconds.
The three lights will turn on and off by themselves. The printer warms up and then stops.
Connect the ethernet cable to the wireless router and the printer
in the browser type:
http://192.168.1.1
It shows the device connected and its ip address.
Close the browser and open new browser
on your internet browser type in http://(ip address that you see as device)
click on "Network configuration"
user: admin
Password: access
click on "configure interface". Change it to "Auto Switching" Click OK
You are back in "Network configuration"
click on Configure wireless
Make sure it is "Infrastructure" and the "channel" is correct.
Also "Authentization Method" should be "open system"
Choose your encryption method
type in your password in "hexadecimal format" and click "submit".
If your password is ascii change it to hexadecimal with an online converter
Follow the instructions.
Wait until it prints the papers.
When it tells you to remove the ethernet cable, Do not remove.
Wait until printing is done. Turn off the printer and remove the cable. Turn on printer.
Now Print the printer status:
click on the Go button once to wake up the printer.
Now click on the Go button 3 times. Wait! it will print 4 pages.
Look at the last page
you will see the IP address of the printer.
go to your browser and type in http://( new ip address that you see on last page)
The last step is again in the "configure wireless" to "configure TCP/IP"
choose something like 192.168.1.198 the last 3 digits should be a high number. Close browser.
Now put in the CD and install the wireless Driver only. All Done!
Turn ON Windows Firewall
Posted on Jun 25, 2010
SOURCE: BROTHER MFC-6490CW won't connect to wireless router
have you found a solution? I just purchased brother wireless printer, same thing, called and they said it must be my router. I haven't had a chance to play with it as much as you have, but before I do was wondering if you found a way to make it work yet?
Posted on Jul 20, 2010
Connecting MacBook or NetGear Router to Comcast
As a Comcast tech I assure you there are no special protocols used on a standard residential installation. There should have been nothing the tech downloaded to your pc most especially an executable file. I would assume he or she was making sure you were able to get to the customer installation page before they left. However if you have a router that the ports are not functioning on you are most welcome to have one shipped to your home for replacement. The wifi key provided on the bottom of the router is case sensitive most generally all in caps. If you dont have a spare cat5/6 cord to see if thats the issue ask them to send one with the new modem. Comcast does not charge you a fee for a truck roll when its faulty eqt. of their own. I have installed hundreds of apple products including the ones you are referring to as well as netgear routers they all work with the gateway Comcast provides the customer. Now if you want there is a tiny factory reset pin button at the very top of the gateway in the back you will need a paper clip to push it in. Hold it in there about 10-15 seconds and the gateway will reboot and return its setting to factory spec. try that first before calling customer service.
Jan 07, 2013 | Comcast XFINITY
For diagnostic purpases I need to obtain the IP adrress of my Zoom 5241 cable modem. My Asus router IP is 192.168.1.1. I recently purchased this modem to save rental fees on the modem that Comcast...
Just use command prompt, at the 1st moment when you connect your router, no matter LAN, USB or wireless/blue tooth or even HDSPA modems connection it will assign itself a port on your machine, to check what ip adress your Zoom 5241 cable modem got, go to Start, then run then type CMD for command prompt screen and in the console, type ipconfig/all on list you will find your router, simply find "default gateway" part and use that local adress xxx.xxx.xyz.xyz.
Please rate my solution :)
Apr 13, 2011 | Computers & Internet
HP laserjet 2015dn IP address problem
please do not assign dynamic IP on the network printer. give a static IP on it base on your network config. and also, please do assign all you computers on the network with static IP's so that every time they boot there will be no IP conflict or problem on the network connection.
Mar 05, 2010 | HP LaserJet P2015dn Printer
Moved router to connect directly to the Comcast modem that also provides VOIP. Comcast activated modem and internet works when computer is connected directly to Comcast modem. Router does not connect to...
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
How can I my up my comcast netgear modems wireless to work? when I try my PS3 it detects a sginal but wont obtain an IP address. The same with my lap top.
You have to change the ipddress on the router different then the modem. For example 192.168.9.1 and leave the modems ip alone. Plug the cable into the Lan port of the router. Go to the setup screen on the router and tell give your username and password that
Comcast gives you. You will need comcast gateway address and dns numbers. There will be a connect button on the router and tell it connect it to the modem. You are trying to let the router receive that only ip address.
Nov 09, 2009 | NetGear CG814M Wireless Cable Modem...
I have comcast and i purchased the surfboard so that i could play use the internet for my xbox in my room. There is another modem on rent from comcast a touchstone telephony modem which provides internet...
u need a router to share internet connection, not 2 modems, from the way your explaining it im going to assume you just bought the modem went home and plugged it up, Well.. thats not going to work , your modem needs to be registered with the network your trying to access(comcast)
Jul 13, 2009 | Arris SURFboard SB5120 Modem
Became new customer to comcast-got the bundle package, internet,phone,cable. Voice overlay modem to accomodate internet and phone lines. Did not use their wireless router-using exsiting router D-Link model...
Hi jad123,
I am sorry to learn about the problems you are experiencing with your service.
I will be happy to reach out to my contacts to assist you in resolving this issue. Please feel free to contact me so that I can get more information from you.
Thanks in advance!
Mark C.
Comcast Executive Offices
We_Can_Help@cable.comcast.com
Apr 10, 2008 | Computers & Internet
Brother Mfc-j835dw All-in-one Wireless Color Inkjet Printer Logo
129 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
