Question about Fujitsu Siemens fi-5220C Flatbed Scanner
Failed to initiate archiving elements - Fujitsu Siemens fi-5220C Flatbed Scanner
WinRar Unexpected end of archive.
There are few reasons for gettingunexpected end of archive RARerror; you usually encounter this error when you start a downloading process and after downloading few GBs (gigabytes) or MBs (megabytes), it stops and displays a message as download complete.
Given below are the steps which might help you in recovering some files from your corrupted RAR archive:
·Download RAR Fix Toolbox software and install the software to your computer desktop/laptop
https://www.fixtoolbox.com/rarfix.html
·Launch the repair application and stick to the procedure
·Hit the "Browse" button to choose the RAR file which is to be repaired
·Initialize the repair process by clicking on "Repair" button
·The program starts the repair process
·Monitor the repair process via progress bar
·After finishing the repair process, the tool displays all the files and folders from the RAR file
·Click on "Next" button
·Finally, save the repaired files to your desired destination location by making use of "Save" option'
Oct 27, 2015 | RARLAB WinRAR
Coffee maker
This model of coffee maker has an adjustable heating element beneath the carafe - ensure the temperature setting for the carafe is high enough to keep the coffee hot.
If the coffee is not brewing hot, the initial heating element/coil may have failed. Removal of the heating element is somewhat problematic and will require disassembly of the water container and base of the coffeemaker, and will likely need to replace the heating coil contained in a plastic sheath. Ensure you take a look at: http://home.howstuffworks.com/coffee-maker2.htm
for further detail.
Apr 07, 2014 | Cuisinart Dcc-2600 14-Cup Coffee Maker
OD ERROR
Fatal error code 0D: No head error
A check of the print head thermistor circuit during power-on initialization determined that the PRINT HEAD is not installed. This error is caused by the following:
? The Print Head is not installed.
? The Print Head built-in thermistor element has failed.
? The Carrier Cable is disconnected or damaged.
? The Print Head temperature detection circuit has failed
Jun 07, 2011 | Epson DFX-9000 Matrix Printer
An internal error occurred in the initialization 502
When you get errors like that it is best to manually delete yahoo messenger and then redownload it. Here is the yahoo help page that goes through the steps to do this.http://help.yahoo.com/l/us/yahoo/messeng...
Be sure to back up your message archives if you archive your messages.
thanks
Jan 21, 2011 | Yahoo Messenger
Can't open outlook express
That's a well-discussed situation if you'd searched for answers much. Answers vary from reinstalling Outlook binaries to running cleanup utilities on the Outlook configuration files, mail archives, address archives, etc. depending on what BSOD you got (seriously, nothing but blue on the screen, no text?)
Backup your outlook address and startup files, and your data if you don't already back it up; then follow the instructions MSDN.com offer for Outlook Express initialization failing/hanging. That will produce a nicer result than just deleting your outlook.ini file. Microsoft like to make it do everything, but the cost is that there are now all these maintenance tools despite the fact that it's the Express (as in condensed) version.
Jun 11, 2010 | Dell Dimension 2400 PC Desktop
Internal error,failed to initialized HAL. i encountered this every time i boot up.i don't know how to fix.i cant play also videos,''cannot find codec matching selected-vo and video format 0x44495658''.by...
To solve Root Password problem :
Type
Sudo su -
then you need to change the password for root. do this by typing
passwd root
and then enter your password
Please check this Link : http://www.linux.com/archive/forums/topic/2539.
Hope this have helped you. Please rate if it helped. Thanks
Apr 17, 2010 | Acer Aspire One Netbook 8.9" Notebook
ADATA PD16 large archive copy/read ok but crc fails.
your a ***. lets not tooot are own horn to much. do you think you know a thing or two hahahaha
Jul 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My Garmin Colorado 300 is freezen
Better to update the colorado firmware to fix the certain problem on your unit.
Updates & Downloads Colorado 300 software version 2.90
Download (3.46 MB)
Installation Instructions
  1. Download the self-extracting archive file for your Colorado onto your hard drive.
  2. Connect your Colorado to a free USB port on your PC with the correct PC interface cable.
  3. Allow your Colorado to initialize and enter USB mode.
  4. Unzip the files in the archive by running the downloaded executable file.
  5. Follow the instructions provided by the launched update application on your computer.
Hope this initial info/idea helps.
Thank you for using fixya
Jun 07, 2009 | Garmin Colorado 300 Handheld GPS Receiver
HE tratado de instalar CALL OF DUTY , Y PIDE ARCHIVO OPENGL
you need to uninstall the game and reinstall and make sure your disk is clean i have had this myself
Nov 16, 2008 | Tablets & eReaders
",.exe" (comma.exe) causing a problem
Its your OS affected by virus..
Mar 04, 2008 | Computers & Internet
Fujitsu Siemens fi-5220C Flatbed Scanner Logo
348 people viewed this question
Top Fujitsu Siemens Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Fujitsu Siemens Office Equipment and Supply Expert? Answer questions, earn points and help others
