Question about Dell Xps 17 Laptop Computer (Intel Core i7 740QM 256GB8GB) (dndojm23) PC Notebook
Dell XPS 17, error code 2000-0146
When I run the diagnostic tests it fails immediately and shows this error code. I googled it and such and saw others had the same problem but they are unable to start their computers up. My laptop on the other hand starts up perfectly and the only problem with it is that when it idles for a few mins. (3-10) It blue screens and gives me the Kernel Data In-page Error. I've looked this up as well and I can not find a fix on it either. Is anyone capable of helping me out? Laptop: Dell XPS OS: Windows 8 Pro 64bit
Try running malwarebytes until it comes up clean like run it once twice so on so on until it finds notthing then try ur thing again if that does not help find out where ur memory chips are located and pull them out and put them back in one at a time like 1 turn the computer on try it and if that dont work turn off and try the other if thats not the case then morethan likely it is ur harddrive and u may need to factory restor ur unit but use that as a last option and back up all important files before u do if that dont work then it has to be that the hard drive is going bad or another part of hardware but i say more than likely it is a virus that has cruppeted some data in the software
Posted on Jan 18, 2013
3 Suggested Answers
SOURCE: Drive Smart Read Error / Kernel Data Inpage Error/1000-0143
have you restarted the PC? If you have and it works, then this error is NOT too much to worry about... As long as the drive is Booting for now you can copy off your files etc to say a USB drive... You do not need to copy the programs etc, usually you simply copy over your "My Documents" or "Users" directories. As all files saved are generally "Under" there if you have any, anywhere else of course you need to get them as well. Now the drive may NOT be totally "Ruined" it may simply require a Re-Format, and then replace the Operating System. After which you can restore your settings. Below is a Microsoft link that tells you how.www.microsoft.com › ... › Computer Setup and Maintenance -
Either with the "Old" drive or a "New" drive. set BIOS to boot from CD/DVD and put the Windows Install DVD in the drive, boot of this and follow instructions, when you come to the place to partition & Format, do this and do a full NTFS format... after which your system will be installed and you can load your drivers and programs again Also before doing all this go to the manufacturers web site and download ALL drivers for your model PC & Operating System. You need to do this so you can install the drivers for all your Video, Sound, WiFi network etc. after you install your operating System
Posted on Mar 08, 2010
bronk50
  • 27725 Answers
SOURCE: I have a dell vostro
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Posted on Feb 19, 2011
I have a drive error that diagnostics says is ref 200-0146 and extended diagnostics shows error code 0F00:1332 and a series of blocks with Interrupt Request not set in time. However most of the t
Barbara,
You will need to replace the hard drive, an error 0146 is a failed hard drive or bad drive sector.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 06, 2015 | Dell Studio Xps 8100 Desktop Computer
Dell error code 2000 0146
That Dell error code indicates a hard drive issue. The link below has some information about running Dell hard drive diagnostics which don't require being able to boot to Windows. (There are other ways to test the hard drive by booting with a Repair CD or other tools, but the Dell test should be sufficient.)
Jan 16, 2014 | Computers & Internet
Error code after running diagonistics
If you run Advanced System Care that will repair your errors, if repairable.
Looks like a fatal error though. Back up your data,NOW!
Nov 17, 2013 | Dell Xps 15 Laptop Computer (Intel CORE I5...
Error code 0147 spindle test failed
The error you received (2000:0147) indicates the drive has failed. It cannot be fixed. You need to replace the drive.
May 27, 2012 | Dell Studio Xps 8100 Desktop Computer
Error code 0141 internal hard drive not found
It can be a possible hardware issue or a software issue
Try to run the dell diagnostics
http://findtechhelp12.blogspot.com/2010/12/how-to-run-dell-diagnostics.html
If it fails replace the part on which it fails.. If it passes reinstall the OS to fix the issue
http://findtechhelp12.blogspot.com/2010/11/how-to-reinstall-os-in-dell-computer.html
Dec 20, 2010 | Dell XPS M1330 Notebook
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
I get the error code 2000-0146 only when i run the f12 diagnostic
The 2000-0146 error code indicates a read/write failure of the hard drive. There is at least 1 sector that is failing on the drive. While it is working at the moment, the drive is failing and will over time degrade and eventually fail completely. Backup any important data, then replace the drive.
Dec 11, 2009 | Dell Computers & Internet
Dell XPS One, Vista, Seagate Hard Drive failing?
go to pcpitstop.com and run full test. But it sounds like spyware to me.
Sep 15, 2009 | Dell XPS One Red Desktop Computer
My dell inspiron 1525 won't boot up
The hard drive could be failing. Try running the test this way.
First you'll have to power off the system.
You need to hold down the Fn button (Located next to the CTRL button on the left hand corner) and then power on the system. This will take the system to the diagnostics mode.
After running a series of tests you'll be prompted to "Press any key to boot to the diagnostics partitions". Now you'll get a prompt to test the computer. You need to select the option and run a CUSTOM TEST on the hard drive.
Write down any error codes listed and continue testing.
If you get any errors note then and contact technical support.
Aug 19, 2009 | Dell XPS M1530 Laptop
Dell Inspiron 1420 error code
You need to take it in for warranty service. The hard drive and possibly motherboard have failed.
Jun 16, 2008 | Computers & Internet
Dell Xps 17 Laptop Computer (Intel Core i7 740QM 256GB8GB) (dndojm23) PC Notebook Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
