Question about Dell PowerEdge 2950 (becwfk1_6) Server
Problem in reboot the server in domain
We are having one Poweredge 2950 dell server which is a part of domain. We are using Windows 2003 server OS. Now problem is, whenever we are trying to restart the server in LAN by using a static IP, server is hanged after boot the machine in "applying computer settings" stage. When we remove the lan cable it starts successfully but some progams are not working. And we can ping other PC from the sever but from other PC (Same domain) can not ping.
Kindly provide me the solution.
  • monoj_goswam Jan 27, 2009
    There is no IP conflict.
    Though there are 2 Network Interface card one card is totally disabled and another card is having static IP address.
We are having one server poweredge 2900 which was open and did some preventive maintenance for dust and other diet. But after the preventive maintenance, we try to switch on the server but the hard disk drives cannot display at the same time.
Posted on Mar 16, 2009
  • sidikikoroma Mar 16, 2009
    This message was displayed on my server poweredge 2900: foreign configuration found on adapter
  • 73 Answers
This sounds like a common DNS issue. You need to make sure that this server has a local DNS server like 192.168.1.1 and not an external one like 4.2.2.2.
Your server is trying to find the domain controller and with the external DNS it cannot. This is why when you remove the cable it loads correctly. it assumes that it is disconnected from the local network and it continues without the domain controller. otherwise it waits for the external dns to time out.
Posted on Feb 08, 2009
  • 46 Answers
Perhaps there is a IP conflict?
Why not set up DHCP with IP reservations for your servers? I have no idea how big your setup is. We have a few of these servers at my work and have experienced no problems.
Also i believe this server may have 2 network interface cards, make sure you have the IP set to the correct adapter, and dont plug them both in with the same IP address.
How long have you left the server at "applying computer settings" before plulling the network cable?
Posted on Jan 25, 2009
How do i reboot a dell server
That would depend mostly on the server. It is recommended to initate most shut downs via the installed OS. If that isn't possible then you can simply hold the power button to power down the servers.
Hope this helps.
Sep 28, 2014 | Dell PowerEdge 2950 (becwfk1_6) Server
How to use the smart start cd to install dell poweredge 2950
Smart Start is an HP utility. Dell has a similar one called Systems Build and Update Utility (SBUU) or Systems Management Tools and Documentation (SMTD - much larger download and includes SBUU).
You should use the DVD version if possible, and if you are installing 2003, it should have SP2. If it doesn't, then you can use nLiteOS.com to integrate the Service Pack into your installation media.
Aug 14, 2010 | Dell PowerEdge 2950 (becwfk1_6) Server
Problem rebooting Dell PowerEdge Server 2600
ERROR 02A2: BMC System Error Log (SEL) Full
press F1 to continue or F10 to enter BIOS.
I wait for 2 minutes without doing any thing my server get started normally.
Please help me how to stop this error
Feb 19, 2010 | Dell PowerEdge 2650 Server
Can I install sco open server 5.0.5 on poweredge server 2950 which is having PERC 6/1 raid controller
Hi ,
You can move a program from sco openserver 5.04 to newer platform it supports RAID controller.
Jan 27, 2010 | Dell PowerEdge 2550 Server
No video output
Turn off machine un plug all power cables.
To access the jumpers, remove the cooling shroud by lifting the release latch and sliding the shroud towards the front of the system
Lift up the memory module airflow shroud for easy access to the jumpers
This will rest the password and then you will be able to rest the server.
Hope this help you.
Nov 09, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
The Dell 2950 Server we have cannot reboot the disc drives
The raid may be fine you need to reinstall the OS.
The best way is to drop the raid array astablish a new raid array then install you new OS on a new raid array.Very nice server you have.
Oct 28, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
Windows - Delayed Write Failed
This points out to a problem with one of your hard drives. Run CHKDSK on all drives you have, & if any problems are detected on any drive, run CHKDSK /F on that drive.
Apr 04, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
Dell PowerEdge 2950 (becwfk1_6) Server Logo
824 people viewed this question
Alun Cox
