Where can I find a list of the different frequencies to input to my EZI30xlt ?
Like C F A etc
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Its not a radio
Posted on Jan 18, 2013
HOW DO I REPROGRAM PANASONIC TC-22LH30. BOUGHT IT USED AND WORKED GREAT ON CABLE. I WANT TO PROGRAM IT ON ANTENNA,
First... You need your working Remote
  • Input
    • TV
  • Now, Menu
  • Scroll to Program
  • Locate and choose from list "Antenna or Broadcast TV or Air or OTA". Different models vary
  • Then choose Scan for channels.
It's important that your antenna is hooked up correctly, and able to catch frequencies. Otherwise NO channels will be found.
Jun 13, 2015 | Panasonic Televison & Video
Date and time appears scanner doesn't scan
Hi June,
Has the radio scanner been programmed with frequencies?
If not, that is the answer to your query.
All radio scanners need input to function as they should, no input, FREQUENCIES, no go.
If you have the user manual handy, it will guide you through the steps required to program frequencies into your scanner.
If you don't have the manual, then going to your local Radioshack store would be of benefit to obtain a copy.
You will also need a hard copy of frequency listings for your location.
these can be found by a simple google search.
I hope this has been useful to you.
Cheers,
Peter
Feb 26, 2013 | Uniden BC370CRS Base Scanner
How do I program a yaesu ft-270?
I will be working from the online version of the manual located here. It may or may not be the same as your printed manual included with the radio - so you might want to download this copy.
First, let's set the radio to automatically set up repeater input shift based on the published receive frequency. By default, the 270R will transmit 600Hz up or down as determined by the band plan. This feature is called ARS and can be disabled if desired. If it does not display a frequency 600Hz up or down from the receive frequency while transmitting, is has been disabled. Let's re-enable it by performing steps #1 thru #5 on page 19 of the manual. Once completed, the 270R will automatically shift the transmit frequency (to match the repeater input frequency) as shown in the top half of the "ARS-Repeater Subbands" graphic at the bottom of page 19. The bottom half shows the export version of the shifts and does not apply to USA versions. If you have "odd splits" (repeaters that have input frequencies that are non-standard ie: other than 600Hz; or shift up instead of down and vise-versa) you'll need to manually change these later as described in VHO Split Mode on page 21. Any repeater operating on 147.000Mhz may have a shift either UP or DOWN. As you can see in the graphic, 147.000 is between the (-) and (+) shift so it could be either direction. Double check to make sure the radio matches the shift that the particular 147.000Mhz repeater you wish to access requires.
Next, create a list of repeaters that you wish to save in memory (you can check online databases to obtain the most recent information). This list should include Name, Receive Frequency, any non-standard direction or value Shift (called "odd splits), Tone Type and Tone. The name should be 6 or less alpha-numerics in length and be something that helps you identify it . This could be the name of the repeater owner: "TIM, PETE, etc. ", the name of the club that runs it: "BARC, CMARA, etc.", the city or town it is in: "BOSTON, OAKLND, etc,". You might run into names that would create duplicates when there are more than 1 repeaters there in the same location. Boston has several 2M repeaters - naming them BOSTN1, BOSTN2, etc. may help you remember them, but it will be easier still to append the decimal portion of the frequency to remember - such as in the case of a Boston repeater on say, 146.030Mhz and one on 145.150. BOS030 and BOS150 would probably be easier than trying to remember which is BOSTN1 and which is BOSTN2. Placing the names in the 270R memory is the last thing done, so don't worry too much about a name for the 270R's display just yet.
Most repeaters use CTCSS for access. Some newer repeaters use DCS. Some require or even prefer that no tone be sent at all. CTCSS is an analog frequency and a DCS code is digital data. The repeater may require one or the other to be present to "wake up" and begin retransmitting your message. All you really need to know about these two systems is the you need to match both the tone type and the tone value to successfully activate the repeater. Set the radio to your desired default power output level. Tap the VFO button once to enter VFO mode (if not already in VFO mode).
Enter the repeater's receive frequency by twisting of the tuning dial (page 13) or by direct entry (page 14) via the keypad. When using the keypad, do not enter the leading "1" of the frequency - as all the frequencies that this radio can tune begin with "1" and can not be changed. With the repeater frequency displayed, next enter the CTCSS tone for the repeater as described on page 23. If the repeater uses DCS, follow the directions that begin 1/3 of the way down on page 24 instead. As far as "TONE" and "TONE SQ" are concerned, the difference can best be described in that a radio working on a repeater system benefits from use of TONE, and a radio working on in simplex operation (no repeaters) benefits from the use of TONE SQ. Since we're programming repeater frequencies, there's no need to select TONE SQ. If the repeater strips the tone from its output, your radio will remain silent if set for TONE SQ. TONE is a much better match for our needs. Remember, you must use the DIAL to select the CTCSS tone frequency or DCS Code. Unlike the repeater receive frequency, it is not possible to directly enter the tone frequency or code via the keypad.
At this point, the radio should be displaying the recieve repeater frequency. Since automatic repeater offset is enabled - the 600Hz offset frequency and direction are set. The tone type and value for this repeater frequency have just been set in the previous paragraphs as well. Now it is time to write all this information to the radio's memory. This is detailed 1/3 of the way down on page 29 under "Memory Storage". Once you have performed step 5 in Memory Storage for this first repeater, it says to repeat this same process. This means setting the next repeater's recieve frequency, tone type and tone value - just as you have done with the first.
Once you have made sure that you have unique names assigned and the other information above, you are ready to begin adding them into the 270R's memory. You can go back add names to be displayed instead of the frequency of the repeaters if desired. Page 31 details the procedure to assign an alpha numeric name to each memory location. Make sure that you are assigning the correct alpha-numeric to the repeater by checking the frequency from time to time - don't blindly add alpha-numerics to memory channels.
This is a very tedious process. Ham Radio Outlet offers Windows programming software and transfer cable by Yaesu called "ADMS-270" for $38.95. This package allows you to easily create many lists of memories on your Windows PC & keyboard that can be uploaded and downloaded "on the fly" I highly recommend this software - or any software that allows you to program the radio from a computer rather than the radio itself.
I hope this was helpful.
Nov 29, 2012 | Yaesu Ft-270r Vhf Ft 270r Ft 270 R
Hello i have a yaesu ft-2900 it receives just fine but when i transmit it shows error. this radio is brandnew
Hi Gerald,
When you say you used the software to download frequencies, do you mean as in from the internet, or did you have to input frequencies via the software on your PC?
There is a difference, that's the reason I ask.
If, by using the software you manually input the frequencies, then did you input both the output and input frequencies or just output for each channel?
If the latter is true, and you are trying to access another user via a repeater, then that is the error.
Repeaters generally, require both the input frequency = the frequency you transmit on, and the output = the frequency you receive on.
Without both frequency pair, you won't be getting out, and no won can hear you, as you are basically transmitting as a simplex station on a repeater allocatted channel, hence the error message on your display.
The radio you have is used by many amateurs & CB operators, and both group utilise repeaters within their allocated spectrum, excluding 27 meg CB, which is simplex only, but with SSB included.
I hope this answers your query.
Best regards,
Peter
Nov 28, 2011 | Yaesu Radio Communications
I recently picked up an old Bearcat 18 channel scanner at a yard sale for $1. It works great and I was able to program it, but now I'm wondering if I programmed it correctly? It seems like sometimes I only...
Hi, You do NOT need to input the "INPUT" channel, as that is the low-powered frequency input to the high power repeater. You will only hear nearby units, and not the dispatcher or other further away units. You can however, sometimes hear more 'secret' info, but most of the time do not use the INPUT, only the repeater Output or FREQUENCY is just fine. A great deal for $1 - it eats up batteries pretty quick, so look for an AC adapter at a sale too! 73's from Ham John
Nov 04, 2009 | Radio Communications
Need cb channel frequencies 1 thu 40
Channel list.
There you will find a list of the citizens band frequencies.
Oct 21, 2009 | Ranger RCI-6900F-25 CB Radio
Hello, i just got my scanner working and need to know what everyone is talking about. How do I find all the codes for san joaquin count california? so, pd, fire, etc? thank you My scanner is not the one...
Congrats on entering the scanner world. Two different points of information you'll need:
1. Local municipal services' radio frequencies
2. Download a "10-code" definition list
If you google search San Joaquin County and "radio frequencies" you get a list of all the local radio frequencies that the local services in your area are broadcasting on. Then you can program them into your scanner... sorry if you already figured this part out..
Secondly, you can download a police call 10-code definition list and you be up and running. Print out your code list and you'll have alot of them memorized real quick. Also you'll get used to the local abbreviations being used in your area... for example in my area, "ECR" means El Camino Real.. a main street near here.
Have a blast..
Oct 17, 2009 | Radio Shack Pro-2096 Base Scanner
Trying to find codes
If you want police "ten codes" you can get a list online via a google search. IF you want radio frequencies for your local police, fire, ambulance etc, you can enter a google search for "radio frequencies" and the name of your county, state, city.. it will give you a list of frequencies ...print the list and then enter them into your scanner.
keep for reference..
k
Jul 03, 2009 | Uniden BC60XLT-1 Handheld Scanner
50Hz to 60Hz conversion
Hi, Your idea is basically sound and should work as long as the UPS originally is designed to produce 240V 60Hz and has its own built in timebase. The reason is that the input as long as the voltage matches makes no difference (50 or 60 Hz). By design, the UPS converts the input voltage to DC to charge the internal battery. The battery then powers an electronic circuitry that produces the 240V 60Hz. The input is then isolated from the output in terms of frequency. This is a common design, however, there are some (not many) that uses for its local oscillation sampling from the source and therefore will replicate the input frequency to its output, but very rare; it's better that you know they exist. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards. P.S. The only problem with 50 and 60 Hz is heat buildup which is tolerable and still within safe parameters. The only time the 50/60 HZ makes a big difference is when motors are used, timers such as in the early designs of microwave ovens, washing machines, etc., pumps and other highly inductive consumers. Most electronic devices converts the AC input to DC and therefore the frequency has negligible effect. Of course others may see it differently.
Sep 15, 2007 | Liebert UPStation GXT2700RT-208...
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
