Question about HP Compaq Presario CQ40-330TU
MY COMPAQ PRESARIO TURN OFF WITH A BLACK SCREEN WEN IT WAS NEARLY COMPLETTING DOING FACTORY RESTORE
  • HP Master
  • 7,627 Answers
If you can get it to boot change the power settings to high performance, sleep and hibernate to never and the screen saver to never.
Posted on Jan 18, 2013
SOURCE: screen is complete blackout when I turn on my hp compaq c6000
You either have a screen that has gone and needs to be replaced or a cheaper fix and usually a more likely one is that the inverter in the screen has gone out. The inverter is quite cheap, around $34.00. Try it
Posted on Dec 04, 2008
Dipu007
  • 2110 Answers
SOURCE: want to restore compaq presario to factory settings
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
this doc may help u ...
Posted on Dec 08, 2008
  • 55 Answers
SOURCE: how do i restore my compaq to factory settings
use recovery disk that came with computer
Posted on Mar 29, 2009
zohail
  • 1223 Answers
SOURCE: how can I restore to factory settings
Compaq/HP: When you first turn on the laptop and see the Compaq/HP logo screen, press the F11 key (you need to do this before the Compaq/HP logo disappears).
pls rate well
Posted on May 07, 2009
kamal1984
  • 1383 Answers
SOURCE: I have a Presario C500 Compaq laptop
when upower up press F8 key then enter in enable vga mode.
then set screeen resolution to 1024*768
and if u r not abled to login enable vga then enter in safe mode.
then go to start menu run then type in run "chkdsk /r"
thats it
then restart it then it fix error on hardddisk.
Posted on Jun 08, 2009
Half my screen doesnt work on my compaq presario. How can I do a factory restore if I cant see the screen and what option to click
I would definitely not try to do a factory restore without a full screen showing. Are you saying that the external monitor does not work for system restore?
amazon seems to have replacement LCD screens for $51.93
http://www.amazon.com/COMPAQ-PRESARIO-CQ57-229WM-SUBSTITUTE-REPLACEMENT/dp/B005IUFKKW
Sep 25, 2014 | HP Compaq Presario CQ57-229WM Notebook PC
How to find factory settings partition
While many problems can be solved by less drastic measures, Compaq owners sometimes need to restore their computers back to factory new condition.
If the operating system becomes corrupt, or if the computer is struck with a persistent virus, restoring the PC to its original factory default settings is often the best way to deal with the problem.
While older Compaqs relied on restore CDs to restore factory settings, newer machines come with a recovery partition built into the unit.
Shut down the Compaq computer and wait for it to power off.
Press the "Power" button to restart it.
Press the "F11" key as soon as you see a black screen.
This will boot the Compaq into the recovery partition.
Follow the on-screen instructions to back up any user files before the recovery process begins.
Click "Next" to start the recovery manager and follow the on-screen instructions.
Hope this helps.
Nov 29, 2012 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
How to reset compaq presario to factory settings keeps going to repair computer
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
or
If your Compaq Presario has major issues, restoring it to factory defaults may be the best course of action.
There are a number of situations when completely restoring a computer to its factory settings is the best solution, including resolving virus infections and corrupt operating system files.
Back up all of your user data to a USB thumb drive, external hard drive or other device.
The restore process will destroy all of your data, so this is vital to do.
Turn on your computer and open your CD or DVD drive.
Place the restore CD that came with your Presario into the drive and restart your PC. If you do not have a restore CD, you can contact Compaq to order one.
Allow the computer to boot up from the restore CD.
You will see a series of messages guiding you through the restoration process, as well as several warnings that all data on the computer will be erased.
Continue the restoration process, and follow the prompts as needed.
You may need to locate the license key for your version of Windows; that key should be located on a label on the top of the computer case.
Hope this helps
Nov 05, 2012 | Compaq Presario CQ60-220US PC Laptop
How do i reset my computer to factory settings. its a compaq presario f700
Hi!
To restore your Compaq Presario PC f700: Turn the computer on, then while restarting, Press and hold the F11 key. Under HP Recovery Manager, select the option to perform a system recovery. ***Note*** Doing this will delete everything that are save in your computer. Back up your files before doing this.
Hope this can help.
Jul 24, 2011 | Compaq Presario Notebook
Can i restore my compaq presario cq60 notebook to factory setting without cd ? its vista
hi.
there are two ways to completely restore settings of a computer:
1- enter Bios of your notebook (by pressing "delete" repeatedly") and select restore to manufacturer's settings.(or load from manufacture settings). THIS CAN RESTORE SETTINGS OF YOUR HARDWARE.
2- for restoring settings of Windows:
restart your notebook and before windows starts up (showing "windows starting") press F8 repeatedly.
then choose "load from last good configuration".
Jan 30, 2011 | Compaq Presario Notebook
Compaq Presario SR1000 won't boot up completely :(
Hi Thanks for your question
I would suggest to enter "safe mode" and then do system restore again. To do this you need to follow these steps.
1.Turn your PC on and press F8 on start up. This should take you to the screen asking what you want to do. 2. Choose safe mode from the list and press enter. 3. Once safe mode loads you should be asked if you want to restore your system to previous state. Just press no to run system restore and follow steps (you already know how to do this)
Shutting your computer down without closing operation system properly may cause start up issues like this one.
I hope this helps you. Good luck
May 26, 2010 | Compaq Presario SR1000T (568657) PC...
I need help resetting my computer to its factory default settings it is a compaq presario cq60-615dx
to reset your laptop, restart your computer and constantly press F11 once the first black screen on your laptop displays, or the Compaq logo display. Your computer will automatically load to recover manager and you can factory restore you computer from there.
2nd option: click start menu, click all programs and scroll to "Hp backup and recovery" or "Backup and recovery" click it and proceed for the factory default setting.
Good luck.
Apr 18, 2010 | Compaq Presario CQ60-220US PC Laptop
How can I restore to factory settings
pls rate well
May 07, 2009 | HP Compaq Presario V2000 Notebook
Looking for freeware
Compaq is not an operating system. However, if what you are looking for is to reset the OS, all you need to do is turn the computer off. When it comes back on and displays the splash screen (that's the screen that says "Compaq" on a black background, by the way), immediately hit F11, this will cause it to go into a program on all HP/Compaq computers that will give you the choice to either restore the computer to a previous date or you can do a complete OS reload. Should you choose to do a complete OS reload, you will then be asked whether or not you want to back up your files. I would do so because as soon as you hit the button to continue, everything on the computer will be erased and all the factory settings will be back to normal.
This is why HP/Compaq and other brands of computers don't come with a reload disc.
Apr 16, 2009 | Compaq Presario 2800CA PC Notebook
How do i Restore my Compaq Presario 1200 laptop to orginial store bought state?
You can restore your Laptop to Factory Setting by Tapping F11 at the startup which should bring the Recovery Screen. Follow the instructions to complete the Restore. If F11 does not work, you need to get Recovery CDs from HP.
Jun 07, 2008 | Compaq Computers & Internet
HP Compaq Presario CQ40-330TU Logo
71 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
