Water pump belt - Washing Machines
  • Washing Mach... Master
  • 17,130 Answers
Tips to Replace the belt. Click on Belt replacement
Posted on Jan 18, 2013
I need to know where to put the timing marks facing for alignment on a harmonica balancer
Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
For water pump replacement i suggest you to check the help link provided below.
click the link below :----
Water pump replacing procedure for all vehicles?
http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html
HOW TO REPLACE A WATER PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-water-pump.html
How to route Water Pump Belt for 1992 Oldsmobile ?
http://carbeltrouting.blogspot.com/2011/12/how-to-route-water-pump-belt-for-1992.html
How to replace Water Pump on Car ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-water-pump-on-acura-car.html
How to Remove Water Pump?
http://technoanswers.blogspot.com/2011/12/how-to-remove-water-pump-on-toyota.html
Where is Water Pump located ?
http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
This will help. Thanks.
Feb 14, 2012 | 1997 Nissan Pathfinder
Water pump 1990 oldsmobile 88 royale
For water pump replacement i suggest you to check the help link provided below.click the link below :----Water pump replacing procedure for all vehicles? http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html
---------HOW TO REPLACE A WATER PUMP
Where is Water Pump located ? http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
----------Below is the master help link provided to go through belt routing diagram:---Timing belt,drive belt,serpentine belt,accessory belt,fan belt,engine belt routing diagrams for all types of car models?
Click the link below :----http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help.Thanks.
Feb 14, 2012 | 1990 Oldsmobile Eighty Eight
How to route Water Pump Belt ?
Jan 26, 2012 | 1996 Isuzu Rodeo
How do i change a waterpump on a 2001Volkswagen cabrio?
Your Cabrio has one of several 2.0L Volkswagen engines - determine your engine type from the
8th digit of your VIN, which will be either an "A", or "C",both are 2.0L engines.
Volkswagen 2.0L engines offered in 2001:
(a) 2.0L (Aba) Engine
(b) 2.0L (Aeg/Avh/Azg/Bdc/Bev/Bgd) Engine
(c) 2.0L (Aeg/Avh/Azg/Bdf) Engine
For completeness, I've included the water pump maintenance manual entries for all (3) 2.0L VW
engines offered in 2001. Note that the instructions below include (3) illustrations, which are
reproduced faithfully from the manual, but the last (2) illustrations are identical, since the last two
engines in the list above are virtually identical.
Volkswagen 2001 engines - water pump replacement
2.0L (Aba) Engine
Before servicing the vehicle, refer to the Precautions section.
Remove or disconnect:
1. Coolant
2. Thermostat housing from under the water pump housing.
Loosen but don't remove the bolts holding the pulley to the water pump.
Timing belt cover.
Alternator and/or steering pump as required to remove the water pump drive belt.
Water pump pulley. On some vehicles, the crankshaft pulley must also be removed by removing the bolts holding the pulley to the timing belt sprocket.
Water pump from its housing.
To install:
Be sure to clean the housing before installing the new gasket. Install the pump into the housing. Pump-to-housing bolts: 84 inch lbs. (10 Nm).
Install the water pump drive pulley. Bolts: 15 ft. lbs. (20 Nm). Install crankshaft drive pulley. Bolts: 15 ft. lbs. (20 Nm).
Adjust drive belt tension and install the thermostat and housing. Bolts: 84 inch lbs. (10 Nm).
Fig. Water pump and thermostat housing-2.0L (ABA) engine
1. Before servicing the vehicle, refer to the Precautions Section.
2. Remove or disconnect:
Coolant
3. Loosen but don't remove the bolts holding the pulley to the water pump.
4. Remove or disconnect:
Timing belt cover.
Water pump from its housing. Refer to figure of ABA engine's water pump above.
To install:
1. Be sure to clean the housing before installing the new gasket. Install the pump into the housing. Pump-to-housing bolts: 84 inch lbs. (10 Nm).
2. Install the water pump drive pulley. Bolts: 15 ft. lbs. (20 Nm). Install crankshaft drive pulley. Bolts: 15 ft. lbs. (20 Nm).
3. Adjust drive belt tension and install the thermostat and housing. Bolts: 84 inch lbs. (10 Nm).
Negative battery cable.
Coolant.
Accessory drive belt and tensioner.
Upper and center timing belt covers.
3. Position the engine so that the No. 1 cylinder is at TDC.
WARNING
Cover the timing belt to protect it from being contaminated with coolant.
4. Loosen the timing belt tension and slide the belt off the water pump sprocket.
5. Remove or disconnect:
Timing belt guard (2) mounting bolt (1), if equipped.
Water pump mounting bolts (5), then the water pump (4).
O-ring (3) and clean the seating area.
To install:
Fig. Exploded view of the water pump mounting-2.0L (AEG/AVH/AZG/BDF) engine
1. Install or connect:
O-ring, moistened with coolant.
Water pump so that the plug in the housing faces downward. Mounting bolts: 11 ft. lbs. (15 Nm).
Timing belt guard, if equipped. Mounting bolt: 15 ft. lbs. (20 Nm).
Timing belt.
Accessory drive belt tensioner. Mounting bolt: 18 ft. lbs. (25 Nm).
Accessory drive belt.
Coolant.
2. Check and clear any DTCs, then match the ECM to the TCM.
1. Before servicing the vehicle, refer to the Precautions section.
1. Negative battery cable.
2. Coolant.
3. Accessory drive belt and tensioner.
4. Upper and center timing belt covers.
WARNING
1. Timing belt guard (2) mounting bolt (1).
2. Water pump mounting bolts (5), then the water pump (4).
3. O-ring (3) and clean the seating area.
To install:
Install or connect:
1. O-ring, moistened with coolant.
2. Water pump so that the plug in the housing faces downward. Mounting bolts: 11 ft. lbs. (15 Nm).
3. Timing belt guard. Mounting bolt: 15 ft. lbs. (20 Nm).
4. Timing belt.
5. Upper and center timing belt covers.
6. Accessory drive belt tensioner. Mounting bolt: 18 ft. lbs. (25 Nm).
7. Accessory drive belt.
8. Coolant.
9. Negative battery cable.
Sep 13, 2011 | 2001 Volkswagen Cabrio
How to change the water pump on a 2006 equinox ls
  1. Drain the cooling system until the coolant is below the level of the water pump.
  2. Loosen the water pump pulley bolts.
  3. Rotate the drive belt tensioner to release the tension on the drive belt.
  4. Remove the drive belt from the right idler pulley.
  5. Carefully release the drive belt tensioner spring tension.
  6. Remove the water pump pulley bolts.
  7. Remove the water pump pulley.
  8. Remove the water pump bolts.
  9. Remove the water pump.
  10. Remove the water pump gasket.
  11. Clean the water pump mating surfaces.
To install:
Fig. Remove the mounting bolts (3) to remove the water pump (1) and gasket (2).
  1. Install the water pump gasket (2).
  2. Install the water pump (1).
  3. Install the water pump bolts (3). Tighten the bolts to 10 Nm (89 inch lbs.).
  4. Install the water pump pulley. Loosely install the pulley bolts.
  5. Insure the drive belt is properly centered on all the pulleys except the right idler puller.
  6. Rotate the drive belt tensioner away from the drive belt.
  7. Install the drive belt to the right idler pulley.
  8. Release the tensioner allowing the drive belt tensioner to come in contact with the drive belt.
  9. Inspect the drive belt to insure the belt is properly centered on all the pulleys.
  10. Tighten the water pump pulley bolts. Tighten the bolts to 25 Nm (18 ft. lbs.).
  11. Fill the cooling system.
  12. Inspect the cooling system for leaks.
Aug 21, 2011 | 2006 Chevrolet Equinox
How can you tell if your water pump is even working
Water pumps FYI
A belt drives your water pump, most are the same belts that turn your altenator and air compressor. Some water pumps are turned by the timing belt. But if you can see that your belt is working the water pump, altenator and compressor, its working. If you had a water pump powered by a timing belt, you would not be able to start your car if that belt stoped.
Water pumps never stop working, they are direct shaft driven.
The only thing is they do start to leak after they get older, then need replacing.
Apr 15, 2011 | Kia Sportage Cars & Trucks
Do you have to change the water pump when changing the timing belt/timing?
You don't have too, but not bad idea, the timing belt drives the water pump, if you just replace timing belt, and not water pump, water pump could go out and mess up the timing belt, now it has to be done all over again, timing belt, water pump and labor.
Sep 16, 2010 | 1996 Subaru Legacy
How to take off the water punp
1. Drain the cooling system until the coolant is below the level of the water pump. 2. Remove the drive belt guard. 3. Loosen the water pump pulley bolts. 4. Remove the drive belt. 5. Remove the water pump pulley bolts. 6. Remove the water pump pulley. 7. Remove the water pump bolts. 8. Remove the water pump. 9. Remove the water pump gasket. 10. Clean the water pump mating surfaces. Installation Procedure 1. Install the water pump gasket. 2. Install the water pump Notice: Refer to Fastener Notice in Service Precautions. 3. Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.). 4. Install the water pump pulley. 5. Install the water pump pulley bolts. 6. Install the drive belt. Tighten the water pump pulley bolts to 25 Nm (18 inch lbs.). 7. Install the drive belt guard. 8. Fill the cooling system
Aug 13, 2010 | 2002 Buick LeSabre
Remove and replace the water pump buick rendezvou 2003 cost and do it yourself instructions . can i do it myself concerned with loosening the serpentine belt and needing special tools?
Visit my Blog here
Jul 21, 2010 | 2002 Buick Rendezvous
How do I change a water pump on a 2004 kia sorento?
Kia Sorento 2003-05
Water Pump - Removal & Installation
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Drain the cooling system.
  3. Disconnect the negative battery cable.
  4. Remove the drive belt and the water pump pulley.
  5. Remove the timing belt cover, timing belt, auto tensioner and idler pulley.
  6. Remove the water outlet fitting, the thermostat case and the water pump fitting.
  7. Remove the water pump mounting bolts.
    Fig. Water pump and timing belt assembly-exploded view
To install:
Fig. Water pump bolt locations
  1. Clean the gasket surfaces of the water pump body and the cylinder block.
  2. Install the new water pump gasket and pump assembly. Tighten the bolts to 12-16 ft. lbs. (17-22 Nm).
  3. Install the water pump fitting, the thermostat case and the water outlet fitting.
  4. Install the auto tensioner and timing belt. Adjust the timing belt tension, then install the timing belt cover.
  5. Install the drive belt, water pump pulley and then adjust the auto tensioner.
  6. Refill the coolant.
  7. Run the engine and check for leaks.
To install:
Fig. Water pump O-ring installation
  6. To adjust the drive belt tension, hang the belt on the pulley of the tensioner and install the tensioner.
    NOTE If the tensioner is already installed, loosen its mounting bolts to allow belt installation
  7. Install the drive belt.
  8. Adjust the belt tension to specification by turning the adjusting bolt clockwise or counterclockwise.
  9. Air conditioning belt tension should be 0.28-0.039 inch. Alternator belt tension should be 0.39-0.051 inch. Power steering belt tension should be 0.31-0.051 inch.
  10. Torque the tensioner assembly bolt to 33-36 ft. lbs. (45-50 Nm).
  11. Refill the coolant.
  12. Run the engine and check for leaks.
TY for using Fixya; remember comment and rated this.
Apr 01, 2010 | 2004 Kia Sorento
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
