Question about Toshiba LX815-D1210 AIO Desktop Computer
I have a Toshiba LX815 and i would like to install a VGA port so i can add another monitor. Can anyone help me out with finding the parts i need. I would also like to install on HDMI port.
Adding a VGA port to my All-In-One Desktop. Also adding a HDMI port. Would like help finding where I can find the parts to order.
IrishDruid
  • 2712 Answers
SOURCE: adding bluetooth to toshiba laptop
Well,I'm not really an expert on Bluetooth, but let me try...
Which version of Windows are you running? If you have Windows XP SP2 or above, the Microsoft Bluetooth stack should be installed on your system. First make sure that the Kensington bluetooth adapter is compatible with the printer and the OS. From what I heard Canon sell a separate Bluetooth adapter for about $80 for this, but I'm not too sure.
Secondly, ensure that the built-in Bluetooth Stack or Software has the required Profile for your printer.
Next, put your printer in "discover" mode (see printer manual for more info ). Use the Bluetooth Connection Utility software that came with the built-in Bluetooth stack to "discover" the printer. Follow the instructions by the Bluetooth stack manufacturer on how to pair and connect Bluetooth devices to your built-in Bluetooth stack.
Please also see THIS article. although it is meant for the Logitech DeNovo keyboard, it can be used for any Bluetooth enabled devices. (Just replace the DeNovo wit your printer in the article.
But mainly, make sure that the Kensington adapter is compatible...
Hope that helps..
IrishDruid
Posted on May 04, 2008
mankou
  • 55 Answers
SOURCE: toshiba VGA
مرحبا :
You may find the definition screen here Kart
Posted on Aug 26, 2008
sidewind69
  • 13 Answers
SOURCE: adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Posted on Jan 26, 2009
    techresolve
    • 109 Answers
    SOURCE: Toshiba M2 missing drivers
    http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=411405&rpn=PSA10U&modelFilter=A15-S127&selCategory=3&selFamily=1073768663
    follow the link and download the required driver from there
    Posted on Apr 15, 2010
    Testimonial: "many thanks, much appreciated! :) "
    TechGaurav
    • 64 Answers
    SOURCE: toshiba L355-S7905 does not want to connect to tv
    First without connecting the external Monitor/TV Go to display properties and Lower down resolution then when you connect the TV press and hold the Fn key on the left bottom of keyboard between Ctrl and Alt and while holding FN ket down press Change monitor button ( Normally F5)( must be having 2 monitor kind of image printed on any of the function key) once then twice or thrice to shift between different options like display output on one monitor, 2 monitor, extended display etc.
    Posted on May 24, 2010
    How to add a 2nd monitor
    Most laptops have a VGA port so an external monitor can be added. Then you might have to press a Fn key combination to get the other monitor to display.
    If you want to add a second monitor to a Desktop computer, you'll need to install another graphics card. A USB adapter card is available; do a search for different models available.
    If neither of these answer your question, please explain exactly what you need a monitor to display from; you posted to the Network and Wireless Adapters section, which is confusing..
    Mar 06, 2016 | Computers & Internet
    How do I connect a external monitor to my toshiba P55T-B5262 laptop
    Ok I looked at the Specs on the laptop --- you have a HDMI port --- Same thing found on almost all tv's now days
    -you need a HDMI to VGA or an HDMI to DVI converter --- very inexpensive purchase
    Options #1
    If the monitor you are trying to has this port:
    -then you need a HDMI to VGA adapter
    http://www.ebay.com/itm/like/350902230382?lpid=82
    Options #2
    -then you need a HDMI to DVI cable
    http://www.ebay.com/itm/HDMI-to-DVI-D-24-1-Pin-Monitor-Display-Adapter-Cable-Male-Male-HD-HDTV-6-FT-/141210464113
    Hope this Helps!
    Sep 06, 2014 | Toshiba Satellite Computers & Internet
    Toshiba bios settings
    You may get away with a USB to Com converter from flea bay.
    Jan 31, 2014 | Computers & Internet
    Any way to hook up my monitor to my Pc? It appears the laptop has a mini VGA port, but my monitor only has the regular size VGA port.
    At the store they have adapters you can buy. WHen you get that just connect the mini part to the laptop and add the attachment and connect it to your monitor.
    Oct 28, 2013 | HP Computers & Internet
    Toshiba satellite C855D-S5105 HDMI
    For the Toshiba Satellite C855D-S5105, HDMI is an option.
    If present, believe it to be on the Left side, same as the VGA port.
    [General example of VGA connector (Port), and VGA Cable,
    http://en.wikipedia.org/wiki/VGA_Connector
    Note* Color is not always Blue. Scroll down a little for VGA Cable example ]
    User Manual states plug external monitor device into laptop, then turn external monitor device on.
    External monitor device should automatically be seen by laptop.
    If not press, and hold down on the Fn key, and at the same time, tap on the F4 key until the display option you want is shown. Then press the Enter key.
    Touchscreen?
    That requires a knowledge of Windows 8, which I do not have a full understanding of yet. The User Interface of Windows 8.
    It isn't stated by Toshiba, (At least that I could find), as to if the HDMI port; is just that. An HDMI port, or a Mini-Port HDMI port,
    http://en.wikipedia.org/wiki/File:HDMI_Connector.jpg
    There are HDMI adapters, and HDMI cables; that adapt from regular HDMI to Mini-Port HDMI.
    There are adapters that connect to a VGA port, and convert to an HDMI port.
    Not the answers you are seeking? Please reply in a Comment.
    For additional questions please post in a Comment.
    Regards,
    joecoolvette
    Apr 12, 2013 | Toshiba Computers & Internet
    I need to connect a VGA dell monitor my Toshiba Laptop
    HDMI is digital
    VGA (the 15 pin connector) is analog.
    If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
    Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
    I have also seen some work if a 2-step connector is used.
    VGA to DVI connector, followed by DVI to HDMI connector.
    DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
    YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
    Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
    Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
    I HAVE A LG Full HD 1080p HDMI W2753V-PF 27-inch i was told my my tech that the monitor needs an inverter...Where can i get one and what is the part number ..if anyone could help me...
    Well, you monitor has several input interfaces/connectors like;
    • D-Sub (Vga connector)
    • DVI
    • HDMI
    If you are connecting this monitor to a computer, then you can use the Vga cable which came with the package. You can see the Vga cable here.. 3d8a2c8.jpg
    You have to plug in either the terminal to the computer Vga port as shown below; 876c259.jpg
    If in case you want better video quality and you don't have hdmi or dvi port
    Dvi Port and Connector;
    Hdmi Port
    cables (these are available in most retailer stores)
    It is not important to connect or purchase additional converter/hardware to connect you computer to the monitor, if you don't like the vga, you can simply get those cables.
    I you let me know the Video card of your computer, I can help you better and shortened all these, but never mind, just refer to the pictures above and let me know if you can't make sure of yourself.
    Good luck.
    Thanks for using FixYa.
    Jun 23, 2010 | Computers & Internet
    External monitor connection problem
    The problem is with the laptop. The femal VGA port is slodered to the motherboard. Once the laptop's MB has been removed you'll most likely find the solder holding the VGA in place is most likely cracked/loose. The fix would be to remove the old solider & apply new.
    I can't guide you through disemble, its complex. I can include a site to help you with this.
    http://www.laptopka.com/2006/03/18/removing-laptop-motherboard/
    http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
    If you find this all a little too involved it might be worth taking it to a pro.
    At this link you can order A105 parts if needed.
    http://www.sparepartswarehouse.com/Toshiba,Satellite,A105,PSAA2U-01T018,Laptop,Parts.aspx
    I hope this helps you kevinwaynewh!
    Mike
    Jan 29, 2009 | Toshiba VGA Board Graphic Card
    Enabling VGA Port
    To use VGA port on your laptop, you have to press the FN key and the corresponding key to switch the output to the vga port (usually F4, but could be something else, look on your F keys and see shich one has a picture of a monitor on it).
    Jun 26, 2008 | Computers & Internet
    How do I connect my Laptop computer to my LCD TV?
    Every laptop has at least a VGA (computer video connection) and s-video cable port. A VGA cable is preferred if you want to be able to read text on your LCD TV. Check to make sure that your LCD TV has a VGA connector. It's a port that accepts a 15-pin connection so it's pretty easy to spot if it's there. It's just like a computer monitor cable if that helps. Should be able to find it at any local retail store that carries computers. VGA or RGB cable.
    Apr 12, 2008 | Computers & Internet
    Toshiba LX815-D1210 AIO Desktop Computer Logo
    29 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
