I just installed a new Reznor Udap100 and it's making loud vibration noise when starting up and shutting down...when its running for a minute or so the sound goes away. It's new and I was won
Unit is making loud noise on shut down and start up...put runs quiet once it's been on for about 40 seconds. It's brand new, and the noise only happens when it first starts up..and when the system is cycling off.
KOakaKO
  • 135 Answers
SOURCE: "Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Posted on Aug 04, 2007
22yooper
  • 828 Answers
SOURCE: Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
Posted on May 16, 2008
  • 230 Answers
SOURCE: Brand new right out of box Everstar MPK-10CR-1 portable 10,000 BTU's
It sounds to me like it is overheating. Make sure that all of the literature that came with the unit is accounted for. Many times the manual or instructions are blocking the exhaust causing it to overheat. If this is not the problem then I would suggest exchanging it for a new one. It may be a manufacturer defect.
Posted on Jun 27, 2008
thaurfen
  • 623 Answers
SOURCE: Clunking noise when compressor shuts off
the technician was right....thank you!!!
Posted on Aug 06, 2008
meBNme
  • 334 Answers
SOURCE: HEATER MAKING LOUD NOISES
Check the draft inducer motor for any partial blockages or dibri.
I've seen sticks, birds nest particles and pieces of deteriorating fan blades (squirrel cage type fans) cause this.
You might also find that the inducer motors bearing are going.
If its a loud vibrating grinding type noise, I'd suspect bearings or missing pieces of the blades. (unbalanced)
If it's a clanking type noise I'd suspect loose items hitting the fan.
The inducer motor will only operate right before and during burner operation, while the blower motor can operate at any time depending on your setting.
Posted on Dec 06, 2008
My fridge started getting really loud when it cycles on, and seems to have a vibration when running
If it ismaking a steady noise, the motor that runs the defrost timer may be making noise. I f the timer motor is making a loud noise, then you should replace the timer.Vibration noises are often caused by dishes or containers vibrate on a shelf inside.
Sep 16, 2013 | Refrigerators
Lound vibration when running
Check gas control valve.
Good luck,
Marty
Feb 18, 2013 | Rinnai Water Heaters
My Sears Mod. #919.155730 ran for 2 mins. (cold 40*) made loud noise, then started vibrating bad, and stopped building up pressure. Intake is sucking air, but coming out of the little valve oppsite si
pull the heads and check for failed reed/poppet valves
check for a blocked non-return valve at the tank indicates a blockage between the compressor pistons and the receiver tank
Jun 21, 2017 | Craftsman Air Tools & Compressors
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
DRYER STARTS BUT IMMEDIATELY SHUTS OFF
If you are having the same problem I had, the motor gets hot and shuts off. My motor was making a fairly loud noise when I cut it on. It would run for a minute or two and then shut off. I had to replace the motor. Motors are fairly cheap and not that hard to install. I paid $50 for a new one on ebay including shipping.
Jul 18, 2009 | Kenmore 63942 Dryer
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
My r85 rinnai water heater vibrates significantly and makes
Sounds like there is something loose in the line.Like cut off valve,check valve.
Mar 09, 2009 | Rinnai Digital Remote Water Heater Control...
Dec 06, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
