Question about Rubbermaid Reveal Spray Mop Kit, FG1M1600GRYRD
I bought a rubbermaid reveal mopping system.and I dropped the mop while using and the bottle fell out, the cleaning solution gurgled all over the floor, and now the cap is stuck inside the mop. Can anybody help me think of a way to get it out without damaging the unit?
    President:
  • 2,976 Answers
Try using a pair of needle nosed pliers, in reverse. Put the tips into the cap and SPREAD the handles. The jaws MIGHT provide enough grab to back the cap out. Otherwise, it will be a try this and try that job. No two are ever alike.
Posted on Jan 18, 2013
I have a Rubbermaid 7380 tandem mop bucket...how can I put the wringer back on track?
It should have grooves on each side to slide the wringer into. Just slide them in place and you should be set.
Jan 26, 2015 | Rubbermaid Vacuums
Reveal mop bottle won't come out easily
There is no locking mechasiam, it should just pull out. If yours is stuck maybe something broke check out this YouTube video. She removes the bottle at 3:42. Rubbermaid Reveal Mop
Oct 04, 2014 | Rubbermaid Reveal Spray Mop Kit,...
How can i make this friggin spray work
When your Reveal will not squeeze you have o-ring swell on the piston which squirts the fluid out. I think the piston rubber swells under the influence of the solvents that people use to clean their floor. My fix, take it apart, and drill out (ream) the plastic cylinder the piston moves up and down in so it moves freely.
Now it works fine. I also stretched the spring a little.
The designers forgot about o-ring swell. Remember the Challenger?
Jun 19, 2014 | Rubbermaid Reveal Spray Mop Kit,...
Rubbermaid Reveal mop trigger sticking
I bought 2 rubbermaid reveal spray mops before I figured this out. You'll need a Phillips and flat head screwdriver & a can of WD40. On the compartment that holds the liquid cleaner bottle there are 2 screws and 1 screw on the connector piece to the mop head. Unscrew all three. The one by the mop head came out and the other two stayed in their holes. Then with a flathead screwdriver gently pull the seam along the side apart. You only need 1/2-1 inch of a gap. If you pull it open all the way you'll pop a few other pieces out of place and have to piece them all back together- so gently! Then spray some WD40 in along the exposed spring using the red straw that comes with the can. Close the gap, hold it together and try the trigger a few times. If the trigger is still sticking spray more WD40 in until it frees up. Then screw your screws back in and it's as good as new!
Dec 03, 2013 | Rubbermaid Reveal Spray Mop Kit,...
Streaks on porcelein tile from shark steam mop
Try washing your pads in JUST water and Baking soda or Borax (and only about a tbs). Sounds like a hard water problem. I had the same issue with my wood floors so I put some Murphy's Oil in a spray bottle and it polished my floors while I steamed. Perhaps there is a good tile cleaner/polish you can spray with a spray bottle while you mop? Just a suggestion. I haven't had this particular issue with tile (our floors are concrete and wood) but the streaks went away when I started using just Borax in my laundry with them, no fabric softener, no dryer sheets. My mom used to use Isopropyl alcohol in a spray bottle with her steam mop. Make sure your tile is well seeled too, it gives you a better finish. The alcohol dries on it's own too without leaving residue.
Jul 09, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
O-Cedar Pro-Mist trigger doesn't work
This person is asking about an O'Cedar Pro Mist Mop. Not a vacuum or steam mop...
I too have problems with the pro mist handle not working... I called the customer care line at 1800-543-8105 and they are replacing my mop for free. You can also try to take it apart and fix it yourself, but I did that and I cant remember how it goes back together! lol Basically a spring comes loose from the pole inside of the mop handle, and that is why there is no tension in the trigger.
Feb 19, 2012 | Vacuums
I bought my steam mop in February 2009 and had no trouble with it until today when it would not put out steam. It made a gurgling sound, but emitted no steam.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Nov 11, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I filled my mop but it will not steam, water drips from mop pad
Use bottled spring water...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
heatman101
Aug 22, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam Mop Model S3101
Use bottled spring water in unit...
heatman101
May 11, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Bonaire steam mop no steam
heatman101
mm
Apr 24, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Rubbermaid Reveal Spray Mop Kit, FG1M1600GRYRD Logo
113 people viewed this question
Top Rubbermaid Vacuums Experts
JoeVacs
Are you a Rubbermaid Vacuum Expert? Answer questions, earn points and help others
