Question about Code Alarm 1100 Vehicle Security System 1100
How can i program a new remote to my code alarm Elite 1100
My original remote is giving me problems so i got a new one but don't know how to program?
Ingot my Philips remote programmed on my tv and DVD player. It works but when using DVD player the buttons don't function as its proper function. For example the play button puts the tv on mute,
It is a common problem with any universal remote controls. Try an other code for your device. Select one code which has maximum functionality. Than is the only thing have to do.
Sep 21, 2012 | Philips SRP4004 Remote Control
Can a new remote be programmed if alarm is set?
Hi Kim, When you ordered the new key the dealer should have asked for the chassis number? That gives them the codes to pre program. so that it should activate and deactivate the alarm, if that is the problem! ? Regards John
Jul 02, 2012 | 2000 Pontiac Grand Prix
On my 98 corolla the radio clock and dome light doesn't work. But when I put the fuse in all that works but the alarm goes off. Don't have original key or remote for the car. Is there away to fix...
leave the fuse in have someone disconnect old alarm
and get a new one. is gonna be more expensive to purchase
the remote than to get a new alarm.
(California of coors).
Apr 21, 2012 | 1998 Toyota Corolla
Will my tv remote work on my converter box?
If the tv remote is the original TV remote, it won't control the converter box (if this is an digital-to-analog converter). If it is another remote, then maybe. It depends on the remote and when it was programmed.
Most remotes are limited to codes for devices released at least 6 months before the remote was programmed. Thus is your TV remote was programmed in late 2006, then it may have the right code. Some universal remotes support the converter boxes; others don't. If you provide additional information on the remote, I may be able to give you more specific details for your situation.
I hope this helps.
(any tv that requires a d-t-a converter box was built before any plans were finalized for the converter box.)
Sep 17, 2011 | Televison & Video
I have a 2003 hyundai sonata and i dont have the remote for the stock alarm. My alarm keeps going off and my car wont start. I bought a new battery and even tried the key in the door still no luck.....
The 2003 Sonata is equipped with a 'starter KILL' burglar alarm system with disables the starting system (using a N/C 'contacts' configuration instead of a N/O contacts configuration). N/C=Normally closed, and N/O=Normally open contacts. When the alarm goes off with a MY Sonata, the only way to DISARM it is with the key fob (remote) originally programmed for it (unless you purchase a new remote & have it programmed for the vehicle at an authorized Hyundai Service Department). NOTE: So long as the keyless entry & burglar alarm system is functioning/operating normally, the alarm will keep going off and the STARTER KILL function will still prevent you from starting the vehicle. One option is left without purchasing a new remote and having it programmed.
1. When the alarm goes off, get into the vehicle and insert the ignition key into the ignition.
2. Turn the key to the 'RUN' position (NOT the ACC position) and wait for the alarm to STOP (usually about 3 to 5 minutes).
3. The engine should then start using the ignition key.
If this procedure doesn't work, the problem will need further diagnosis by a qualified/certified Hyundai Service Technician.
Hope this helps
Aug 27, 2011 | 2003 Hyundai Sonata
The code of my home theater (Sony BDV-E570) listed in remote manual ( Kamaleon URC-9960b01) doesn't work. Do you have the right one?
Hello
That is I wonder about your problem post! No universal remotes have the codes for Blu-Rays so far. You haven't try for that. You can synchronise other devices like TVs, VCRs, DVDs and so n, but not with Blu-Rays. The remote control you posesses now is one amoung the greatest one universal remotes we can get from market. Not waste your time for this purpose. Try to get its original number remote control from Sony. Just contact the nearest Sony Authorised Service center. They can provide you the original number remote handset. If you don't know the number of the remote control, isn't matter, just give them the exact model number of your device. OK.
Aug 05, 2011 | One For All Kameleon URC-9960 LCD...
I have a Dynex TV & a Dynex DVD player, Lost the remote to the DVD player but I have a PHDVD5 universal remote that I'd like to use for them both, or AT LEAST the DVD player. I just don't know...
TV code is 115
Will not find a code for the DVD player though. Im not sure which model you have, but Dynex will send you to MCM Electronics for original replacement parts, that is their provider. Check out www.mcmelectronics.com or give them a call at 888-235-4692 to see if they have your remote. Remotes for the models DX-DVD2 and DX-UPDVD2 are both listed for $4.99 plus shipping.
May 13, 2011 | Philips PH-DVD5 Remote Control
Code Alarm  1100 Vehicle Security System 1100 Logo
Top Elite Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Elite Vehicle Part and Accessory Expert? Answer questions, earn points and help others
