Question about Honeywell Voyager 1200g Barcode Scanner 1200G2USB1 Handheld Barcode Scanner
Honeywell I did try to solve my problem but can not get answer. - UPC-A : 12 digits with 0 in front (done) - EAN13 : 12 digits (done) - EAN8 : no additional 00000 (problem) I can get EAN8 without 00000, but the UPC-A also without 0.
    Problem Solver:
  • 18 Answers
Scan "do not expand ean-8 to ean-13" in your programming guide.
Posted on Nov 09, 2013
UPC code85948500222
Hi. I'm not sure if this will help you, but I found this website:
UPC Database Item Lookup
According to this website:
"Enter the all digits printed on the UPC bar code, including any numbers to the right or left of the bar code itself, even if they don't line up with the main row of numbers. This should be 13 digits for an EAN/UCC-13, 12 digits for a Type A UPC code, or 8 digits for a Type-E (zero-supressed) UPC code. Anything other than 8 or 12 digits is not a UPC code! (And just because it's 8 or 12 digits doesn't mean it is a UPC.) You must enter every digit here.
If you have a barcode scanner that outputs plain numbers, you should be able to use it to enter the UPC number here."
So, apparently you need more digits to complete the bar code #. But if you have the full barcode, you should be able to enter it on the website linked above, and find the image of the frames that you are looking for. I hope this helped. Thanks!
Oct 23, 2014 | Datalogic QuickScan QS6000 Plus Bar Code...
My scanner reads only12 numbers not 13 numbers from barcode what h do?
Perhaps you should ask for replacements and ask for a bar code scanner who reads 13 numbers because even how many times you try it over and over again if the function of the scanner is limited in reading 12 number the results will be the same..Hope it can Help you.
Jul 02, 2011 | Metrologic Instruments 9520 Voyager
What is the upc?
UPC=Universal Product Code
Wikipedia says:
The UPC encodes 12 decimal digits as SLLLLLLMRRRRRRE, where S (start) and E (end) are the bit pattern 101, M (middle) is the bit pattern 01010 (called guard bars), and each L (left) and R (right) are digits, each one represented by a seven-bit code. This is a total of 95 bits. The bit pattern for each numeral is designed to be as little like the others as possible, and to have no more than four consecutive 1s or 0s in order. Both are for reliability in scanning.
Since S, M, and E all include two bars, and each of the 12 digits of the UPC-A barcode consists of two bars and two spaces, all UPC-A barcodes consist of exactly (3 × 2) + (12 × 2) = 30 bars.
The UPC has only numerals, with no letters or other characters. The first digit L is the prefix. The last digit R is an error correcting check digit, allowing some errors in scanning or manual entry to be detected. UPC data structures are a component of GTINs (Global Trade Item Numbers). All of these data structures follow the global GS1 standards.
Apr 10, 2011 | Nextar MA933A MP3 Player
We need to convert UPC-A barcode number to EAN-13
Most scanners will convert UPCA to EAN13 as you scan if you have that setting checked. A 0 will be added in front of the UPCA to make it an EAN13. Nothing else changes. You can read about this stuff on Wikipedia.
Mar 24, 2009 | Symbol LS2208 Handheld
Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
Configuring eclipse 5145
Turning off check digit sending and adding 4 suffixes: 2 cursors left and 2 deletes, solved the problem.
Apr 19, 2008 | Metrologic Instruments MS5145 Handheld
Voyager 9520 10 digit UPC
The last digit should be a parity Digit (used for error checking)
you may be able to clear this using the settings barcodes in the user manual
Mar 31, 2008 | Metrologic Instruments 9520 Voyager
Honeywell Voyager 1200g Barcode Scanner 1200G2USB1 Handheld Barcode Scanner Logo
141 people viewed this question
Top Honeywell Computers & Internet Experts
Ron Dufek
Ron Dufek
Les Morrison
Les Morrison
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
