Question about KitchenAid PRO LINE KPCM100 Coffee Maker
Kitchenaid coffee maker on switch broken
The knob coming out of the front to dial the machine on/off broke near the base. Is there any way to fix this? Cannot figure out how front panel can be removed to access the base of it.
SOURCE: kitchenaid coffee maker model #KCM534OBO
The manual s available online here http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/P05032002.pdf
Posted on Mar 14, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: how to clean the kitchenaid java express coffee maker
The Coffee Maker can be descaled using
a packaged descaling agent or vinegar.
Always mix the descaling solution using
cool water.
• When using a descaling agent, follow
the directions on the package for the
recommended amounts of descaling
agent and water to use.
• When using vinegar, fill the carafe with
a solution consisting of 1⁄2 vinegar and
1⁄2 water.
Descaling Steps:
1. Before descaling, always remove the
water filter (see “Installing the Ion-
Exchange Water Filter” on page 7) and
make sure the brew basket contains
no coffee or coffee filters.
2. Run the Coffee Maker through a
complete brewing cycle using a full
carafe of the descaling solution.
3. If the cleaning needed indicator lights
after the brewing cycle is complete,
repeat Step 2 using fresh descaling
solution. Keep repeating Step 2 until
the cleaning needed indicator no
longer lights after brewing.
4. Rinse the Coffee Maker by running
it through two brewing cycles using a
full carafe of fresh, cool water
each time.
5. Wash the brew basket in hot, soapy
water and rinse with hot water. This
part can also be washed in the upper
rack of the dishwasher.
6. Reinstall or replace the water filter.
Replace the filter every three months
under normal usage, or more often
with heavy use.
Posted on Mar 30, 2009
  • 145 Answers
SOURCE: need manual for pro 12 kitchenaid coffee maker.
Manuals and guides may be located online at KITCHENAID.COM.
In the upper-right hand corner of the site, click on CUSTOMER CARE and then click on LOCATE MANUALS AND GUIDES.
It will then ask you for your model number.
For an espresso maker, the model number is located on a silver sticker behind the water reservoir. For a coffee maker, the model number is located on a silver sticker underneath the machine.
On the website, type in your model number exactly as it appears on this sticker and click GO.
This will then bring up the literature listing for your particular unit. You will need Adobe Acrobat Reader to view the files.
Also, Kitchenaid Customer Service will send you a physical copy of an instruction manual at no charge if you choose to call them. Their toll-free telephone number is:
1.800.541.6390.
Posted on Aug 08, 2009
SOURCE: KitchenAid Artisan: A bang, and now no water coming through.
Call Importer Peter McInnes - based in sydney, they'll put you on to someone!
Pete
Posted on Jun 08, 2010
SOURCE: KitchenAid Proline coffee maker has what looks
I have the same problem of corrosion under the finish near the water filling section.
Posted on Feb 28, 2011
Clean keeps flashing even when I've cleaned
External visual cleaning is not enough.
The coffee maker needs internal cleaning.
Please descale the machine to remove the error message.
Mar 03, 2015 | Kitchenaid Coffee Maker - 14 Cup - Empire...
Why is our coffee maker not brewing
Hi Rob:
Chances are pretty good that there is a broken electrical wire or non functioning switch inside the unit.
If you have a continuity meter you might try (with the unit unplugged) to dismantle the unit and check.
The rule is:
It's already broke, so if you can't fix it you're no worse off.
Jun 17, 2014 | DeLonghi Coffee Makers & Espresso Machines
Bosch benvenuto b30 had for years and loved. Now when use beans the coffee/espresso is too watery and pucks are like sludge after. Works good when use preground coffee .
You have accidentally turned down the brew strength selector, on front of unit just above "clean" and "descale" buttons. Dial it the the maximum. Will grind longer, make more grounds, larger puck, stronger coffee. Or this dial is broken/ wire broken etc. u can disassemble per some other posts on here and check wire connections. I did all that then realized someone had just turned it down. So I turned it to maximum strength and problem fixed.
Oct 15, 2013 | Bosch Benvenuto B30 Espresso/Coffee Maker
What is part # for broken steam control dial eam3200
DeLonghi 5532125700 On/Off Knob
I think that's the one.
Jun 01, 2010 | DeLonghi EAM3200 Espresso & Coffee Maker
Pete
May 21, 2010 | KitchenAid Artisan
Coffee Lid
www.shopkitchenaid.com
You will probably need to buy the whole thing (jar and lid) for about $25.
Mar 07, 2010 | KitchenAid KCM511 Coffee Maker
How to work Spidem Cappuccino Instantly Espresso Machine
the coffee portion of the knob only allows the instant coffee to be added to the mixing process, then when the knob is turned to the milk selection, the milk is frothed and the instant coffee is added and dispensed into a container under the dispenser area on the front of the machine......Hope this helps.
Aug 16, 2008 | Coffee Makers & Espresso Machines
Broken see thru knob P/N 30595
you can try using rear view mirror adhesive, available at auto parts stores. Get it very clean with alcohol first.
Jun 10, 2007 | Faberware FCP512S Coffee Maker
KitchenAid PRO LINE KPCM100 Coffee Maker Logo
20 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
graybeard32301
Ismael Rodriguez...
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
