Question about HP Office Jet 4500 G510n
Hp officejet4500status says printing but not printing
Printer says printing but not printing
  • HP Master
  • 32,281 Answers
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Posted on Jan 18, 2013
Is there available any android app for HP Printer Support, to guide how to fix HP Printers Error
First Enable HP Printer service plugin, this established connection between the Android mobile to Wifi network.
Install or Update the HP Print service from Play Store, and then Turn On the Plugin.
Check out the printer and android mobile is connected in the same network to make printer or else wifi direct on your printer and android device is enabled.
Install or update the HP print service Plugin from the Google Play Store
If Installation completed choose a method to turn on the HP Print Service Plugin.
Is this the first time you installed the HP Print Service Plugin, Now sweep down the home screen to get notification dashboard and then find HP Inc.service installed.
Would like to update the HP Printer service Plugin, goto setting,tap more,more networks,more settings or NFC and Sharing and then tap print and printing.
While you Turn On the HP Printer Service Plugin, the other printer service plugin should be Turn Off.
How can you take print menu and the click print. Now you will get print print preview screen
Next to select a printer,tap the down arrow to view the printer list and then select your printer from the list of available printers.
for more Printer Helpdisk https://123hp.co/
Nov 09, 2017 | HP Office Equipment & Supplies
WHY DOES MY HP PSC 1610 MAKES A CLICKING/CLANKING SOUND WHEN STARTING TO PRINT STILL PRINTS
I think your printer required maintenance, because printer time all parts working then your printer print. I gas you some points link printer belt, printer header, printer roller..so any one damage or this types of issue create, so i suggest you contact HP printer technician and check it.
Thanks,
HP Printer Support
May 18, 2014 | HP PSC 1610 All-In-One InkJet Printer
Will it print from edge to edge on the paper?
Most will not, at least not with the drivers that the manufacturers give you.The only time I have had a printer print edge to edge is when I got my Windows Mobile 6 phone to print via bluetooth to an HP printer that came with a bluetooth dongle. I could not get that same printer to print edge to edge when printing from a computer, no matter what I did.
Here is some more advice regarding HP printers (since you didn't specify which printer make or model, and HP is the most popular):
from: How to Print to the Edge With an HP Printer ' eHow.com http://www.ehow.com/how_5817661_print-edge-hp-printer.html#ixzz1JuTJG38a
"Not all HP Printers will do borderless printing. If you don't see the borderless paper option, your printer does not support borderless printing.)"
Apr 18, 2011 | Office Equipment & Supplies
Is it possible to make the printer print a test print or diagnost
The HP Printing Diagnostic Utility is created to diagnose and fix many common issues preventing printing from the computer:
http://h10025.www1.hp.com/ewfrf/wc/s...roduct=1153481
May 07, 2009 | HP LaserJet 1020 Printer
New HP CP2025 printer prints "ghost" DVD circles between labels
hi, i work for a company who is the dealar of hp products.
you have to do a clean service of your hp printer.
after that the printer should not have ghost print any more.
Apr 17, 2009 | HP Laserjet Cp2025n Printer
The printer is not recognizing the black print cartridge. It is an official hp black 59 (19ml) cartridge but it still does not recognize it and therefore will not print. My printers is an HP 1215...
Your printer does not use #59 Cartridge!!!!
HP 56 black print cartridge (19 ml) C6656A HP 57 tri-color print cartridge (17 ml) C6657A HP 27 low capacity black print cartridge (10 ml) C8727A HP 28 low capacity tri-color print cartridge (8ml) C8728A
Sep 24, 2008 | HP Office Equipment & Supplies
How can I print Black only?
Hi
HP Inkjet printers work only if both the cartridges have ink unlike HP Laserjet printers.
If you want the printer to print only in black, Follow the steps
Start --->Control panel -- >Printers and faxes ---->Right click on the printer icon (HP c5100) select printing preferences.
Under printing prefences there u will see an option to print with black or print in gray scale.
Note:HP Inkjet printers like Photosmart C5180 will work only both the cartridges have ink.
Thanks
Riz
Jul 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
Pale print on PDF files
It sounds like a driver problem. Try replacing the driver for this printer on the printers folder, using the HP LaserJet Series II. With this driver, try again the PDF file and see if it prints correctly.
Jul 25, 2007 | HP LaserJet 4345mfp Printer
HP Office Jet 4500 G510n Logo
mukhtar21 shaikh
mukhtar21 shaikh
