Question about Toshiba Satellite A135-S4527 Notebook
I'm always being alerted that Com surrogate has stopped working
It sometimes happen when windows explorer is opened, then it will just close the program.
  • 315 Answers
This might help:
Disable Thumbnail Previews in Windows Vista Explorer If you want to speed up browsing around in explorer, you might think about disabling thumbnail previews in folders.
To make this change, click the Organize button on any folder, and choose Folder and Search Options from the menu.
i'm always being alerted that Com surrogate has st - image%7b0%7d%5b1%5d.png
Click the View tab, and then check the Always show icons, never thumbnails checkbox.
Click OK, and you're done.
There are lots of people also pointing this problem to Divx, Nero and general codec packs but the problem starts when they start using a media player not windows explorer.
Give it a go and if it helps please rate me.
Cheers
Posted on Jan 25, 2009
  • 86 Answers
This problem is caused because of codecs and other COM components installed by various softwares that aren't fully Vista-compatible.
Right click on Computer, and choose Properties
Click on Advanced System Settings, and then under Advanced, click Settings
Select the "Data Execution Protection" tab, and then click Turn on DEP for all programs and services except those I select
Click on the Add button, and then browse to C:\Windows\System32\dllhost.exe as shown
Click Open, and then OK.
If I diable com surrogate will it harm my computer
Com surrogate is a service that allows switching on the com ports. Without it, communication to your devices will stop. If you're encountering this error there is a driver problem with your com port controller and you need to install the correct drivers.
Sep 01, 2014 | Microsoft Windows Vista Home Premium...
COM surroget not working
Here is a great trouble-shooter for your current issue.
Reference:
http://www.howtogeek.com/howto/windows-vista/fix-for-com-surrogate-has-stopped-working-error-in-vista/
Aug 01, 2010 | Microsoft Windows Vista Ultimate Edition
''COM surrogate has stopped working.................
Sir COM means "Component Object Model". These are basically DLL files which are used for system tasks and if they get corrupted then you get same problem. For solving this you need to repaid your windows using windows disk.
Jul 21, 2009 | HP Computers & Internet
Com surrogate has stopped working.
find the link for the software u need on this website http://vistatipsforall.blogspot.com/2007/05/com-surrogate-has-stopped-working-error.html
May 31, 2009 | HP Computers & Internet
Com surrogate
These should help:
http://www.superbdevelopment.com/forums/general-tech-talk/3600-windows-vista-com-surrogate-has-stopped-working-fix-solution.html
http://www.mydigitallife.info/2008/06/13/how-to-fix-com-surrogate-problem-when-opening-video-format-files/comment-page-1/
Error message: "COM Surrogate has stopped working."
COM objects are often defined in Dynamic Link Libraries (DLL files). The Program file for COM Surrogate is actually dllhost.exe that can load a DLL and make its objects available to other programs.
The COM Surrogate error message is often related to codecs and other COM objects that aren't fully compatible with Vista. These are installed by other programs. The most common culprits are DivX and Nero. The first thing you should do is upgrade to the latest versions of these to see if that fixes the problem. Another possible fix is to disable thumbnail previews in Explorer. To do that:
In Windows Explorer, click Organize, then select Folder and Search Options
Click the View tab
Check the box that says "Always show icons, never thumbnails"
Click OK
To help troubleshoot which codec(s) might be causing the problem, you can use a free tool called InstalledCodec. You can use it to disable individual codecs one at a time.
You can download it at http://www.nirsoft.net/utils/installed_codec.html
Hope that helps
Mike
May 13, 2009 | Dell Inspiron 1521 Laptop
http://fileforum.betanews.com/detail/Vista-Codec-Package/1159994557/1
Just download this small program and everything should be just fine . I was having the same problem , ive been told that its because of nero or divx codecs , didnt unistalled anything just installed this program and my problem was solve !
Nov 28, 2008 | HP Thin Client - AMD Geode NX 1GHz - 256MB...
Com surrogate and run ddl 32 problem
download codec pack and install it, ex - k-lite codec pack its free on net
Nov 11, 2008 | Microsoft Windows Vista Ultimate Edition
WINDOWS EXPLORER HAS STOP WORKING
Hey there
The problem could be because earlier version of nero You can solve your problem from doing the following:
If you are using Nero, you can try upgrading to the latest version (7.7.5.1+)
If you’ve upgraded Nero and still have the problem, you can try renaming the file C:\Program Files\Common Files\Ahead\DSFilter\NeVideo.ax to NeVideo.ax.bak. You may also need to rename NeVideoHD.ax to NeVideoHD.bak
This will break Nero Showtime, however.
There's another possible solution below of turning off DEP for dllhost, which might not work your windows explorer
Essentially, turning off Data Execution Prevention on dllhost (the COM surrogate or windows explorer) can fix this problem. This solution is detailed below.
Select the "Data Execution Protection" tab, and then click “Turn on DEP for all programs and services except those I select”
Enjoy working
Gimme your acknowledge by rating me
thanx
Romy
Oct 18, 2008 | Computers & Internet
Windows explorer has stopped working
Hey there
There's another possible solution below of turning off DEP for dllhost, which might not work your windows explorer.
thanx
Romy
Aug 03, 2008 | Microsoft Windows Vista Ultimate Edition
Toshiba Satellite A135-S4527 Notebook Logo
135 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
