Question about Kenmore Dishwashers
Dishwasher will not start wash cycle, but diagnostics, all lights on and cycles.
Got the system in diagnostics, all lights came on and cycled, but after diagnostics is over, only heat select lights will come on, no other switches work.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Compassitor
Posted on Jan 18, 2013
5 Suggested Answers
  • 116 Answers
SOURCE: Not starting wash cycle
Typically this means that there has been a water leak of some sort and there is water in the lower base pan. This is the large white plastic base that the dishwasher sits on.
If you remove the toe kick and look back past the fill valve on the extreme left side of the dishwasher about 6 to 8 inches from the front you will see a red stick that goes straight up and down. This is a mechanical linkage that activates the drain feature. Be careful as there are live connections here.
This stick rests on a round piece of Styrofoam that acts as a float. If there is water present it will cause the stick to lift and the dishwasher will go into drain. The source of the leak will have to be isolated and corrected. Most likely it is the fill float assembly as referenced at the end of this post.
If the stick is not in the upright position then there is possibly an issue with the switch mechanism itself.
You will have to pull the dishwasher out from beneath the cabinet and remove the panel covering the left hand side. If it is a full panel then there are a couple of screws holding it on from the front through side trim as viewed when the door is open if it is a half panel then it can be removed by removing the large torx screw on the lower right as seen when facing the panel.
If there is a problem with the switch then the entire mechanism should be replaced.
Try the following link to a picture for reference. It is upside down as compared to the installed one:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=935595&PPStack=1
Posted on Sep 17, 2008
Amigaman
  • 248 Answers
SOURCE: Whirlpool Dishwasher Fills and then Stops
  Check your connection where you connected dishwasher to power cord.
Posted on Oct 25, 2007
StarGGundam2
  • 24 Answers
SOURCE: Maytag Quiet Series dishwasher won't start
Sounds like you have a bad Control Board
http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
Posted on Oct 12, 2009
SOURCE: IDL705 dishwasher showing error code
Indesit IDL700 first two green lights flashing and cycle stops with dirty water left in the machine. CAUSE - blocked or jammed drain pump. SOLUTION - First remove all the filters inside the machine, syphon or sponge up all the water in the sump and check for any obstruction over the fine grill at the very bottom. (we had a pistachio shell covering the hole!). If this doesn't cue it you will need to gain access to the pump. First, turn off the power. Gently lift the machine onto it's side (be ready for some water to spill out!). Remove the bottom plate (6 screws) and disconnect the sump float switch. Remove the single screw retaining the pump to the bottom of the machine and rotate to remove. You should be able to see the rotor blades. With your finger check to see if the pump rotates freely. To dismantle the pump, remove the 3 screws and separate the two halves. Our pump was jammed with an apple stalk!. Reassemble and connect any cables. Apparently this is a known problem with these machines and can be prevented by assembling the filter system correctly and pre-rinsing plates etc. before placing in the dishwasher.
Posted on Nov 01, 2009
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
F13814978
Try this diagnostic cycle operation to reset.
To start the Service Diagnostics Cycle, press the
following keys, in order, in less than 6 seconds, while in standby(power on but unit off):
Heated Dry, Normal, Heated Dry, Normal
To Rapid advance one interval at a time, press the Start key, noting that
unlike Standard cycles, the Diagnostics Cycle automatically resumes
after door openings and does not require pressing Start to resume.
Once the diagnostic cycle has run and shut off, run a normal wash cycle, empty and with no detergent, to reset the control to factory "normal" operation. Make sure there's plenty of hot water.
Feb 14, 2014 | Whirlpool 24 in. GU3200XTP Built-in...
Does my whirlpol du1145xtpb1 dishwasherr need to be reset
SERVICE DIAGNOSTICS CYCLE
Read more: http://forum.appliancepartspros.com/dishwasher-repair/261055-whirlpool-quiet-partner-ii-clean-light-flashing-have-reset-still-flashing.html#ixzz2UOcsE2Yg
May 25, 2013 | Whirlpool 24 in. GU3200XTP Built-in...
I have a Whirlpool Quiet Partner II dishwasher and it is stuck in the clean mode the light continuous blinks
THat means that something is wrong with the water temp. It is either not hot enough when it fills or the heating element that increases the temp it bad. To start the Service Diagnostics Cycle, press the
Feb 22, 2013 | Dishwashers
Kenmore classic dishwasher washing cyle doesn't start
It sounds as if you need to replace the timer. The reset motor is separate from the primary motor--that is why one type of "cycle"--diagnostic-- seems to work but the regular cycle(s) do not.
Jan 30, 2013 | Dishwashers
The "cancel" light blinks on and off rapidly. If we push start for the cycle the dishwasher clicks off and on intermitently.
To solve this you will have to reset the console. Do this by closing the door and press these buttons in sequence
-high temp wash -heated dry -high temp wash -heated dry
After doing this sequence all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).You should now be able to run the dishwasher as normal.
Thank you!
May 16, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Clean light flashes cant get to start a wash cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It's not as common but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Mar 07, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
Will Not Run
I had the exact same problem. The tech came by and suggested to run the diagnostic cycle to clear up the error. Nice guy didn't charge for the time. He said Whrilpool has a poor software design.
Problem - LED blinks 7 times when the temperature doesn't come up to the degree F required for the wash. This may happen if someone took a shower minutes before starting the dishwasher.
The Tech said, Whirlpool should have allowed a straight forward reset by the customer (instead of disabling the machine for a tech to come by and fix the minor issue).
Here is the solution.
Solution - (is pretty much the same to clear up the other software glitches as well)
Try "resetting" the control board by running the diagnostic cycle. The cycle completes in 15 minutes.
The details are in the service manual. The manual can be found hidden behind the tow plate (at the very bottom front of the washer).
The diagnostic cycle may tell you the problem. It also helps clear up some of the software gltiches.
It is easy to run the diagnostic cycle.
Just the buttons in the following sequence. The sequence should be complete within 6 sec.
heated dry -> Normal -> heated dry -> Normal
This will trigger diagnostic cycle of 19 intervals. Pay special attention to the intervals 18, 17, 9, 6, 4.
Interval 18 - displays your controller module number (should be letter 'd' followed by number 0 or 1 or 2 or something. Note that down for future reference.
Interval 17 displays 'software generation number' Note that down for future reference.
Then wait until you reach interval 9.  --- clean LED turns on - then an open or shorted thermister is detected.
-- Sanitized LED turns on - then the washer detected greater than 100 deg F temperature
Interval 7
-- Soaking/sensing LED should NOT come on (unless food soil is present).
Interval 4 -- Soaking/sensing LED should come on
Let the cycle complete and then try running the normal wash. Hopefully the possible glitches are cleared by now and you should have no problem.
If this doesn't work, time to call the expert tech.
Jan 05, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kenmore elite model 16574
press (high temp-wash) button and then ( heated dry)
do that 3 times in that order within 5 seconds. So it looks like this:
(high temp-wash) ( heated dry) (high temp-wash) ( heated dry) (high temp-wash) ( heated dry)
That will start a short diagnostic cycle (last about 2 minutes) that will clear the blinking light and allow you to use the dishwasher. If the light comes back, your drying cycle has failed and you will need service.
Oct 28, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Kitchenaid double-drawer dishwasher will not start
i just installed a used dishwasher. It filled up with water then stopped. The lights are still on as far as the cycles but nothing is happening. I did the factory diagnostic test and the service diagnostic test, not sure how long each test was supposed to take because after it seemed to go through each cycle by the lights on the front nothing else happened. I waited over 30minutes because I didn't know how long this was going to take. When all the lights on the front went out I tried to turn it on like to run a wash cycle and nothing is happening and the bottom is still full on water. HELP!!
Oct 24, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwashers Logo
345 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
