Question about Motorola Mobility MOTOROKR S9 Wireless Headset for Bluetooth-Enabled Cell Phones - Black/Red
Pairing Motorola S9 headset with PC
Hallo
Can I pair my Motorola S9 headset to my PC by using a USB bluetooth stick. If so how do I make sure what is compatible?
Thanks
**** man this headphone sucks mine also not working
Posted on Jun 04, 2012
I have try this before i couldnt do it untill i tryed using the same bluetooth brand as my head phones worked straight away
Posted on Jan 25, 2009
I have metro pcs phone service and a motorola s9 bluetooth headset i cant get the passcode.
Press and hold the power key (under the red cover) longer than the time required to turn it on, until its indicator light is alternately flashing in red and blue. It is in pairing mode (discoverable) now. Then, make your phone's bluetooth application search for new devices. After a little while, the S9 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the S9 should enter the stand-by mode. There could be such an indicaton in your phone too.
Hope it works for you.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
Mar 07, 2011 | Motorola Mobility S9 Headphones
I have the droid backflip and my boss has the first droid from verizon, neither can find the bluetooth headphones (motorokr s9 black & red) how can i pair the headset to my phone if i cant find it
Make sure you put the headset into discoverable or pairing mode, there should be specific instructions that came with your head set to do this, then use the droid or the backflip to scan for the devices and it should find them.
Oct 18, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
How do I put the motorola s9 hd wireless headset in pairing mode for a iPhone 3G ?
Starting with your headset turned off, press and hold the power button for some 6 seconds, until the indicator light flashes alternately in blue and red. It is in pairing mode now. Then, make your phone's bluetooth application search for new devices. After a while the S9 should appear on-screen. Make it connect. If a paring code (or PIN, or passkey) is requested, enter '0000' (four zeros). The indicator light will flash some times and enter stand-by mode.
Regards, Carlos
Sep 01, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
How do I connect my motorola bluetooh headset S9 to my LG Vu920?
When using your S9 for the first time, follow these
steps to pair (connect) to your Phone:
Important: If you are pairing separate Bluetooth
devices for handsfree calls and streaming music, it is
recommended that you pair your S9 with your
handsfree device (phone) first.
1 Ensure the Bluetooth feature is enabled (turned
on) in your phone.
2 Turn on your S9 by pressing and holding (|) button
until the indicator light flashes three times in
blue.
After a few moments, the indicator light will be
steadily lit in blue to indicate your S9 is in pairing
mode.
3 From your device, perform a Bluetooth device
discovery/search. .
When pairing your S9, use
the following steps to perform a device discovery
from your phone:
After accessing the Settings Menu, go to bluetooth.
to add a new device, tap [New].
1. Tap [New] key to search the device that can be connected and which is
within range.
The phone lists Bluetooth devices it
finds.
b Select Motorola S9.
c Select OK or Yes to pair your S9 with
your phone.
d Enter the passkey: 0000
e Select OK.
When your S9 successfully pairs and connects to
your device, the indicator light displays blue with
10 quick purple flashes. If wearing your S9, you
will also hear an audio tone indicating successful
pairing and connection to your device.
4 To verify your S9 has successfully established a
handsfree calling connection with your phone,
dial a phone number you want to call and press
the Send key on your phone.
When successfully connected, you hear ringing
on your S9. A Bluetooth Handsfree Phone (HFP)
connection is now established with your phone
Jul 13, 2009 | LG Vu CU920 Cellular Phone
Trying to connect motorola s9hd to the laptop
assuming you have bluetooth installed on your laptop,
1) you have to disable the bluetooth pairing of your s9 with another device that you may have paired with it earlier - like a mobile phone. disconnect previously paired devices first.
2) turn on the bluetooth feature on your pc and ask it to "search" for devices. assuming your s9 is on standby, your pc should be able to "locate" and pair with it assuming the s9 is within an arms length distance from the computer.
3) make sure that the s9 is completely charged to eliminate that power issues as well
Apr 07, 2009 | Motorola Mobility MOTOROKR S9 + Bluetooth...
Motorola motorokr doesn't work
The mic stopped working on my S9 after 2 weeks and removing the BT device and repairing did the trick...try removing the S9 bluetooth device from phone, then re-adding and pairing again. this worked for me (I have an LG Voyager that I use with the Motorola S9). .
Mar 27, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Pairing Motorola D650 to Motorola S9 with ipod nano or touch
It does work with the itouch. Try turning off the ipod completely. Turn it on again, then plug in the D650 and then your S9. Enjoy!
Mar 18, 2009 | Motorola Mobility MOTOROKR S9 + Bluetooth...
Motorola s9 mic does not work
try removing the S9 bluetooth device from phone, then re-adding and pairing again. this worked for me (I have an LG Voyager that I use with the Motorola S9). Mic stopped working after 2 weeks and removing the BT device and repairing did the trick.
Mar 11, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
PAIR KEY FOR MOTOROLA s9
Bluetooth headsets have their passkey hardcoded by their manufacturers. So, I'm afraid it is not suitable to be changed. However, once any two bluetooth devices are paired, their link is encrypted. You see, you put your headset in pairing mode only when you want to pair it to a specific device of yours (i.e. phone, PC, etc.). Once they are paired to each other, third devices won't be able to get into that connection.
Just my 2 cents...
Regards, Carlos
Feb 21, 2009 | Motorola Mobility S9 Headphones
Motorola Mobility MOTOROKR S9 Wireless Headset for Bluetooth-Enabled Cell Phones - Black/Red Logo
532 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
