Question about Zebra ZM400 Direct Thermal-Thermal Transfer Bar Code
Zm400 media darkness settings get reset after printings lable from SAP
  • 96 Answers
The printer driver settings override the printer settings unless you tell the driver to use the printer settings. You can tell by setting the printer setting and saving it permanently. Print a configuration label. Send a label to the printer. Print another configuration label. Compare the config labels and If it changed, then the driver changed it. Set the driver as above and it will not change when you print.
Posted on Nov 06, 2013
4 Suggested Answers
  • 185 Answers
SOURCE: I am having problems with Zebra printer MDL#ZM400
Try entering the Menu system and exiting, whilst exiting and instead of saving permanent, cycle around to load defaults. once you have done that make sure the settings are as you need such as Thermal Transfer etc and save permanent. You won't have a problem after that. If you do I would be checking the page setup in the software to make sure it fits the lables.
Posted on Jan 25, 2010
  • 35 Answers
SOURCE: zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Posted on Feb 16, 2010
  • 97 Answers
SOURCE: For ZM400 and S4M, Has anyone had any luck with
You can try this: on the S4M, you can press the Menu key to go into setup mode. Under password level 3 parameters,there is a setting for ribbon which by default is set to Yes thermal trans. If you set it to No for direct thermal mode, this will in effect turn off the ribbon sensor. The printer won't stop now if it runs out of ribbon but usually you are there when printing to see that the ribbon is running out.
On other Zebras, you can turn down the sensitivity of the RIBBON LED sensor but the S4M doesn't have that setting.
See if that helps.
Posted on Jun 21, 2011
Zebra ZM400 drops interface on port 515
make sure you have no network traffic for your printer and decrease the printing speed, and make sure you are using a free port not a used and default port for the service..
Jul 20, 2014 | Zebra ZM400 Thermal Label Printer -...
Z4MPLUS doesn't recognize the MEDIA(LABEL) automatically.
you should recalibt=rate the printer.
Are you sure that your previous label was not longer?
With the autocalibrate function activated the printer should try to detect the correct length. If it doesn't the yoou have
- A problem with the label border
- Preprinted stuff which the printer detects as to fo feed
Dec 09, 2013 | Zebra Z4Mplus Label Printer
Hello, I changed the ribbon. The ribbon and labels
can you adjust the printhead pressure?? if so then do that
Aug 22, 2017 | Zebra ZM400 Thermal Label Printer -...
Will not print onto the label. but can see it on the black ribbon reel.
Perhaps your darkness is set too low, or your labels are not coated to accept thermal transfer printing. Let me know if this helps!
Aug 28, 2011 | Zebra ZM400 Thermal Label Printer -...
I am having problems with Zebra printer MDL#ZM400 skipping labels....so if I print 10 lables it might give me 15 lables and 5 of them are blank
Jan 23, 2010 | Zebra Z4Mplus Label Printer
Zebra zm400 turn printed info 180 degrees
Dec 17, 2009 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
Prints larger that print preview shows...
Firstly make sure your using the correct drive ZM400 rather than Z4M. if you are using the applications driver make sure of headers and footers sizes and the print area is set correctly. If your using odd sized lables download some new drivers from the Nice Label website, they are far more adjustable that the standard Zebra drivers.
Aug 29, 2009 | Zebra Z4M Printer
I can't print to my printer zm400
When you install the driver, do you get a test print from the driver setup? If the data light blinks, this is at least a sign that something is coming and the printer is aware of it. If you feel knowledgeable of the printer to do a Media Sensor setup through the menu, you can reset the printer to Factory Default settings. Getting any print from the machine is a plus. Are you using the Zebra drivers? If yes, you can try printing from Notepad.
Apr 26, 2009 | Zebra Printer 140-751-00000
Trying to use a Zebra ZTC ZM400 with an AS400
I was having same issue printing from our AS400's as well.
Issues was resolved by installing latest Zebra ZM400 firmware.
We were on ver V53.16.3Z but upgrading to V53.16.4Z seems to have resolved it.
Good luck.
Jul 03, 2008 | Office Equipment & Supplies
Will not print on all four lables, and does not print in the same place each time.
for starters you need to calibrate your printer.
Note: If printing in Direct Thermal Mode, default the printer first (4 flashes).
1. Load the labels and ribbon (if used) and close the printer
2. Turn on the printer power.
3. Allow the printer to feed or error out.
4. Press and hold the feed button until the green status LED flashes once, then twice. Release the feed button.
6. The printer will set the media sensor for the label backing being used and then automatically feed until a label is positioned at the printhead.
7. A profile of the media sensor settings (similar to the example in Figure 1) will print. Upon completion, the printer will save the new settings in memory and the printer is ready for normal operation.
8. Press the feed button. One entire blank label will feed. If this does not happen, try defaulting (Hold the FEED button until it flashes 4 times)
Jun 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra ZM400 Direct Thermal-Thermal Transfer Bar Code  Logo
849 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
