Question about Desa International Blower Glow Warm Wall Heater
Glo-warm heater won't light
Heater has new regulator and hoses.... when you depress the ignitor the pilot light sparks...
SOURCE: glo warm?
u need a 100 lb tank minimum for the heater to operate properly
Posted on Nov 22, 2008
FixFree
  • 12 Answers
SOURCE: glo warm wall heater will not stay lit
Hi Cindy,
It seems that your heater is not sensing the flame is lit and is shutting gas supply off. There should be what is called a flame sensor, it is a thin pc. of metal that sticks out into where the flame when lit.
This usually gets charred and dirty, if you unscrew it and clean it with a soft cloth then re-insert it, it will get you by. You should get a new sensor when you have a chance.
Good luck and be sure to disconnect from any power source or turn unit completely off when orking on it.
Thanks,
Paul
Posted on Jan 28, 2009
tinytrees
  • 92 Answers
SOURCE: Glo Warm propane heater won't light
There is really not a lot to go wrong with the heater itself so my first guess would be that the regulator is bad, not letting the proper amount of gas through. You can check it for leaks with a bottlee of soapy water but even if you don't see a leak there is a rubber gasket inside with a pressure spring that is probably bad.
Posted on Feb 04, 2009
SOURCE: My glo-warm propane heater keeps shutting off automatically-pilot and all.
my heater says if the pilot light keeps going off automatically it is a safety function that means it does not have enough fresh air to operate
Posted on Dec 04, 2009
  • 4 Answers
SOURCE: I have a blue flame GLO WARM 20btu wall model # WMP20A
Look for and clean the flame sensor.
Posted on Dec 06, 2009
When my glo warm heater reaches desired temp it not only shuts off but pilot light goes out too.
Maybe it's a direct spark ignitor so when call for heating pilot would open and spark ignitor would lite it
Jan 05, 2018 | Heating & Cooling
Pilot light wont light will spark, but no propane
verify the inlet pressure to the heater. those pezioelectric spark lighters are garbage. make sure all manual shut off valves to the heater are open. Pilot tubing may also be blocked
Nov 25, 2013 | Glo-warm 503284 30000 BTU Propane Gas Vent...
I have a full tank of propane - my pilot light is sparking but it will not light? Any ideas on what to check? Thank you, Korby
Korby, I think you meant, your ignitor is sparking and you're not getting gas to the pilot. Since you have a full tank of propane, I can rule out that the tank is empty. However, I believe the tank or at least the tank valve is playing a role in this.
Turn the tank valve completely OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY (Slow Motion, slow) until the valve is fully open. Then light the pilot as you normally would. If the pilot lights, you solved the problem. If it didn't, either the pilot light is clogged and needs to be cleaned or the heater's hose/regulator assembly needs to be replaced.
Endless Summer Patio Heaters are made by Blue Rhino. So, if you need parts, that's where you can get them. Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 09, 2011 | Endless Summer 153100 Open Flame Patio...
My glo-warm wall mount heater pilot light will not light. I tried the ignitor, saw blue spark , and nothing. I also tried using a lighter, I got it to light barely once and that was it. I can't smell any...
Without the model number of the heater it is hard to give an accurate answer but I will give you some suggestions.
I would start with cleaning the pilot ODS assembly.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
I would check the regulator on the heater...if it is propane these gas get raw gases in the regulator and cause the unit not to pressure up correctly.
Give these items a try first before replacing any parts.
Thanks
M Cramer
www.allpartsinc.com
Jan 04, 2011 | Desa International Blower Glow Warm Wall...
Pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Propane heater has spark but wont light
ODS/Pilot may be clogged make sure you clean it out according to the instructions in your owner's manual. If you need a copy of the manual let me know and I will try to find it for you. If it is still not working it could be the gas regulator or the ignitor cable. For Glow warm parts contact Master Parts at 800-446-1446 or you also can find them online at www.masterparts.net. I hope this helps you!
May 04, 2009 | Desa International Blower Glow Warm Wall...
Natural Gas Heater Dyna-Glo
it s the thermocouple excannge it should solve the problem , try national energy they do spares
Feb 16, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Lighting a glo warm heater
Is this a new heater or have you had it awhile? If new, yuo may have air in the line that will need to be bled out. The heater has a gas valve with a pilot setting on it. Make sure the gas is turned on. Turn the knob to the pilot setting and depress the handle. Holding it down and at the same time, press down on the red button that sparks. You may have to repeat this a few times. Once the pilot lights, continue to hold down on the pilot knob for about 30 seconds. When uou release the knob, the flame should stay o. If it does not, replace the thermocouple. Once the pilot flame is steady, turn the gas valve knob to on.
Nov 29, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Desa International Blower Glow Warm Wall Heater Logo
869 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
vance jones
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
