Question about Hotpoint Ultima WF860 Front Load Washer
My hotpoint ultima super silent displays 'test' but dnt run cycle
When i request any wash the machine goes to start then test comes up on the display it seemss to go throough the prewash wash rinse and spin with no water then goes back to the beggining and does it all over again!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
Posted on Jan 27, 2009
My hotpoint lumina super silent is starting a cycle but only loads the water and then doesn't spin it just stays still and counts down the time until theoad finishes and then empties the water. What's...
it's not named after that other car, is it? It's a hotpoint ultima super silent. Most likely suspect is the drive belt for the tub. Remove back cover and find the tech sheet stuffed in the unit for lots of secrets, shortcuts, and commonly replaced parts with the correct mfr part numbers. Check to see if the belt has come loose and why.
Mar 05, 2015 | Hotpoint Washing Machines
Hotpoint Ultima Super Silent. Was & Dry
High Temperature Rise in Drying:
check fan motor & filter for blockage. basically a reduced airflow within drum unit
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Test mode
press start once
then press start again now hold on/off and cancel together for a few secs should no say d/off or something should work now
Aug 22, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Error Code "TEST"
Just had the same problem & found the following solution via the web :-
1. When tESt shows hold down both the ON/OFF Button & the START Button together & let the Test proceed holding the two buttons down for the entire test (Approx 3 Minutes ) .
Continue to hold the " buttons down until the word Done appears.
After which you should be able to proceed with the normal wash cycle
May 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Demo mode
To fix, hold the Start Button in until it completes the full cycle about 3 mins. It should say end or something similar then start as normal.
May 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Aug 27, 2008 | Washing Machines
Ultima WF 840
try unplugging from wall hold down start button for a few seconds leave unplugged for 10-15 mins reconnect and ckif problem still there may be control bd problem ..first call the sales person you bought if from ..some washer have a demo mode for floor display use may be a way to back out of it
May 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN SPEED.
I read that someone has a problem with F-03 on the display. I have seen this for the first time on my hotpoint wf860 1600 spin. I read the manual the only thing I can think of maybe an unbalanced load in the machine. Albeit the manual is not clear about this. P21 automatic features unbalanced load warning.
Sep 04, 2006 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
673 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
