Question about Mitsubishi Televison & Video
How do I activate the vga on a Mitsubishi Medallion 1080?
I am trying to use the vga device on a MitsubishiMedallion 1080. The owners manual is quite vague, telling me to simply connect the vga and activate the projection from my notebook. I have connected the VGA cable to the correct ports. I have done the right click thingy on the desktop that everyone talks about (which takes you to monitor options and resolution). I press windows p to bring up projection options (split, extended, etc.) No matter what settings I use, I can not get the VGA to work. I have gone through the tv device menu. I know where to create new devices, but under create device, there is no VGA option, It shows DVD 1 2 3, Component 1-3, Input 1-5, Input-DTV...but no VGA. The way the manual explains it, leads me to believe that it should just automatically detect my notebook once I turn on the lcd, monitor, etc, but nothing happens what so ever. I am using an Asus G73, which has both HDMI and VGA...the Medallion TV, however, was from 03 and does not have HDMI input, only VGA. Any input would be greatly appreciated, this is really confusing me and hurting my brain. Thank you for your time,
diths_kri
  • 67 Answers
SOURCE: No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Posted on Jan 07, 2009
doin12volt
  • 233 Answers
SOURCE: connect Macbook Pro to Component input
you should be able to use an SVGA to component rca connector on any component input - i have a wd-65513, and thats how I have my pc hooked up to it. I could also never get a clear picture using the SVGA plug on the back of the set.
Posted on Jan 12, 2009
falsafat
  • 31 Answers
SOURCE: Connect Sony Vaio Laptop to DVI on Sony LCD Projection TV
try to lower the resolution of the display, to know how please visit the following link:
https://www.microsoft.com/windowsxp/using/accessibility/screenresolution.mspx
< Please Rate :) >
Posted on Apr 12, 2009
zecs
  • 123 Answers
SOURCE: Trying to hook up HP DV6000 laptop to Mits 55859.
heat vga chip
Posted on Jul 13, 2010
  • 1779 Answers
SOURCE: Hi – please help ….. I have a WS 55907 Diamond
Try turning the set off then reconnect the vga cable, boot the pc then turn the tv on and see if it recognizes it.
Posted on Nov 25, 2010
Vga input to my mitsubishi Medallion hdtv 1080 doesn't work
You can't just plug in the input and expect it to work. You have to bring up the input selection screen on the TV first and select that specific input. Read the manual to see how to select different inputs and you should be fine.
Nov 16, 2013 | Televison & Video
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
I am trying to connect my laptop via VGA cord to my 65" Mitsubishi Medallion, but when I click on the VGA device selection in the device menu, it goes to a blue screen and says "Warning: Turn on...
Press the Windows key + P on your laptop.
Or, if that doesn't work, look on your F keys for something that looks similar to a monitor.
Press the FN key and that key.
This should bring up your laptop's display on the tv.
Mar 09, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi Medallion 1080 WS-55413 - colors not aligned
There is no "reset" as the set has in the customer and tech menus ways to attempt to manually adjust this.
under convergence in the customer menu select advanced and follow the instructions on the screen.
If Red or Blue or Green are skewed and will not adjust it means one of the two STK-394-250 CONVERGENCE chips this set uses is bad.
Depending on where you buy them they will range in price from about 12 dollars each to nearly 35 dollars each.
Let me know what you find; this may or may not be a do it yourself repair as some real expertise is required to correctly get at and replace the chips.
SD TECH
May 11, 2010 | Mitsubishi WS-55413 55" Rear Projection...
My Mitsubishi Medallion 1080 will not come on the green light just keeps flashing and none of the buttons will work...can't find the owners manual...please help!
You can try resetting it , but most likely you have a problem on the dm board. Easiest way to reset is just unplug it for a couple of minutes.
Aug 22, 2009 | Televison & Video
My Mitsubishi Medallion 1080 won't turn on
Are you sure its the right remote? Verify TV mode on remote if equiped with mode switch. Drain the remote by removing batteries.
Jun 27, 2009 | Televison & Video
My t.v. wont turn on. I have a Mitsubishi, Medallion HD 1080. Model ws-65819.
hold down the menu + device for five sec what is the error code?
should be like 1 pause then a 2 or something
Jan 12, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi hd 1080 medallion
i have a green screen on my mitsubishi medallion hdtv 1080
May 30, 2008 | Televison & Video
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
