Question about Dirt Devil UD70095 Bagless Upright Cyclonic Vacuum
Can you take apart a vacuum brushroll?
The pin in the brushroll is loose and off center and wondering if you can take apart the brushroll to fix it?
  • Dirt Devil Master
  • 18,424 Answers
There are roller bearings at each end of the brushroll, they need replaceing
http://dirtdevil.com/file/295/
Posted on Jan 18, 2013
Roller brush pin spins off center
If you are describing the problem accurately, you need a new brush and new bearings (bushings). Once they get worn to egg shape, no matter how slight, the problem will only get worse.
Jan 18, 2013 | Dirt Devil UD70095 Bagless Upright...
Brush won't spin when carpet cleaner is running
see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearing. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly itself might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might be jammed. Try removing the brushroll and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning the cogged belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
Sep 27, 2012 | Vacuums
How to change g5 belt
1)First, you turn the square belt lifter on the front of the power nozzle until the red arrows line up (belt off)
2)Remove the power head from the front of the machine. Now turn the belt lifter the other way and line the green arrows up again. This releases the tension on the belt
3)Turn it upside down and release the two clips that hold the metal baseplate on and remove the baseplate.
4)Grab the brushroll and pull it out of the power head. Slide the new belt onto the center of the brushroll. It will hang loose...it doesn't have to stretch around anything yet. MAKE SURE THAT THE BRUSHROLL SPINS FREELY!! If it doesn't, you'll burn all new belts quickly due to the added strain on the belt.
You can get a replacement belt here:
Kirby G5 Replacement Belt
Nov 02, 2009 | Kirby G5 Bagged Upright Vacuum
Loud screech when engaging brush
you will need to have the clutch change or the brushroll replaced. to change the brushroll you will need a special belt tool. you can get one on ebey for about $15. you could call dyson and find one of the service centers in your area.
Oct 13, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do i fix my bissell myself cause it wont **** up trash after i picked up the lager things that dont go in a vacuum
You may of damaged the belt that moves the brushroller. Also check for clogs in the system, there could be something blocking.
If you take apart, make sure to be mindful of what screw goes where.
Aug 11, 2009 | Vacuums
Cant seem to get the green light going on vacuum head,hook seems to be wrong way when its should be hooking the band off its doing the opposite
2)Remove the power head from the front of the machine. Now turn the belt lifter the other way and line the green arrows up again (belt on).
4)Grab the brushroll and pull it out of the power head. Slide the new belt onto the center of the brushroll. It will hang loose...it doesn't have to stretch around anything yet. MAKE SURE THAT THE BRUSHROLL SPINS FREELY!! If it doesn't, you'll burn all new belts quickly due to the added strain on the belt. New brushrolls are available here...  NEW KIRBY BRUSHROLLS
5)Look at the ends of the brushroll. The brushroll has three height settings...you should see notches AND  NUMBERS on the sides of the brushroll's end caps. ONE notch (also #1) FACE UP on BOTH sides is the first setting and should be used when the roller is new. Three notches is the last setting used before a new roller is needed and should be used if the brushes are short and worn. Put the brushroll back in, making ABSOLUTELY SURE sure that the SAME NUMBER of notches and the same raised number on the edge are FACE UP on BOTH sides. This is important, as the brushroller will be unbalanced if inserted wrong.
6)Replace the baseplate by fitting the front clips into place and then push it down in back and secure it with the two rear swivel clips. Make sure it fits securely down over the bumper on all sides with no suction leakage.
7)Turn the belt lifter to where the RED arrows line up, making sure that the inner "hook" grabs the belt and stretches it up while you are turning it. Once you have the belt stretched up, put the power nozzle back onto the Kirby and lock it in place.
8)NOW...turn the belt lifter back to GREEN. If the little green light on the power nozzle lights up when you turn it on, CONGRATULATIONS!!! The brushroll is spinning!!
Apr 18, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I need help changing belt on my Eureka Optima
If you're not familiar with how the vacuum is put together, taking it apart can be a real pain. Thankfully, most of the screws on the unit are the same size and type. For the ones you need to remove, a #2 Phillips should do the trick.
Unplug the vacuum, and flip it over, flat on the ground.
Press the silver button on the neck where the roller head attaches to the body and pull the head off. This isn't completely necessary but it makes it easier to work on.
Remove the 12 screws holding the case together. There will be 2 smaller (I think) screws by where the head swivels. Keep track of those.
Once ALL the screws are removed, the case should be loose and pretty easy to remove.
Flip it back over and carefully move the top cover to the side.
If you're looking at the piece head on as if someone were vacuuming facing you, the belt side of the brushroll should be on your right.
Remove the far side (non belted side) of the brushroll first by lifting it straight up.
The belt should be slack enough to remove the belted side of the brushroll and replace the toothed belt.
When reinstalling the brushroll, stretch the belt a little and put that side back first. Trying to get the belt side in after doing the far end takes too much effort.
Make sure the belt is tracking straight by rotating the brushroll and adjusting the belt as needed.
Since it's all opened up you may want to give it a good cleaning too.
Reverse the rest of the steps to put it back together.
Sep 13, 2008 | Eureka 431A Optima Bagless Upright Vacuum
The belt is loose on the bottom
Here is the link to the detailed instructions for belt changing. When you take the brushroll out, make sure that the brushroll spins freely. If it doesn't it will burn up your belts and needs to be replaced. (brushrolls available also by using this link)
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps...
Marci
Jul 30, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Brush roll not spinning
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=453845
Brushroll not spinning
Posted by vistaloopy on Mar 19, 2008
I have a Eureka Bagless Optima 431 Lightweight Upright that is not working. I took it apart to clean the brushroll and have tried to put it back together several times, but the brushroll will not spin anymore. Maybe I'm putting the belt in the wrong spot? Where can I find a diagram or something?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. You have only 2 choices, the belt is either side driven belt or the belt is a center driven belt and the brushroll has one side that is for the belt and the side driven brushroll and the motor pulley must be in line in order to work properly, you may want to check the bearing holders, some vacs will mark the ends with words like NEW or USED and both have to be identical in order to fit right. Once you have the brushroll out it should spin if you set it on it’s side and if that happens you are OK, then watch the ends of the brushroll. Align the end with the motor pulley, B4 install the belt place the belt on the pulley side and install the brushroll. Then once the brushroll is in and spins properly, and then you can use a belt puller and stretch the belt onto the motor pulley and then track it in a straight line. If you need further help please feel free to contact your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Mar 19, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Dirt Devil UD70095 Bagless Upright Cyclonic Vacuum Logo
76 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
