Question about NetGear WGR614 Wireless Router
NETGEAR WGR614v7 Network Security key
PLEASE HELP ME "ASAP" HOW TO RETRIEVE MY SECURITY KEY on my NETGEAR Wireless Network Properties thru WPA-Personal (Security type) TKIP ( Encryption type)
as of now i set it as:
Security type: No Authentication (OPEN)
Encrypion type: NONE
Security Key: ?
whenever i set it to my old settings i cant connect wireless...
Please help...
  • 55 Answers
Hi, you need to connect to the routers admin pages to configure the wireless settings and security. Check out this page:-
http://kbserver.netgear.com/kb_web_files/n101676.asp
When you get to step 6, click the WPA-PSK security setting and it will give you a box to type in a password of your choice, make it memorable but difficult to guess, so a mixture of numbers and letters. I think its a min of 8 characters.
Hope this helps..
Posted on Jan 25, 2009
I wan't to use the signal from my router on my desktop for my tabler , But I forgot my password ?
If you have a laptop or other device which has previously accessed the wireless router, you should be able to retrieve the router security key (password) from that device.
If that device is running Windows Vista/7/8, you can read the security key directly. In the system tray (lower right corner), click on the Wi-Fi signal icon, then right-click on the entry for your router, and select "Properties". When the properties box appears, the security key will be hidden; to display it, place a check in the "Show Characters" box. (See diagrams 1&2, below.)
Alternatively, you can install a software program on a computer that has accessed the router, in order to retrieve the security key. My suggestion is "WirelessKeyView", a Windows freeware program from Nirsoft. See: http://www.nirsoft.net/utils/wireless_key.html That will display all of the router security keys stored in that computer, under the "Key ASCII" column. (See diagram 3, below.)
Sep 01, 2012 | NetGear WGR614 Wireless Router
Tip
How to check wireless security key or passphrase on NETGEAR routers.
Most of the times after configuring the wireless connection on the NETGEAR ROUTERS, the user either forgets the security key or misplaces it.
In order to get this key we need to login to the router's page using any computer which is physically connected to router. The below steps are applicable for most of the NETGEAR routers.
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually by typing 'http://192.168.1.1' or'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that Username and Password are case sensitive).
4. Click on Wireless Settings (under Setup) from the left menu.
5. Check if WEP (Wired Equivalent Privacy) or WPA-PSK (Wi-Fi Protected Access Pre-Shared Key) is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase(or network key).
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the router's wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new Password and click apply. You will then have to use the same Password for all the wireless devices connecting to the network.
Hope the above steps will help the user to locate or reset the wireless security key.
on Feb 10, 2010 | Computers & Internet
Reset password on wireless router
That more than likely mean you have put the password in wrong or you are using the wrong authentication type.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the WirelessNetwork Connection and select Properties. When the Properties window openclick the Wireless Networks tab. Click on the SSID for your wirelessnetwork that you connect to and the Properties window will open. You canchange the Authentication Type to match the type set in your wireless routerand you can also change your password or Network Key to make sure you have itin correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left ofthe open window and click Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center thenlook to the left and select Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
Jun 08, 2012 | NetGear N300 Wireless Router
How do I find the WPA to set up wireless connection on my new laptop
    • 1 Right-click on your network bar in the bottom right corner and click "Open Network and Sharing Center." You can also click "Start" and type "Network and Sharing Center" in the search box. Click on the Network Sharing center link in the search results list.
    • 2 Click "Manage wireless networks" on the left-hand pane.
    • 3 Highlight the network you wish to retrieve the WPA or WPA2 security key from; right-click it and select "Properties."
    • 4 Click the "Security" tab to see the security settings. The type of security will be listed along with the encryption type and security key. The security key will be hidden.
    • 5 Check the box labeled "Show Characters." The network security key will now be visible.
Apr 12, 2012 | Zonet ZSR4154WE Router
Lost my security key... can it be replaced by a new one (Netgear WGR614v7) Thanks
just reset your access point an reconfigure it you can use the manual came with the Netgear WGR614v7 if you lost it just google for it
Apr 10, 2010 | NetGear WGR614 Wireless Router
Netgear wireless router wgr614v7 not transmitting a signal anymore. everything seems fine but it's not pumping out the signal.
Dude try the following steps it will help,else let me know the exact problem
  1. Click Start > Connect To > Show all connections, and then double-click your wireless network.
  2. Click General > Properties.
  3. Click the Wireless Networks tab.
  4. Under Preferred Networks, click your home network and then click Properties.
  5. Click Authentication, then clear the Enable IEEE 802.1x authentication for this network check box. (If you cannot click the check box, then you are not using 802.1x authentication or wireless security.)
Dec 29, 2009 | NetGear WGR614 54Mbps Wireless Router...
When I install it says Card unplugged when it is firmly plugged in
i have netgear wgr614v7 and a broadband connection working without security code, when i tried to configure to put a wep i reset the netgear and now it is not working . what should i do to have a connection via netgear and with security password
Dec 04, 2009 | NetGear WG511T 108 Mbps 802.11b/g Wireless...
Trouble connecting on my NETGEAR WGR614v7 router. I'vechecked all the cable & surely they are all correct. I've change the security network key on my security network properties. Please help asap!
Hi there are you using this wirelessly? it sounds that the network key on your PC doesnt match to the one that is stored on the router. therefore you will not be able to connect.
Jan 25, 2009 | Computers & Internet
I cant connect thru my netgear router model wgr614v7
If you hook your PC directly to the router using an Ethernet cable you don't need the key. You can log into the router and change the WEP Key to anything you want, but u have to be directly connected to the router not going through the wireless.
Jan 25, 2009 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
1,524 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
