Question about Gateway Computers & Internet
Clock resetting and power button malfunctioning on my Gateway NV53A laptop.
I have a Gateway NV53A laptop, and I've had two problems starting today. First of all, the time on the clock keeps resetting. Secondly, several times today, it's been plugged in to the wall, but turned off, and when I press the power button, nothing happens. It won't turn on. However, if I switch to a different plug in another room, it turns on fine. But then, if I let the screen time out or turn the computer off, the same thing will happen: I press the power button, nothing happens, switch to another plug, press the power button, and it turns on fine. Any ideas???
  • Gateway Master
  • 7,627 Answers
Replace the CMOS battery. In the Control Panel, Power Options, set to High Performance, open Advanced power settings, set Sleep and Hibernate to Never, Adjust other settings to your preference. Set Screen Saver Time. Always turn off the computer and unplug when not in use, it will prolong life and a reboot every day will reset the computer. I would say you have a issue with the outlet connections/plug. If you have a multimeter you can verify.
Posted on Jan 18, 2013
  • 5 Answers
SOURCE: won't turn on
Sometimes it is the battery not holding the vharge. If that is not the case then it most likely is the adapter connector on the mother board where there could be a broken solder connection or the connector itself may be broken. I had the same problem with my hp laptop and disassembled it abd found a broken solder connection to the motherboard and the adapter connector. I just made a solder connection where it was broken and everything came on normally.
Posted on Jun 10, 2008
  • 998 Answers
SOURCE: Laptop won't boot (display problems)
If the diagnostics displays on the LCD screen but you get no display when Windows starts to load, it sounds like you have a video software driver problem. Try tapping the F8 key when you power on your laptop and boot in Safe mode. If it works in safe mode then you need to check you driver. You can also try connecting the laptop to an eternal monitor and see what happens.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 09, 2008
  • 90 Answers
SOURCE: Dell Precision M60 won't start up
Without battery connected it wont work. Better buy a new batterry connect it and plug it for charging for 8Hrs conitnuosly without switching on the laptop.
Posted on Apr 20, 2009
  • 3 Answers
SOURCE: my laptop won't power on (EliteGroup G320 PC Notebook)
Sounds like the infamous electrolytic capacitor plague (see http://en.wikipedia.org/wiki/Capacitor_plague -- also read the discussion page)
In the early years of this century chinese spys stole a formula for novel electrolyte from a leading Japanese chemical company but unfortunately they only copied page 1 of the two-page recipe. The incomplete electrolyte went into many millions of capacitors reducing their life span dramatically. I understand these capacitors were made until 2004. That's about the time the G320 was manufactured, at least mine.
I opened and disassembled everything, I saw some "swollen" 1500uF/6.3V capacitors, replaced them and the G320 would start again.
This may sound easier than it was, however. I live in a country where computers aren't made no more and spare parts are hard to find. The G320 has 4 of the above caps in upright position and 4 placed horizontally. I could only get some larger types that do fit horizontally but not vertically. Thus I had to replace a bad vertical one by one of the remaining good horizontal ones and then replace the horizontal ones by the bigger ones.
Warning!
If you re-assemble your G320 make sure you use the shortest 3 screws for the the points where the upper cover is fastened to the metal sheet frame that presses the cpu against the heat sink. If you use a longer screw (which I did) you may experience that a destroyed 4x56 ohms resistor network chip on the mainboard can also be hard to be relaced in non computer producing countries.
Mittwoch
Posted on Nov 14, 2009
leecom72
  • 4806 Answers
SOURCE: Toshiba Satellite C655-S5082. Won't power
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Posted on Jul 16, 2011
Gateway ethernet controller driver
Use a USB flash drive on the computer you can access the internet on and save the driver files onto it. Then transfer them to your Gateway NV53A laptop.
How to Save Files to USB Flash Drive
Jun 28, 2014 | Computers & Internet
Gateway NV53A 15.6 inch Notebook, touch pad not working
Touchpad settings: right click on the touchpad icon on the Taskbar at the bottom right of the screen. Click on Default button, then Apply, then OK. Re-try. If that doesn't fix, then TouchPad ribbon inside the laptop needs to be replaced.
Feb 09, 2014 | Gateway MT3705 Notebook
I have a gateway NV53a Batt went dead wont start correctly since
Try removing the battery and see if you have any issue just using the power cord. The laptop may be detecting issues with the battery causing it to malfunction. If that is the case just replace the battery with an OEM (original manufacturers) part.
Oct 27, 2013 | Gateway Computers & Internet
Delete hardrive on a gateway nv53a
To delete a harddrive you would go into BIOS Setup, and remove.
(Main menu, or Standard BIOS options (setup)
Was there a previous harddrive, you installed a new one, and the old is still showing up, or what is going on?
http://support.gateway.com/s/notebook/2010/gateway/nv/nv53A/NV53Asp2.shtml
My intel indicates press F2 to enter BIOS Setup.
The best method I've found is;
AS SOON AS you press the Power On button, start tapping on the F2 key.
You may hear beeps as you do.
Those are Stuck key Error Code beeps, and it is you that is doing it.
Ignore them.
If you do not know how to navigate in BIOS Setup, or save changes; post back in a Comment.
Totally way off? Post back in a Comment.
Regards,
joecoolvette
Feb 22, 2013 | Acer Gateway NV53A36u
My touch scroll stopped working for my Gateway NV53A. Can I fix it?
1_9_2013_6_10_09_am.jpeg check it first , by , connect a mouse , go control panel disable it , and use mouse ,turn the notebook , turn on & enable it , may be works , other wise hardware problem.
Jan 09, 2013 | Gateway Computers & Internet
It isn't charging
For this kind of issue, please follow up the following steps to check:
confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
Oct 28, 2012 | Gateway NV53A NV55C NV59C NV73A Acer...
Gateway M 6843 won't turn on
You may have already done this, but remember many laptops require that you remove the battery for about 30 sec. as
well as disconnect the AC power to reset them.
Always try this when everything appears completely dead.
Source: pcsupport.com <<<and it's worked
Aug 28, 2012 | Gateway M-6843 Notebook
What's your problem?do u have to use a specific external USB connected dvd+-rw/cd rom combo drive with gateway NV53a laptop
No, the U in USB stands for universal. Provided that the device has drivers for the PC operating system all will be good.
Oct 03, 2011 | Computers & Internet
Upgrade video card or increase video memory on a gateway NV53a
Unfortunately, there isn't any way to increase the video performance of this model. Only very few laptops have interchangeable video cards and this isn't one of them, sadly. Video RAM can sometimes be increased in the BIOS by hitting F2 when the computer is first starting up (during the Gateway screen) and fiddling around with that, but it's probably a long shot because usually only enthusiast laptops have that function.
Aug 23, 2011 | Gateway NV53A24u Laptop
Gateway Laptop(MODEL M-6750): The power button keeps flashing blue and so does the wireless signal. I've tried removing the battery, holding the power button nothing changes.
Does it do this when it is plugged in? Try to power it up with no battery, and see if it acts differently, it may be a battery issue unsure. Is the computer working normally except for this problem?
Jun 10, 2011 | Gateway M-6750 PC Notebook
Computers & Internet Logo
287 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
