Question about Honeywell Furnace Air Pressure Switch 1013802 2.00" Wc
My heil heater is not firing up
It try's to light but it won't light I don't hear the air pressure switch click at all
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 37 Answers
Take the hose off the exhaust fan assemby and suck on the end and you should hear it click try sticking a paper clip or something like in the hole where the hose coonnect on the exhaust hosing sometimes some junk just gathers there
Posted on Jan 18, 2013
The hot tub Hester will not light up pilot but does turn on and bow cold air
Glenn,
Many things could be wrong. First off, the exhaust fan turns always goes on when you turn on(up) the thermostat. It does that to suck out any residual gas in the combustion chamber. After about 10 seconds you should hear a click which is the gas valve opening to let the gas into the chamber. You should also hear a series of clicks for about 10 sec, which is the electronic ignition firing. If you hear the clicking of the ignition, but do not smell gas from the exhaust, then the gas feed is being blocked. If you don\'t hear the ignition clicking then the computer board is detecting a fault condition by one of its sensors: over-temp, water flow, exhaust fan . These are all in series and if one doesn\'t pass then the ignition won\'t fire.
Jun 08, 2013 | Pool & Spa
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
2 flashes wont light
SOUNDS LIKE A PRESSURE SWITCH MALFUNCTION OR A OBSTRUCTED FLUE EXHAUST. 2 FLASHES MEANS YOU ARE IN SYSTEM LOCKOUT. ATTEMPT TO START 3 TIMES THEN IN LOCKOUT MODE RIGHT? YOU WILL NEED TO TURN OFF AT T-STAT OR BREAKER TO RE-SET UNIT, OR WAIT 60 MINUTES & IT WILL DO IT AUTOMATICALLY. WHEN IT CALLS FOR HEAT THE DRAFT INDUCER MOTOR WILL COME ON, THIS WILL CREATE A VACCUM THAT OPENS THE PRESSURE SWITCH PROVING DRAFT INDUCER IS VENTING, THE VACCUM CREATED CAUSES THE PRESSURE SWITCH TO OPEN PROVIDING POWER TO THE IGNITION CONTROL. THIS IS WHERE YOUR PROBLEM IS ACCORDING TO YOUR DISCRIPTION. TRY TO DISCONNECT VACCUM LINE FROM DRAFT INDUCER MOTOR & SUCK ON IT WHILE LISTENING FOR A CLICKING SOUND AT PRESSURE SWITCH. IF YOU DON\'T HEAR THE CLICKING SOUND WHEN YOU DO THIS, THEN YOU NEED TO REPLACE THE PRESSURE SWITCH. IF YOU DO HEAR THE CLICKING SOUND THE PROBLEM IS WITH AN OBSTRUCTION IN THE FLUE VENTING. THIS IS SOMETIMES CAUSED BY DEBRIS GETTING LODGED IN THE PORT AT INDUCER MOTOR WHERE THE VACCUM LINE FROM PRESSURE SWITCH IS CONNECTED. TRY TO CLEAR OBSTRUCTION WITH COMPRESSED AIR OR A WIRE HANGER. THIS SHOULD FIX YOUR PROBLEM. GOOD LUCK. HOPE THIS WAS HELPFUL.
Dec 24, 2012 | Mr. Heater MHU45NG
York furnace won't ignite
Is the igniter receiving 120 volts after the pressure switch closes? If not, either the board is bad or the pressure switch is open
Nov 27, 2012 | Heating & Cooling
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
94 gmc sierra 4.3 v6 manual, won't turn over, can hear fuel pump start when accessories turned on..won't fire, girl who needs help
The first thing I would check is fuel pressure. This type of fuel injection requires a minimum fuel pressure in order to operate. If fuel pressure is as little as one psi below minimum the vehicle will not start. You can try squirting a couple of shots of carb spray into the air snorkel while somebody cranks the engine over. If the engine starts and then dies you now you fpdeffinetely have a fuel issue. If the engine still won't start check for spark. Let me know what you find. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Feb 07, 2012 | GMC Sierra Cars & Trucks
SR400NA will not fire. All operations seem normal, gas valve clicks loudly, but no gas flows. Igniter new this season, gas valve replace due to rusted terminal, but this is a new problem.
It is possible there is no gas pressure or the gas pipe contains more air than gas. There is a port with a plug in it close to where the gas enters the valve body. If you carefully loosen to plug a small amount of gas will leak out if there is gas pressure. Make sure you don't screw the plug all the way out or you may loose it. If there is no pressure then you know that a valve is turned off upstream of the heater somewhere. If there is gas pressure then when the gas valve is energized you should be able to hear gas or air coming through. If you hear this gas and the ignitor is not able to light it then either there is something wrong with the ignitor or the gas has too much air in it. Another possible problem is if there is dirt or rust in the gas line it could clog parts of the system like the a regulator, valve or orifaces. I hope this helps.
Please vote on this answer. Thank you.
Aug 25, 2011 | Sta Rite Sr400na Max E Therm Pool & Spa...
When my trailblazer over heats. there is fluid that leaks out of a drain hose on the fire wall. why is it?
Sounds like you may have water leaking out of your heater core.
This will cause an overheat condition, which you get because your engine cooling system can't pressure up as well.
You may also notice a kind of "sweet" smell to the air that comes from the air vents that blow when A/C or heater is on.
As water leaks into the A/C & Heater core compartment area...it trickles to the overflow drainhose on the firewall. This is usually intended for the condensation of the A/C core but a leaking heater core will drain that way too.
From what I hear, I'd see about disconnecting the heater core hoses going into the firewall and maybe use a splice to connect them to each other OR get a two 5/8 bolts and a couple clamps and plug the hoses.
This allows you to drive car without overheating and buys some time to get you another heater core (basically a "mini-radiator") Its summer, so you don't need the heater right now but keep in mind...you won't have a heater until the core gets replaced.
Hope this helps...
Aug 13, 2011 | 2002 Chevrolet TrailBlazer
Furnace wont start. heil gas furnace. on initial
Yes, inspect the air intake, exhaust pipe, filter and condensate piping for blockage or moisture. Also check for a hole in the hose that goes from the small exhaust blower to the pressure switch or a bad connection on the switch or control board. You may be able to temporalily jump the switch for diagnostic purposes only.
Oct 17, 2009 | Heating & Cooling
Honeywell Furnace Air Pressure Switch 1013802 2.00" Wc Logo
91 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
