Question about O2 Xda Atom
Water issues xda atom exec went thru washing machine. when charging top light goes orange but cannot switch on. no insurance / warranty on product. is it repairable? I believe it was on when it went thru machine. many thanks.
  • Anonymous Apr 04, 2009
    my phone went into the water, now the touchscreen totally not sensitive and i cant use my handphone for anything! even to make outgoing calls!
    Problem Solver:
  • 7 Answers
Not repairable through warranty sorry
Posted on Jul 13, 2007
SOURCE:
Salam sejahtera buat master.nih mau nanya gprs konek wierles jg konek tp gak mau browsing hp saya o2 xda atom exec. gmana mohon petunjuknya.trims
Halo P' Giarto, Salam sejahtera,
Bapak pake operator apa? Biasanya tiap operator memakai kebiasaan buruk sendiri2 ( membuat set up yang berbeda beda satu dgn lainnya). Di Indonesia sebaiknya bapak ke kantor cabang operator saja, suruh dia setting dan bapak tinggal nunggu saja. Biasanya akan butuh penyettingan user name, password( kadang ini gak ada), Proxy dsb. Utk + perbendaharaan bapak bisa lihat links dibawah ini:
www.cnet.com.au/o2-xda-atom-exec-240063806.htm www.fixya.com/tags/o2_gprs
GBU, hrp divot, Jaya
Feb 01, 2011 | O2 Xda Atom Exec Smartphone
My Phone does not switch on.
Perform a hard-reset.
At the expense of your data-loss,
atleast you get your device working back.
To perform a hard-reset on your O2 Xda Atom,
Keep pressed the POWER key, and then perform soft reset. After the device this leave everything and confirm that you want to hard-reset as shown on the screen.
Please rate...
Sep 12, 2009 | O2 Xda Atom Exec Smartphone
My o2 xda atom doesn't charge. i don't know if its the battery.
I think the problem is your battery... and you think that your battery is OK then you can try charging it the computer through USB.
Nov 13, 2008 | O2 Xda Atom Exec Smartphone
O2 dxa atom exec software repair
i have o2 xda atom exec comera is not working properly
Sep 06, 2008 | O2 Xda Atom Exec Smartphone
O2 xDA Atom Exec Screen Blank After SofReset
Couple of things you can try to fix the issue, firstly try a hard reset
To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device. *Note: Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost
Try that and if it doesnt resolve the issue then we can try another solution
Aug 23, 2008 | O2 Xda Atom Exec Smartphone
Instructions
here you can get user manual: http://www.myacrobatpdf.com/7883/o2-xda-atom-exec-user-manual-english.html
May 03, 2008 | O2 Xda Atom Exec Smartphone
While charging my O2 atom exec, the LED (Flash light) does not glow red ?
I have the same problem. What I did several time is to actually shut down the phone, remove the battery and leave it like that for several hours (3 to 4 hours). Then, I put the battery back in the phone, and it would charge again. However, due to the long time with no battery, the phone's clock would be reset to January 2007.
I found no other work around right now. However, I have to do this more and more often, almost once a week ...
Mar 21, 2008 | O2 Xda Atom Exec Smartphone
Computers & Internet Logo
62 people viewed this question
Top O2 Computers & Internet Experts
Ekse
xxxxxx xxx
Mufaddal  Kurlawala
Mufaddal Kurlawala
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
