Question about Whirlpool Washing Machines
Gsl9365eq2 whirpool ultimate care II - Whirlpool Washing Machines
  • 58 Answers
SOURCE: How to take the top off Ultimate Care II
2 screws behind control to loosen control panel. when out panel will hinge back and you should see 2 clips that will pop off with a screwdriver and harness for lid switch. whole cabinet will then come off iff you pull it forward
Posted on Oct 31, 2007
  • 262 Answers
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Posted on Dec 03, 2007
honeymokey
  • 3113 Answers
SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
Lid switch. Push down on lid.
Posted on Jun 18, 2009
washdryman
  • 154 Answers
SOURCE: Upper agitator on Whirlpool Ultimate Care II washer
replace agitator "dogs"
Posted on Mar 01, 2010
SOURCE: How to separate auger from agitator. whirlpool ultimate care II
When you look down into the agitator, are there 4 white plastic points that look slightly melted or otherwise deformed? If so, using a small flat head screw and a small hammer, separate the white plastic from the surrounding translucent plastic. Once you've done that, it should easily pull apart.
Posted on Jul 14, 2010
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    How to put belt back on whirpool ultra care II washing machine
    There's a very good video provided by PartsSelect which shows the process for replacing the drive belt on a Whirlpool Washer. Video link is below. Best of luck!
    Greg
    Sep 12, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirpool Ultimate Care II washer - drips
    Your water inlet valve is leaking through. Turn off the water. Remove the hoses from the washer. Clean the sediment screens in the water valve and replace the hose.
    If that does not solve the leak through problem,the water inlet valve will have to be replaced.
    Use the attached video to show how to access the inside of the washer in the event the water valve needs replacing.
    http://appliancejunk.com/forums/index.php?topic=5191.0
    Nov 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Ultimate Care II keeps taking water.
    ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
    Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing machine stops working
    I search in the internet on regards to the problems with the Whirpool Ultimate Care II and found out that many others had the same problem as I did. Some solved this issue replacing the switch, so i decided to do the same.
    I opened the machine and saw that the switch was not working properly, it was not doing any contact, so whenever I open or closed the lid, nothing was happening. I did a house fixing, with some duck tape i was able to make the system work, and now the machine is washing everything again.
    Nov 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    The load won't start.
    It sounds like you have a bad lid switch.It's an easy fix.You can get the part at your local appliance supply.
    Dec 09, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Remove top of machine, you will find lid switch or 'sensor' there. I would say its faulty ,and needs to be replaced.g,luck.rate me
    Dec 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    26 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
