Question about Maxi-Cosi Priori
Moving maxi cosi to another car
Baby staying with granny need tto change from vehicle to vehicle, can't find how to release isofix points to do this
  • 419 Answers
I assume that you mean the Maxi Cosi Priorifix?
At the top of the leg (that extends to the floor of your car) there is a button (which, if connected to the Isofix points will be red) push this button in as far as it will go and the seat will release from the Isofix points.
I hope this helps.
Posted on Sep 15, 2009
Maxi cosi easyfix base stuck in car. The button will not turn red or release the isofix points. Help please!
Hi
If you're in the UK please contact us directly for further instructions on removal of the product.
If you're not in the UK please visit www.maxi-cosi.com and select the country you're in, then choose the Contact Us tab on the right side of the screen for your enquiry to go through to the customer care department who can assist you.
Dorel UK Customer Service
Sep 08, 2013 | Maxi-Cosi Priori
Maxi-Cosi Familyfix base Isofix base warning beep
Yep, there's a switch underneath to turn off the sound, but the lights will still work.
Jan 31, 2013 | Maxi-Cosi Familyfix Base Isofix only
Does maxi cosi cabriofix easy base require anything to be removed from it before fixing it? we cant find where the button is that fixes it to the seat
Hi
Can you clarify - what button are you looking for?
The EasyFix base is fitted into the vehicle using the IsoFix points OR the 3 point seabelt. (Never both) The carseat then clicks onto the base and the metal rods on the underside of the CabrioFix carseat are grabbed by clamps on the base.
May 26, 2012 | Maxi-Cosi Maxi Cosi Mura 3 with Free...
How do I release the maxi Cosy cabrio from the family fix isofix
Press the button on the front of the FamilyFix base and it will release the carseat.
Mar 16, 2012 | Maxi-Cosi Baby Gear
Hi, I just installed the isofix base Maxi cosy isofix without the yellow adapter. Know I am worried this could be a problem without using the, Does all users have these on? Is it necessary?
Hi - The yellow plastic guides are only for your conveniance if you need them. Some cars have very prominant IsoFix points and you do not need to use the guides - this is fine. As long as the indicators go green to show correct fitting it is fine.
Sep 24, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Hi, I would like to ask a few questions: 1. Does the Maxi Cosi Cabrio car seat fits only to the isofix base, or can it be installed to the mico base as well ? If it does, the only difference is that the...
Good Morning
The Maxi Cosi CabrioFix can be fitted without any base, using the 3 point seatbelt: With the EasyFix base, using IsoFix points or 3 point seatbelt: With the EasyBase and EasyBase 2 using the 3 point seatbelt. It cannot be used with the Mico carseat base as they are not designed to be used together. The Mico is available in US and does not meet UK standards: Likewise the CabrioFix does not meet US standards so they should never be used together.
If you don't know how to fit the carseat into your vehicle using the 3 point seatbelt please check your user manual, or download a replacement copy at www.maxi-cosi.com before use go to an authorised retailer to check it is correctly installed as this will affect the performance of the carseat.
Aug 05, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I have lost the yellow plastic parts that make the isofix seat work. where can i get replacements?
Good Evening
The yellow plastic IsoFix guides can be ordered via your local retailer or direct with the customer service department on 01284 413 141 Mon-Fri 8.30-4.30. The RRP is £10 (set of 2) with £3.99 p+p if you order direct.
Bear in mind that these are guides only and may not be required. Some cars have the IsoFix points very prominant and quite high up so you can slot the IsoFix connections on without the guides; They are only to help if needed, if the IsoFix points are located quite deeply within the cushion of the vehicle seat.
May 20, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I have a maxi cosi cabriofix and need a base to go with it. Which base fits this model? What is the difference between the easy base and easy fix? My car does not have the iso fix adaptors so that will...
The Maxi Cosi CabrioFix can be fitted using the EasyFix base (IsoFix or seatbelt fitted) the EasyBase and EasyBase 2 (fitted with seatbelt only) or the FamilyFix base (IsoFix only). If you do not have IsoFix points you need either an EasyBase or EasyBase 2 to be fitted with seatbelt.
Sep 25, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
What's the difference between Easybase (non isofix) and Easyfix base (isofix)? can I use the second one for both maxi cosi cabriofix and car seat up to 3.5 year?
The Easy Fix Base is used for cars which have isofix points in their car. The Easy Base fits into your car using the seatbelt.
Both of these bases can be used ONLY for the CabrioFix Carseat and cannot be used for the next stage seat (Group 1).
I hope this helps.
Sep 25, 2009 | Maxi-Cosi Baby Gear
Maxi-Cosi Priori Logo
205 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
