Question about Rotel Audio Players & Recorders
Need volume control part for Rotel rx 875
Can't find pat #c-4170a09 50k2 x 2
  • Jimmy Jan 19, 2013
    I found a pot for my rx 875 after searching the net and making numerous phone calls.There is a place in Vancouver BC that sells parts for almost anything. I installed it and everything works fine. It's nice to have the old girl back, they just don't make things like that any more, built like a tank.
  • Jimmy Apr 20, 2014
    Found part
  • 20 Answers
SOURCE: DirectTV HD-DVR & Yamaha RX-v1500
The types of remotes are as follows
- Single item, or fixed. This unit will only operate the unit it came with
- Multi function, this type can operate the unit it came with and a fixed set of other types. Normally the remote comes with a list of supported device it could work with.
- Learning, the combine both a predefined list with the ability to learn functions by sensing input from the original remote.
- Programable. These are the newest remotes that work like multifunction but the list is maintained by the manufacturer and down loadable from the web.
I would guess that the DVR has a multi function remote.
If you can't find the specific Yamaha in the list, then
try another brand, this could take a while.
Some multi function remotes have an option that allow a semi automatic configuration.
You turn on the item and then using a special key sequence try to turn off the device. once the item turns off you should be able to control it.
If you can't the Yamaha has a learning remote. If you really want an easy solution try looking at a programmable remote. I just got a Logitech, (Harrmony). Life has never been so easy.
Posted on Apr 01, 2008
Basti
  • 1447 Answers
SOURCE: Connected Emotiva mps1 power amp
What cable are you using to connect MPS1 amp to Onkyo?
Posted on May 01, 2008
SOURCE: Rotel RX-800
I have an RX 600 - which has just gone 'phut' - which is how I came today to find this website ! I once had your speaker problem but eventually tracked it down to a bad connection of the speaker cable into the rear of the Receiver. Plastic sheathing and dust was partly in the way. Strip off a bit more plastic to expose fresh bright wire, and remake secure tug-proof connection before you try anything else. Oh, and while you doing it, do the others as well !
Posted on Sep 11, 2008
  • 118 Answers
SOURCE: Where can I obtain a Rotel RX-402 user or service
i hear the internet is good for that
Posted on Nov 04, 2009
Bennytechkid
  • 99 Answers
SOURCE: Yamaha RX-V800 volume control
i would say that the component that controls the sound level (called a potentionmeter) or (varible resistor) is either broken or faulty....you will need to remove the cover and inspect the area around the volume control just to make sure it is not broken or that any wiring has just become dry jointed....if all is good then what i would suggest to do is to find out the value of the pot...normally there around 10-50K then youll need to get a replacement...if this still dosen't fix it or your confident enough to look or fix it yourself i would take it to a local electronics repair shop....remeber to disconnect unit from power before removing cover hope this helps,ben
Posted on Jan 09, 2010
How to connect my Bose 901 series vI speaker to yamaha rx v740 and rotel rb 1582. Appreciate your help. Thanks
The Bose controller gets wired in series between the pre-amp and the power amp.
I presume you plan to use the 901's as the front L&R pair. So the cables going from the 740's Pre-Out Front L&R go to the inputs on the Bose controller. The outputs of the Bose controller go to the power amp Front L&R channel inputs.
Aug 17, 2014 | Audio Players & Recorders
Connected Emotiva mps1 power amp to Onkyo 875 and cannot control volume with master volume control knob, although can do so with Harmony controler.
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
May 01, 2008 | Audio Players & Recorders
Hi i have a Rotel Rsx 1067, powers up then off, the remote control is using new batteries, the receiver pickups the remote sensor but doesn't do nothing. volume control does not adjust up or down, and when...
Try fixing your remote controller, because sometimes when we neglected to replace our remote batteries for a while, it will leak and it will build up on the contacts of the remote pad.
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Good luck
Sep 28, 2010 | Rotel RX-965 Receiver
Hi, I have a Rotel 1050 receiver that I am trying to hook up to a NAD 2400 THX amp. I do not know how to "bridge" the connections so that the Rotel amps are not disabled. Any help is appreciated.
I think the best solution is to remove the jumpers from the Pre Out - Mon In connectors, insert a pair of RCA Y-adapters and plug one end back to the Mon In while the other ends feed the NAD (Page 15 of the manual available at Retrevo.com) . The Rotel's volume and other controls will still be in charge of the NAD.
The manual fails to mention looping the Pre Out back to the Mon In to enable the Rotel's amp to still participate in the program material.
Apr 10, 2010 | Rotel RMB-1095 Power Amplifier
Volume dial doesn't work well anymore - when turning louder, sometimes turns volume lower or just stays at the same volume level
Some manufacturers allow you to set a max volume limit so you don't blow your ears off.  Check the users manual to see how to turn it off.
Also, have tech support install a new potentiometer for you.
Oct 25, 2009 | Rotel RX-975 Receiver
Rotel RA01 amp - volume control
Make sure you connected your record player in the right inputs. Better try it to a line level auxilliary input that is sure to pass the volume control. hope this helps..
Sep 18, 2008 | Rotel Audio Players & Recorders
Rotel RX-800
Nov 26, 2007 | Rotel Audio Players & Recorders
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
richie46
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
