Question about Dolmar New Chainsaw PS-9010
My ps 9010 dolmar goes dead after about 10 minutes of running
Saw will idle fine all day. Once I start cutting with it, it goes dead after 10-15 minutes. I can crank it back up, but it immediately goes back dead if you give it gas.
    Sergeant:
  • 391 Answers
Tim:
The problem with your saw could be a few things. First, check the filter at the end of the fuel line in the tank. Sometimes the filter hangs up in a part of the tank where it is not totally submerged in the fuel. This can happen especially if you are doing side-cuts or tilting the saw. you may possibly need to adjust the fuel/air adjustment screws on the carburetor.
Posted on Jan 19, 2013
How to stop saw from bogging
Two things. First, is the chain dull? Second, if it develops a "throaty" sounds when you're cutting instead of the "crisp" sound you normally get from a chainsaw or weedwhacker or dirtbike... then the carburetor's running rich - it's "four-stroking". Try fiddling with the two mixture adjustment screws; one should be for idle mixture, the other for high-speed mixture. Get the saw idling and turn one of those screws clockwise ONE-QUARTER TURN. If the saw's idle doesn't change, turn that screw one more quarter-turn. if the saw's idle still doesn't change, thats the high-speed mixture screw.
If the saw's idle changes while you're doing that, then you're on the idle-mixture screw - return it to exactly where it was and adjust the OTHER screw clockwise a quarter-turn. Now try cutting - see if you've improved the saw's performance. If it's still four-stroking, try another quarter-turn.
If you go too far, the saw won't want to run at all at higher speeds... so you'd need to back up the screw the other way. Run it at the richest (most counterclockwise) position where it doesn't four-stroke under load.
Jul 25, 2014 | Dolmar Cyl & Piston Cpl Ps-510 - DM...
My Husqvarna 351 starts then stops after 1-2 seconds
Once the saw cools down will it restart and run fine? There are a couple other solutions that are not directly due to carburation. The first two solutions above are definitely your first options.
1. Ignition Coil: Highly unlikely, but possible. I seen some where they get hot and run fine while cutting, you shut it down for a few minutes for whatever reason and it won't restart or starts and stalls.
2. Crankcase Air Leak: We started to see more and more of these issues. There are a couple of quick ways to test this if you do not want to pay a shop to do an actual test. You want to do a cold test and a hot test. With a half tank of fuel, start the saw up for the first time of the day. While the saw is idling, turn the saw sideways from right to left, do this slowly, listen to the saw idle, if the speed changes by increasing or almost stalling, you have a crankcase air leak. Most bad air leaks won't be noticeable until the saw has gotten hot and the aluminum crankcase starts to expand a bit. Do the same thing once the saw has gotten hot. If this happens when it's hot, chances are that it won't start or starts and stalls until it cools down and everything retracts.
Test Results:
Sporadic idling when cold: Most likely just the oil seals, fairly inexpensive repair.
Sporadic idling when hot: Most likely crankcase itself is leaking, requires a complete crankcase gasket replacement. Can be fairly expensive to repair.
Apr 13, 2014 | Garden
Dolmar ps 34 or makita dcs34
Replace the spark plug and get some starter fluid. Add FRESH gas/oil mix. Spray a couple squirts in the spark plug hole, replace the spark plug and try to start it. I would add Sea Foam (get it at any parts store) to the gas tank and let it run for ten minutes. Go to the manufacturers website, support, and search for your saw by model/serial number.
Mar 15, 2014 | Garden
Fuel mix and slow/fast running jet ajustment Dolmar sach 119. starts easy wont pull under load.
Set both the high and low speed screws from lightly seated to 1 1/4 turns out. This will give you a rough setting that will allow the saw to start and idle. Set the idle screw to where the chain just stops moving at idle.
With the saw warmed up adjust the low speed screw out until the saw smokes a bit and acceleration is sluggish. Bring the screw in small steps until the hesitation is gone from the acceleration...you may need to adjust the idle again after this.
Now hold the throttle wide open and while it is wide open adjust the high speed screw in until the noise becomes smooth and the saw "sings". Do not leave it at this setting as it will burn down in short order. Once the saw is singing back the screw out until you can hear the saw's tone "roughen"....then back the screw out a tad more for good power / fuel under load.
That's it in a nutshell...here's a good link also...
http://www.youtube.com/watch?v=3Lw0pJcEPYo&feature=player_embedded
Dec 08, 2010 | Garden
Motor on miter saw is runnig back wards
I would suggest going to Milwaukeetool.com and typing in your model number and pulling up a wiring schematic for this tool. If your switch and field are not as shown on this breakdown (its a good one) I would either take it to a repair center or change what is wrong one wire at a time. They also have a toll free number and would be more than willing to help with your problem. Let me know and have a good day. P.S. I would not run the blade backwards though.
Jun 21, 2009 | Milwaukee Tool 10" Magnum Compound Miter...
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Once I start my 1994 Jeep Grand Cherokee it starts hestating.
check idle control valve mounting hardware & electrical connection on tbi. do not over torque bolts.
Mar 25, 2009 | 1994 Jeep Grand Cherokee
Engine intermitantly stalls
if this a fuel injected car just check to fuel pressure first.
Oct 24, 2008 | 1994 Pontiac Bonneville
Dolmar New Chainsaw PS-9010 Logo
126 people viewed this question
Top Dolmar Garden Experts
Dennis Key
Dennis Key
john h
Are you a Dolmar Garden Expert? Answer questions, earn points and help others
