Question about Sony Cyber-Shot DSC-T1 Digital Camera
Dsc t1 I need six srews holding the back and front together
I dropped the cameera and the six srews popped out. When I hold the camera together it works fine.
  • Sony Master
  • 586 Answers
    Due to hard jurk its body get misalligned and when the screws thightened the body it don't work.You have to change the upper case assy.And it will work fine again
You can contact any sony service centre nearby to you. For your convenience please visit:
www.sony.net
or
www.sonyworld.com
Here you can find contact info of nearest service centres.
Thanks for using FIXYA.
Posted on Jan 31, 2009
What are the factory settings for a cyber shot dsc-ti camera
Maybe she switched off the display try to found in manual how to switch it on
Mar 26, 2012 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony DSC-T1 not taking picture after I dropped it.
This is a problem with the LCD and/or possibly the optics in the camera. Typically happens when the camera is dropped or receives a heavy jolt. You will need to take it to a repair person or have the camera replaced.
May 06, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony DSC T1 - blurry screen and photo
It seems to be the issue with the CCD of the Camera. Until March 31, 2010, Sony will repair, free of charge, the following product models exhibiting the above-mentioned symptom where it is caused by the image sensor device.
Refer the following link:
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
You can also perform the below troubleshooting steps.
1. Press the reset button with a sharp pointed object when the Camera is turned ON. The Reset button is located near the Control button.
2. You can also power reset the Camera. To reset the Camera, remove the battery from the Camera, press and hold the Power button for 30 seconds and then, reinsert the battery.
Nov 07, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
My T1 is experiencing power problems. I have several batteries and when the camera is plugged in it shows the charge light but the batteries just dont seem to hold power for very long. It seems unlikey...
DSC T1 li-ion batteries goes bad in a period of 3 to 5 years of continusly use (daily). i will recommend to buy a spear charger that charges the batteries without using the camera.
Oct 09, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony camera screen black dsc t1
It is known problem of CCD Imager is DSC-T1 camera and that part will be replaced.
Sony will repair DSC-T1 Free of Cost in bad CCD Imager problem.
Click Sony CCD Support for details.
Feb 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Can't download photos from my Sony DSC-T1.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DSCT1
go to this site... choose the operating system you are using from the pop down list and get the software.
Robert
Please take a moment to rate this solution thanks
Jan 27, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Mechanical problem
Undo the six M2 screws that hold the left housing assemble (control panel for flash & focus etc) and remove You will see that there are 3 srews that hold the hinge assembly together all 3 wiil be loose and require tightening (you will neeed to tilt the lens up to see and tighten the third screw.
Reassemble the housing making sure not to trap thw flexible cable
Easy 5 min job
Jul 29, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
How to Remove the Lens Cover on a Sony DSC-T7
It is only six screws, and you have to GENTLY wiggly the front cover off....Start at the bottom, and wiggle side to side to get it unattached at the top of the panel. I just got mine off. I'm having black screen problems....
Jul 17, 2007 | Sony DSC-T7 Digital Camera
Sony T1 Questions and/or Suggestions.
If your camera has a scene mode that is called "high speed", "sports", or "action", you can try using that scene mode with flash. Other than than, there is no way to adjust the shutter speed. There are several factors working against you. The T1 has a very weak flash (4.9 feet) and it will move the adjustments toward more light, which means slower shutter speeds. All light weight, small cameras are more difficult to hold steady. If it has a viewfinder, using the viewfinder will help because you are holding the camera to your head; which is steadier than your arms held out in front of you. Resting you hand on a solid object is a good solution, but not practical all the time.
Sep 08, 2005 | Sony Cyber-Shot DSC-T1 Digital Camera
Picture Blurry on the Sony DSC-T1
Put it on a tripod, and don't move it until the picture is captured. At the very least, hold it steady for several seconds after you press the shutter button. You are probably moving it while the shutter is still open recording the image. Digitals do this in low light situations. I frequently get caught by this because I think 'Click. I'm done. Move on.'
Sony Cyber-Shot DSC-T1 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
