Question about Nokia N73 Cellular Phone
N73 Bluetooth problem
When I tried to switch on the bluetooth it says ''bluetooth operation failed''
Its not working at all..
  • 2 more comments
  • Anonymous Jan 29, 2009
    ?š?¾?³?´?° ? ?¿?????°?»?? ?¿?µ???µ?¹???¸ ?½?° Bluetooth ?³?¾?²?¾???¸????''Bluetooth ?¡?±?¾?¹ ?¾?¿?µ???°???¸?¸''
  • freelancer_9 Mar 30, 2009
    whenever i go to enable my bluetooth it says bluetooth operation failed....HELP!
  • dipak mistry Apr 10, 2009
    when i switch on the bluetooth it sawing unable toperform bluetooth operation. please solve this problem
  • bhanuchandu Oct 14, 2011
    how to solve the bluetooth problem
Try open your Menu, then go to Tools. Open Tools function and go to Transfer and open it. You will see "Transfer Data". Press Option and Select to transfer. You will have to switch On your Bluetooth. Try switch it on from there. I've tried it and it works for me.
Good luck...
Posted on May 31, 2010
2 Suggested Answers
tech-hero
  • 66 Answers
SOURCE: Unable to switch on Bluetooth
Just restore your phone to factory settings. It is mostly a software problem. After setting it to factory settings, it must turn back again. try it. just save your important files first. do backups with your messages and contacts and other stuffs in the phone memory.
Posted on Jan 25, 2011
"Can not Perform bluetooth operation", is the message that comes always when i switch the bluetooth on
"Can not Perform bluetooth operation" is happen due to many reason it may damage bluetooth IC or corrupt your phone operating system (it may some time work properly and some time not)
follow the following solution it may be helpful for you
1.ensure your phone batary is full
2.remove memory card
3.type *#7370#
it will make hard reset of your device, careful it will erase all the details of your phone including contact numbers and don't interrupt the process it may damage your device
if it's still happening you have to change bluetooth ic don't try to do it if you not enough competent
thanks for watching
Oct 01, 2013 | Nokia N73 Cellular Phone
Unable to switch on Bluetooth in nokia N73. if i tried to select ON option the result is unable to perform bluetooth operation
Jan 25, 2011 | Nokia N73 Cellular Phone
My N73 shows Unable to perform bluetooth operation
sir in your cellphone the bluetooth device is failed give to the nokia service center for changing the new bluetooth device....................
Dec 25, 2010 | Cell Phones
Swith on the bluetooth it says unble to perform bluetooth operation
This is due to presence of background application trying to use the bluetooth interface.
>try to rename the phones bluetooth name to nokia >rstore the factory seyttingd
if still this fails >backup everything on the phone and switch it OFF >>Now PRESS the keys "3" + '*" +"call" and then the power button simultaneously. this should format the phone and apply factory restore. everything will be fine.
>restore the backup.
Nov 30, 2010 | Nokia N73 Cellular Phone
My bluetooth is not working in N73 mobile .When i turn on my bluetooth this error appears " unable to perform bluetooth operation " can some1 tell me why ?!
My Bluetooth is not working in N73 mobile .When i turn on my bluetooth this error msg appears " unable to perform bluetooth operation then plz help me someone
Mar 06, 2010 | Nokia N73 Cellular Phone
N73 when i try to open bluetooth application it show error msg as unable to perform bluetooth operations wht to do ??????? please suggest once i had already restored by*7780# still same problem continues
The error massege shows as unable to perform bluetooth operations when memory is full.
Try to delete some of the data applications and try to perform the bluetooth operation.
Even if you find the same problem to perform bluetooth the remove the battery when the mobile is switched on and remove the sim and reinsert after 2 mins.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 09, 2009 | Nokia N73 Cellular Phone
Got a message on my Nokia N73 'unable yo perform
sir just hard reset your phone hard reseting code is *#7780# type this on your phone`s keypad it will not delete your any data
Sep 09, 2009 | Nokia N73 Cellular Phone
Nokia n73 bluetooth not work
Have you activated your bluetooth? You won't be able to use it before you have activated it. Find the bluetooth - should be under extras or applications and select "on".
Mar 17, 2009 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
1,880 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
