Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Not getting spark to plug on eagerbeaver 2014
    Sergeant:
  • 391 Answers
Jeffuxum:
The magneto is probably where the problem is. You'll need to pull the cover off of the motor and check the gap between the magneto and the flywheel. If the bolts holding the magneto have vibrated loose, the gap between the magneto and the flywheel will be incorrect. While you have the motor cover off, check the wiring to make sure you don't have a short in your ignition wiring and clean the air filter. I don't remember what the gap is between the flywheel and magneto, but .010 In. sounds familiar. Both legs of the magneto should be the same distance from the flywheel and they must not touch the flywheel at any point. I have used a matchbook cover between the flywheel and magneto while I tightened the magneto retention screws and it worked.
Posted on Jan 19, 2013
The engine starts fine, but why doesn't it rev when I press the trigger?
Have you checked the throttle linkage to the carb.?
Apr 21, 2016 | McCulloch Garden
How do you get to the spark plug wire connectors volvo s60 2014
This car does not have spark plug wires. It has 5 individual coils located under the plastic cylinder head cover tha is held down by 6 or 8 number 30 torx screws.
Sep 23, 2015 | Volvo Cars & Trucks
How do I change spark plugs on a Hyndai Accent 2009?
Hyundai Accent How to replace spark plugs - YouTube
? 3:21
www.youtube.com/watch?v=TQSplCznN9c
Jan 15, 2014 - Uploaded by Dima Travnev Hyundai Accent How to replace spark plugs ... Part 1 2009 Hyundai Accent tune up Spark plug replacement in 720pHD - Duration: 14:00. by ...
Sep 09, 2015 | Cars & Trucks
My 2014 dodge avenger was in a flood won't turn over no water in oil or fluids but air filter wet. Battery, lights, windows and locks work fine. Do I have spark plugs and distributor cap?
Yes you have spark plugs, No you don't have a distributor cap, With the air filter being wet you might have water in on top of one of the pistons and it stops the engine from turning over. Remove the spark plugs and rotate the engine with the starter to eject any water off the top of the pistons re-install the plugs and try starting it
May 31, 2015 | 2014 Dodge Avenger
How do I start a floode 2014 polaris sporstman\
2 ways f you have a gas shut off on the bike you can shut it off and turn the bike over a few times to dry it out . best way is to remove spark plug blow it dry be carefull not to bend the prob. or just replace the plug any one should help you get it going if you have spark
Sep 15, 2014 | Polaris 2014 Sportsman 570 EFI
The spark plug keeps getting wet every time i take it out its a ktm 85 sx 2014 model i clean the spark plug and blow torch it itll start and idle but when the throttle goes its bog and turn off?
Brand new from the dealer? Don't mess with it if so, make them fix it. From what I've read, it may just be the fuel mixture is too rich.
Mar 30, 2014 | 2014 KTM SX 85
I have a 2014 Ultra Limited, how do i remove the gas tank to install new spark plug wires?
I have not worked on a 2014 yet but I WOULD BE AMAZED IF YOU NEEDED TO REMOVE THE FUEL TANK TO CHANGE SPARK PLUG WIRES. HERE is how to remove a 2013 Fuel Tank etc:
Mar 26, 2014 | 2014 Harley Davidson Electra Glide Ultra...
Car had been sputtering and stalling while stopped in "drive". Mechanic mentioned to change the thermostat so I did it myself. The problem still exists and now the blower for the heat and A/c doesn't
  • Doug Warne Your kia here is what i would do to help diagnosisMar 19, 2014
  • Doug Warne First of all i would do these steps"
    Mar 19, 2014
  • Doug Warne how does it run when cold how does it run when hot
    Mar 19, 2014
  • Doug Warne i would look for Vacuum Leaks
    Mar 19, 2014
  • Doug Warne i would remove the spark plugs check engine compression hope to see about 180 psi on each cylinder
    Mar 19, 2014
  • Doug Warne i would exam each spark plugs to see if fowled with Gasoline or carbon keep spark plug with each cylinder because low compression will cause this
    Mar 19, 2014
  • Doug Warne low compression i would exam cooling systemicon1.pngfor airbubles or coolant in engine oil
    Mar 19, 2014
  • Doug Warne if oil looks milky white in color its coolant do not operate vehicle
    Mar 19, 2014
  • Doug Warne change head gasket get head kit with valve cover and take head to machine shop to have shaved straight and checked for cracks Replace head with Remanufactured if warrpiage to great or stress cracks
    Mar 19, 2014
  • Doug Warne check air filter and breather to insure the intake is getting air before you do compression test
    Mar 19, 2014
  • Doug Warne if engine dies when hot lets look at the fuel pump pressure
    Mar 19, 2014
  • Doug Warne lets take and look at the fuel cap where you put your fuel in make sure the vent is open which allow outside air pressure becuase you can have a 100 billion gallon second pump but if there is no air coming into take the pump will pump 0
    Mar 19, 2014
  • Doug Warne Check your OBD 2 codes First this will give you ideas of what happening ie bad oxgen sensor telling me look for vacuum leak or poor spark ignition or poor engine compression, possible injector leaking
    Mar 19, 2014
  • Doug Warne poor compression tell me the engine maybe out of timing and or valves or worn or burnt exspecially when engine is hot and it dies
    Mar 19, 2014
  • Doug Warne a cylinder leak down test would be revealing for valves or piston rings
    Mar 19, 2014
  • Doug Warne if engine has good Intake of Air and gas mixture and then good compression of air and gas mixture and good spark from the Ignition and good flowing exhaust the engine will operated smoothly
    Mar 19, 2014
  • Doug Warne if engine looses power or stalls when hot take a look at the catyalitic converters to see if glowing red or hot one side and cooler on rear side also check the exahust pessure at tail pipe to see if cats are plugged if you have little exhaust pressure and no exhaust leaks
    Mar 19, 2014
  • Doug Warne i hope this helps and i always kiss the job.............
    Mar 19, 2014
  • Doug Warne Keep IT Simple Stupid
    Mar 19, 2014
    Mar 19, 2014
  • Doug Warne as far as the thermostat is the engine running hot..????
    Mar 19, 2014
  • Doug Warne CHECK FOR AIR BUBBLES IN COOLANT as piston compress air if it leaking pass the headgasket seal into the coolant jacket this will cause air bubbles and you may loose heat out of the heater core...i have seen this with cracked heads also so if this is the case have head checked at machine shop
    Mar 19, 2014
  • Doug Warne check the oil from the dip stick smell it see if you smell gasoline this is telling me thin oil, possible injector leaking gasoline
    Mar 19, 2014
  • Doug Warne Low engine Compression with satuerate oil the oil ring on the piston will have hard time to create seal to cylinder wall there fore low compression exspecially when engine is hot
    Mar 19, 2014
  • Doug Warne get a spray bottle fill with water and with engine runing spray water in coil packs and spark plugs wires to see if there cracked or frayed Electricty is lazy it will use the water as a ciricut and go to ground through the water this is telling me cracked coil pack or plug wires engine will began to miss and fumble while running
    Mar 19, 2014
  • Doug Warne these are some tricks i use to help diagnosis problems....hope this helps
    Mar 19, 2014
  • Doug Warne As far as the A/c Heater Blower i would first check the Fuse in the box with a test light, and i would check all the fuses remember you have a battery side and ignition side of the fuse box if the fuse is blow replace with manufacture Amp Fuse and if new fuse shorts then i would look at blower motor draw
    Mar 20, 2014
  • Doug Warne Check your battery Cold Crank Amps with a load test meter most parts store will do for free hoping you will buy a battery and if batter test not good if you choose to not to replace your alternator will be charging constentently and the trio diode board in your regulator located inside the alternator in most applications these days will short then this will cause a battery high amp draw so your battery wont start in the am when your late for work..
    Mar 20, 2014
  • Doug Warne If your battery is loosing charge overnight or anytime you can simply take your negaitive Cable from your batter and put a test light from the negiative cable then touch your neg. terminal and if test light illuminates you have a draw and bad draw so take amp meter and test to see the draw in amps if high amp draw i would first look at the regulator and remove the 12volt singe wire and see if draw disappear if draw is no longer then 99 percent your regulator has shorted
Mar 19, 2014 | 2001 Kia Sportage
On my 2014 eltigre6000 the engine with have a slight hesitation just after slowly taking off! It does it at first warm up and after bar,gas stop,etc!!!!
Hi, Wade and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition and leaking.
3. Spark plug gap too close or too wide.
4. Faulty ignition coil, module, and or sensor.
5. Battery nearly discharged.
6. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
7. Intake air leak.
8. Water, dirt, or rust in the fuel system, carburetor and/or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose, dirty, or corroded ignition module connector at crankcase.
13. Faulty MAP, CKP, O2, and/or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damaged intake or exhaust valve.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
https://www.tradebit.com/filesharing.php/search/0/2014+arctic+cat+zr+6000+el+tigre+es
Mar 02, 2014 | 2014 Arctic Cat ZR 6000 El Tigre ES
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
104 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
