Audi A4 (2002) concert CD/Radio - all LED flashing radomly
All led's flashing radomly - no display digits
No control
Even when car locked radio still flashing - had to take fuse out
When fuse back in I get the same symptoms - no SAFE displayed
The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
1. Turn on radio. The radio display shows "SAFE".
2. Press the FM2 and RDS buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
3. Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
4. Once the code shown on the display is correct, press the FM2 and RDS buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
5. The radio should unlock and be usable shortly afterwards.
6. If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
7. If you lose your radio code, contact your Audi dealer.
IMPORTANT NOTE: You must have the security anti-theft code for yours Audi Concert radio from the car manufacturer!For Audi Concert the sequence of programming is: 1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed. 2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt. 3. By the #1 key you will set up the first safe code digit. 4. By the #2 key you will set up the second safe code digit. 5. By the #3 key you will set up the third safe code digit. 6. By the #4 key you will set up the four-th safe code digit. 7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
IMPORTANT NOTE: You must have the security anti-theft code for your Audi Concert radio from the car manufacturer, or from an Audi dealer! You can find the radio code at: http://www.radio-code.co.uk/
The sequence of programming for a 2002 Audi TT Concert radio is: 1. Simultaneously push "SCAN" and "RDS" keys until on the screen will appear "1000" displayed. 2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt. For example: we have the security code "5079". Then: 3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted. 4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted. 5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted. 6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted. 7. Then simultaneously push again "SCAN" and "RDS" keys to confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready to use! --------------------------------------------------------
Audi Delta CC Radio
Please perform the following procedures while the car is parked. Otherwise you risk getting into an accident while your attention is not focused on the driving. Entering anti-theft code The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
Press the FM1/2 and DX buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
Once the code shown on the display is correct, press the FM1/2 and DX buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
to be the code.
it depends on year of car and make of RADIOHERE IS THE SETTINGS FOR A 2002 AUDI A6 Quattro V6 2.7L Turbo (APB) engine code
For the Audi Concert Radio
YOU STILL NEED YOUR RADIO CODE TO ENTER THIS!!!!!!!!!!!! tell me if this work for you
Entering Anti-theft Code
correct order.
Note: Some European market Concert radios have a TP button instead of
the FM2 button, so the description above with those units would require
pressing the TP and the RDS buttons simultaneously.
IMPORTANT NOTE: You must have the security anti-theft code for yours Audi Concert radio from the car manufacturer!For Audi Concert Radio the sequence of programming is: 1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed. 2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt. 3. By the #1 key you will set up the first safe code digit. 4. By the #2 key you will set up the second safe code digit. 5. By the #3 key you will set up the third safe code digit. 6. By the #4 key you will set up the four-th safe code digit. 7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
i'm not familar with that particular radio.... but try unhooking the battery for about ten minutes then hook the battery up again.... it should be fine.
