Question about Ferret Instruments Digital Tach Advance Timing Light
My timing light dousenot work - Ferret Instruments Digital Tach Advance Timing Light
    Problem Solver:
  • 18 Answers
Most like you need to check the 'U' shaped core in the pickup if it is broke no flash.
If this is not the problem then you need to open the unit get a coated wire stripped ends 0.5 inches. there is a large yellow capacitor. Short this out first! Mostly this cap has a problem with loosening the solder joint(s) so check this first. The next area would be the flashtube area. Check the diodes and there is a trigger transformer. The phone number is 800-627-5655 Chris and Evy run the repair dept.
Posted on Jan 26, 2015
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
The low. Beams don't work but all the other lights
sound like faulty DRL RELAY causing all your problem.
May 29, 2013 | Cars & Trucks
A/C works sometimes/ ac light doesn't come on
I would guess a loose electrical connection. Have you had work done lately?
May 18, 2013 | 2001 Oldsmobile Aurora
I have 2008 Malibu 4 cylinder and my engine light comes on, my temperature gage at times doesn't work and when it isn't working the fan keeps running and the engine light goes off at times, th
You need to find out the fault code that is stored that is causing the check engine light, the whole thing may be related to one failed part like the temperature sensor or the wiring to it.
May 17, 2012 | 2008 Chevrolet Malibu
Where are the timing marks on ford ascape 2001 v6 3.0
On the crankshaft:
Timing Lights There are two basic kinds of timing lights--DC powered timing lights, which operate from your vehicle's battery, and AC powered timing lights, which operate on 110 volt house current. Of the two, the DC light is preferable because it produces more light to see the timing marks in bright daylight. Regardless of what kind is used, the light normally connects in series with the No. 1 spark plug using an adapter. Models that are more expensive sometimes use an inductive pickup, which simply clamps around the plug wire and senses firing impulses. Inexpensive models use alligator clips; one clamps onto the connection between the plug and the plug wire, and the others clamp onto the vehicle battery terminals. NOTE: Some timing lights will not work on electronic ignition systems, so unless you still own a vehicle equipped with points, check to make sure the timing light you buy will work. The biggest problem you will probably have when using a timing light is trying to see the timing marks on the crankshaft pulley. Before you time the engine, mark the appropriate timing indicators with fluorescent paint or chalk. Stay out of direct sunlight when you time the engine and buy a timing light with a xenon light, not a neon light. Timing lights that use a xenon tube provide a much brighter flash than those that use a neon tube do. Fig. 1: A modern electronic timing light. Note the inductive pick-up clamp. 88521p22.jpg
Nov 12, 2010 | 2001 Ford Escape
Service light came on and day time running lights
No service light may means a different problem.You need a diagnostic tool in order to clear this light.Replacing only the bulb may not solve your problem.
Oct 05, 2009 | 2002 Chevrolet Cavalier Coupe
98 Ford Explorer Brake lights not working,top brake light does
I had a similar problem like this with my 98 explorer once; neither brake lights worked and the top one stayed on very dimly at all times. It turns out both of my brake lights went bad at exactly the same time, which for some reason made the top light stay on. Felt like an idiot, but all I needed to do was change the bulbs.
Sep 10, 2009 | 2003 Ford Explorer
1990 Mazda Miata, Tail lights, Interior lights not working! :\
I have a problem with my tail lights in my mazda. Brake lights working great but the light that supposed to be working during night time are not. By the way the front lights are working too! Also the light of the panel inside is not working. Can anyone please tell me how to fix it?
Thanks alot in advance!
Sep 06, 2008 | 1990 Mazda MX-5
Ferret Instruments  Digital Tach Advance Timing Light Logo
203 people viewed this question
Top Ferret Instruments Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Ferret Instruments Measuring Tool and Sensor Expert? Answer questions, earn points and help others
